Question about Craftsman Garden
Chainsaw oil I have a craftsman electric chainsaw 2.0/14" model number 358.34810. What oil do I use for the chain? thank you.
  • 770 Answers
SOURCE: ive just bought a husqvarna 34 husky is this the
Get Chain lube for the chain oiler. Naturally, husqvarna recommends that you use "genuine husqvarna" oil for your mixture, I recommend a quality oil, doesn't have to be husky. Husqvarna recommends a 50:1 ratio, other manufacturers, of vertually all 2 cycle power equiptment use a 40:1 ratio. This mixture is slightly richer, but will not hurt your chainsaw. May produce a bit more smoke. Not sure what a 34 husky is...neither is Husqvarna, I visited the website and even tried to download a manual. Looked at every husky model, no 34.
Posted on Jun 21, 2009
spekgt
  • 60 Answers
SOURCE: 455 rancher chainsaw does not pump oil to the chain
If you look under the machine by the chain you'll see a flat head screw (next to the sprocket) which controls the bar and chain oil flow . Try to turn the screw and check if there's any oil flow to the chain . If not you will need to replace the oil pump (part # 537 10 55-02 which will cost you about $35.00) Hope this help
Posted on Aug 29, 2009
dontbother10
  • 2220 Answers
SOURCE: I have Craftsman 36cc 16in Model-358-350461no oil to the bar.
We are prohibited from contacting you directly.
Oil System Plugged:
1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar), if equipped with a sprocket nose ensure it rotates easily at least one complete revolution.
• Clean the saw oiler hole and channel. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out.
• Pay attention to the screen or filter on the free end (clean or replace, difficult to determine serviceability).
• Start the saw and see if it oils when revved up (oozes down side of saw).
• If yes reassemble your saw. If no, continue with 2.
2. Work your way through the linkage (use IPL to identify components and locations) cleaning and replacing any defective parts as you go.
• Carefully check the hoses for cracks especially at bends and connections.
• If equipped with an oil pump it is usually behind the clutch (clutch is a left handed thread).
• Please make extensive notes & some digital pictures will help during reassembly.
3. If it does not oil on completion of 1 it is most likely a bad oiler or worm gear (see IPL for the location).
The IPL (exploded parts list) for your saw is the only detail for the oil system, it is sketchy at best. Oiler components and part numbers are listed but may be on different illustrations. They are also beneficial with disassembly/reassembly:
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=358350461&productCategoryId=1503220&brandId=0247&brandDescription=CRAFTSMAN&modelName=CHAINSAW&diagramPageId=00001&componentDescription=CHASSIS%20BAR%20CHAIN&documentId=P0205138&blt=06
It appears to have an outboard clutch, this will be helpful;
R² Drive Link Outboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=cdqkIuVNUQc
  1. Check the IPL for your saw to see if any special tools are needed. Poulan (Craftsman, Jonsered, Husky) clutch removal tool part number 530031112 if needed, is under $5 from many sources (look at the visible area between the weights if 2 small round sockets are visible you need the tool).
  2. There are metal piston stops available, when square (almost never) with the piston top these work well, if not square they have been known to punch through the piston. I suggest a length of nylon rope (nothing left behind) be used instead of the piston stop (retain 6" ± so you can remove it). Make certain the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
  3. Everyone I have ever removed had a left handed thread (tighten it to loosen it).
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on May 11, 2010
SOURCE: I have a craftsman gas chain saw model 358.352180....
Make sure you drain the oil when storing your saw. That's because the saw is designed to supply a generous amount of oil to the chain and bar.
Posted on Jun 18, 2010
  • 95 Answers
SOURCE: my 18 " craftsman chainsaw will not oil the chain.
Take the bar off and clean the grove out with something like a small flat blade screwdriver.Make sure its open where it bolts on.It gets its oil through the bolt holes.If you have a way to blow the dirt out it helps.You can try running the saw without the bar on to see if its putting out any oil.If not you will have to get to the oil pump to see if its not bad.
Posted on Mar 08, 2011
How to replace clutch model 316341070
See if there is too much tension on the chain. Is there enough chain oil on the chain? Go to the Sears Parts website to get the clutch.
Aug 27, 2014 | Craftsman 16" Electric Chainsaw Chain Saw...
Need manual for electric chainsaw 316 341070
follow this link.
http://www.ioffer.com/i/sears-craftsman-chain-saw-manuals-model-316-341070-143713729
Apr 20, 2013 | Craftsman 16" Electric Chainsaw Chain Saw...
Have a problem with my electrical Kraftsman chain saw, the engine is running and the chain is rotating, but when I put it against the tree for cut, the chain will stop rotate bot the engine is still...
The main drive gear is slipping. This is caused by etiher worn teeth or worn bearings. If you pass the model number I can show you a diagram of where to look and what part or parts that have most likely failed. The drive gear is the weakest link but the motor can be shifting in the housing away from the drive gear. It only takes a bit less than 1/8 inch side play. The model number will be similar to this 358.341160
Most likely it is item 26 of this diagram:
http://c.searspartsdirect.com/lis_png/PLDM/P0101241-00001.png
This example is for model 358.381160
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Chainsaw-Parts/Model-358341160/0247/1503210/P0101241/00001?blt=06&prst=&shdMod=
Thanks for choosing FixYa, Kelly
Sep 13, 2011 | Craftsman 16" Electric Chainsaw Chain Saw...
Describe your sears 18"
I put a new bar and chain on my craftsman 18" chainsaw because the chain keeps coming loose. I am still having the same problem, after running 10 seconds, the chain falls off.
Sep 11, 2011 | Craftsman sears 18" Chain Saw Chain (...
My 18 " craftsman chainsaw will not oil the chain.
Mar 08, 2011 | Craftsman sears 18" Chain Saw Chain (...
Need a manual for a 14" Craftsman electric chain
Use model number 315.34020 which is the same saw w/o power sharp. In fact the 34030 model is mentioned in this manual. I haven't found anything relating to the 34030 model specifically. Oregon products is able to cross reference the saw and find parts for it (less the power sharp feature.)
Jan 02, 2011 | Craftsman Garden
Where are the oiling ponts to the bar to the ryobi 16 inch petrol chainsaw?
Hi
It's Lisa?
On an electric chainsaw there usually aren't what you would call oiling points.Somewhere,probably on the rear or one side of the case will be a bulb.It's also the screw on cap for the oil reservoir.
You fill that up with chainsaw bar oil,and as you use the saw every few minutes push the bulb down 2-3 times and it applies oil to the chain and gear in the case.The chain transfers the oil to the bar.
If this helps,would you rate my post please?
Thanks Bob
By the way,if you give me your model number I can look for a manual somewhere.No promises though,Ryobi likes to sell their manuals rather than download them.
Aug 16, 2010 | Ryobi 18-inch Electric Chainsaw Chain Saws
I have a craftsman gas chain saw model 358.352180. It leaks oil from underneath the saw even when not in use.
May 19, 2010 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Need to know what kind of oil to put in ryobi chainsaw
If it is an electric chainsaw (not gas powered) then the only oil you need is chainsaw bar oil, which lubricates the chain and bar during use (self feeding system). This goes into the chamber at the top of the saw. You can buy chain/bar oil for chainsaws at any good hardware store or outdoor power equipment store. You can use any brand of chain bar oil, most are pretty good.
If it is a gas/petrol operated model, I will need to know the model number to advise on that.
Jul 03, 2009 | Ryobi 18-inch Electric Chainsaw Chain Saws
Garden Logo
42 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
