Question about Hotpoint 30" 1.5 cu. ft. Microwave Oven RVM1535
Blown fuse in RVM1535DMWW
Need help locating inline fuse
My Panasonic genius sensor 1250W microwave has stop working, now is their fuses i need to check,or is their a way i can, check the heating element to see if i us out.
Kevin,
There is a fuse in a microwave. One way you can tell for sure if the fuse has blown is that there will be no lights or any activity when you push buttons. The screen will not light up either. If that is your case, then you can be fairly certain that your fuse has blown. I would suggest before working on it that you plug something else into the same outlet and see if it works okay so that you can eliminate that you lost power in your outlet. If all of that is okay, then turn your microwave around so that you are looking at the back and take out the screws that hold the cover on. Remove the cover and look at where the power cord goes into the back of the unit. Find the black wire from the power cord and follow it to either an inline fuse holder, or a fuse block, or a circuit board. Depending on your model, you should have one of these three options. Make sure that you replace your fuse with the same amperage fuse that you take out. Look on the metal rings at each end of the fuse and that will tell you what amp fuse you need. Hope tis helps!
Feb 26, 2015 | Panasonic Microwave Ovens
How to start oven in rmv1535 model microwave
You can download GE owner's manuals and installation instructions here.
Dec 25, 2012 | Hotpoint Hot Point RVM1535DMWW Over the...
I plugged in the new microwave, model JVM1740DP1CC, and nothing happened, is there a fuse inside the mivcrowave and where is it located
Hello there and thank you for choosing fixya
Yes these microwaves al have a small inline fuse in them and thye a re located on the controle board you need ot remove the outer cover and then the fuse will be seen on the right side towards the front as you are looking at it it is a small fuse that simply pulls off and a new one snaps back in place
Walmart or radio shack will have theese also any automotive parts store will carry them too ok
Hope this helps.
Best regards MIke
Jul 25, 2011 | GE Spacemaker JVM1740 Microwave Oven
MICROWAVE IS NOT HEATING BUT EVERYTHING ELSE IS RUNNING NORMALLY
there is on some Models fuses that can be replaced and or an Thermal fuse blown , got too hot and shut down the heating element , both can be purchased @ Radio Shack , Thermal fuse rated @ 8-10 amps for a few dollars . . and can be crimped on or soldered inline. hope this works for you ? good luck >
Dec 20, 2010 | Jenn-Air JMV8196 Microwave Oven
Food is not heated
two things could be wrong. One, There is an inline fuse that allows the current to flow to the magnatron. If this fuse is blown then the unit wont heat. Remove the outer cover and follow the cord into the unit and you should see the fuse. Make sure you replace this fuse with the same type. If the fuse doesnt work then the magnatron has gone out and cost for repair is about the cost of a new microwave
Dave
Mar 18, 2010 | Microwave Ovens
Micro wave simply quit. How an I check to see if
The fuse is located inside the microwave. You will need to remove the front panel to get to it. It will be located on the black power wire inside the microwave and installed inline. Make sure that the microwwave is unplugged before removing the front panel. Once you locate the fuse inside you will need to remove it and test it with a continuity tester to see if it is blown. If it is make sure you replace the fuse with the same amp rating you found. If the new fuse blows again then there is an electrical short somewhere inside the microwave.
Dec 24, 2009 | Emerson MW8778 Microwave Oven
Heat won't work on ge spacesaver microwave oven --what to do from
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
ioi
Dec 16, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
No power
yes there is an inline fuze it should be inside the microwave around where the cord comes in
Apr 24, 2009 | Microwave Ovens
Microwave has no power
I'd say the thermostat and/or fuse are blown. I just hope the magnetron survived.
I don't have that exact model's service manual but ones before and after only used one thermostat, similar to the drawing below.
They also have a fuse, usually located in an inline fuse holder connected to the power cord inside.
For Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit here.
Goldstar owner's manuals can be downloaded here.
Aug 21, 2008 | Goldstar MV-1515 Microwave Oven
Nothing works, blank touch pad
before you replace a circuit board check the inline fuse on the unit if you take off the the front panel you usually can see the fuse it is a 20 amp fuse you will need an meter to check resistences across the fuse it should read read 1 to 2 olhs on the meter if that does not work then you need to check tstat on the megatron itself or the the cavity tstat more than likely it is the fuse
Mar 22, 2008 | Whirlpool MH7135XE Microwave Oven
Hotpoint 30" 1.5 cu. ft. Microwave Oven RVM1535 Logo
Top Hotpoint Microwave Ovens Experts
William Miller
William Miller
Jim Thurston
Are you a Hotpoint Microwave Oven Expert? Answer questions, earn points and help others
