Unit will turn on, but no sound, also displays "OFFSET" error
When i turn on the unit, no sound comes out, and it displays a message that read "OFF SET"
  • sherrill7885 May 08, 2009
    this occurs when i initialy turn on the unit,
  • Mike LaPres
    Mike LaPres May 11, 2010
    What are you trying to turn on and what is connected to it.
  • 757 Answers
The typical cause for this amplifier damage or a short on the rear panel.
Check your speakers terminals to make sure they are secure and that there is no stray wiring from the speaker cables that can make contact with anything other than the binding posts.
Posted on May 08, 2009
Tip
ERROR CODE AND POWER SUPPLY CIRCUIT
Viewing the Self Check Diagnostic List
1. TV must be in standby mode. (Power off).
2. Press the following buttons on the Remote Commander within a second of each other:DISPLAY > Channel 5 > Volume - > TV POWER .
Results for all of the following diagnostic items are displayed on screen. No error has occurred if the screen displays a "0".
NOTE: If the Service Menu display text is not completely visible, press the Menu HOME button on the Remote Commander to refresh the display.
3. To exit Self Check display, turn the power off. Press [Menu] Exit.
Clearing the Self Check Diagnostic List
1. In Service Mode, press the Channel 8 Channel 0 .
RESETTING TO FACTORY DEFAULTSUse the following instructions to restore the User Controls and
Channel Memory settings to the preset factory conditions.1. While holding down the UP ARROW on the Remote Commander, press the POWER button on the right side of the set.The set restarts and displays the initial setup screen. This may take several minutes.
White Balance adjustment
1. Allow approximately 30 minutes for the set to warm up before proceeding with the white balance adjustment.
2. Connect the signal source to the 3 terminals of the Component In input (Y/Pb/Pr).
3. Set the Picture Mode to "VIVID" in the user menu.
4. Select the Component In input.
5. Open the Factory Service Menu (see section 3-1.) and select "Service Alignments Menu".
6. Set "White Point Red", "White Point Green", "White Point Blue" and "Black Level Offset Red", "Black Level Offset
Green", "Black Level Offset Blue" to average values .
"Cool " White Balance Adjustment
1. Select "COOL" from Color Tone in Service Alignments Menu.
2. Input 70IRE full white pattern signal into Component In.
3. Adjust "White Point Red", "White Point Green", "White Point Blue" in Service Alignments Menu if needed.
4. Input 25IRE full white pattern signal into Component In.
5. Adjust "Black Level Offset Red", "Black Level Offset Green", "Black Level Offset Blue" in Service Alignments Menu if needed.
6. Repeat steps 2 to 5 to achieve desired White Balance.
FOR MORE DETAILS CHECK THE FOLLOWING LINK
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
USE SEARCH TAB TO FIND MODELS OR USE THE DROP DOWN MENU
on Jun 30, 2015 | Sony Bravia L-series Kdl-32l5000 32-inch...
Tip
SERVICE MODE AND ERROR CODES CHECK
on Jun 30, 2015 | Sony Bravia KDL-26L5000 26 in. LCD HDTV
Electrolux Icon side-by-side E23CS75DSS - repair man replaced the defrost thermostat and now the digital temp display flashes. The freezer temp display flashes "E" and the fridge display flashes...
Sounds like you have a evaporator fan motor. That is what the error code you have indicates, the fan blade could be stalled to.
I work on these units every day and know them very well, I can walk you through any repair on this refrigerator.
http://www.appliancerepairlesson.com/
Mar 01, 2011 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Tip
Ink System Failure Fix for Some HP Printers
<span><span>Hewlett Packard Ink System Failure Error Fix (tested C6180) </span></span> <ol> <li><span><span>Press and hold the "*" key. </span></span></li> <li><span><span>Press the "#" key and release both keys. Display should say "Enter Special Key Combo" </span></span></li> <li><span><span>Press and release in sequence the "1", "2" and "3" buttons. screen says "support" R0631M </span></span></li> <li><span><span>Press and release the right arrow button until the display says "System Configuration Menu". </span></span></li> <li><span><span>Press and release the "OK" button.</span></span></li> <li><span><span>Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status", </span></span></li> <li><span><span>Press and release the "OK" button. </span></span></li> <li><span><span>Display should say "Hardware failure status: Clear. Press OK to clear". </span></span></li> <li><span><span>Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue". </span></span></li> <li><span><span>Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE. </span></span></li> <li><span><span>Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.</span></span></li> <li><span><span>Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer </span></span></li> <li><span><span>Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK. The Printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page. </span></span></li></ol><span><span>I hope this helps</span></span> <span><span><br /></span></span> <span><span>Regards GM</span></span>
on Jul 15, 2011 | Office Equipment & Supplies
Tip
How to Troubleshoot CF-19 The Panasonic Toughbook CF-19, commonly known as...
How to Troubleshoot CF-19<br /><span style="font-style: italic;">The Panasonic Toughbook CF-19, commonly known as simply the Toughbook 19, is a laptop computer geared towards people who work on location, such as field workers or military personnel, who require a sturdy and resilient device. Unique features of the model include its screen which can display clearly in bright sunlight, its touchscreen function and its backlit keyboard. If you experience errors or malfunctions with the CF-19, troubleshoot it to diagnose and solve the problem before replacing the device or seeking professional repair.</span><br style="font-style: italic;" /><br /><span>Instructions</span><br /><br /><span>Device Turning On</span><br /> <ol> <li> <span style="font-style: italic;">Check that the AC adapter is connected properly. One end should be plugged into the laptop and the other end should be plugged into a working AC outlet. If the adapter is disconnected at either end, connect it.</span></li> <li style="font-style: italic;"> Disconnect any device connected to the laptop's USB port or ExpressCard slot. A malfunctioning device may cause the laptop to malfunction and not turn on.</li> <li style="font-style: italic;"> Press the "Fn" and "F8" at the same time to turn off "Concealed Mode." This mode disables the power functions of the device.</li></ol><span>"Remove disks or other media. Press any key to restart" Error Message</span><br /> <ol> <li><span style="font-style: italic;"> Remove the floppy disk or CD-ROM from the device and press any key. This message indicates that the disk does not contain system startup information and cannot run on the device.</span></li> <li><span style="font-style: italic;">Disconnect any device connected to the laptop's USB port or ExpressCard slot as problems with these device's may also cause this message to appear.</span></li> <li><span style="font-style: italic;"> Contact Panasonic Technical Support if this problem persists after attempting Steps 1 and 2 as this may be a sign of a problem with the laptop's hard disk and it may need repairing or replacing.</span></li></ol><span> No Display/Screen is Blank</span><br /> <ol> <li style="font-style: italic;"> Press the "Fn" and "F3" keys simultaneously to switch to "Internal Display" mode as the device may have been set on "External Display."</li> <li style="font-style: italic;">Check if the device is in "Power-Saving" or "Sleep" mode by pressing any key on the keyboard. The screen should come on if the device was simply in "Power Saving" or "Sleep" mode.</li> <li><span style="font-style: italic;"> Turn on the display screen or monitor of the connected device if you have the laptop set on "External Display" and want the display to come up on that device.</span><br /></li></ol><span style="font-style: italic;"><span>Hopefully this can help<br /><br />regards<br />multilinkent</span></span><span><span><span style="text-decoration: underline;"><span style="font-style: italic;"><span style="font-weight: bold;"><br /></span></span></span></span></span>
on Jul 08, 2011 | Computers & Internet
 Grubhead
Grubhead
