Question about Pro Line Home Security
Pls how can I programme proline UK pr911 with four wired sensors and one wireless sensor
Programming wired sensors from the panel
3 Suggested Answers
  • 78 Answers
SOURCE: Can't add sensor
Hi, try code 4321.
Posted on Sep 09, 2009
  • 74 Answers
SOURCE: I am trying to trip this sensor for programming
If you open up the cover there is a tamper switch inside. Try tripping that.
AlarmProfessor.net
Posted on Aug 23, 2010
What does Err4 mean on proline PFL510W-U1 washing machine
proline pfl510w u Washing Machines Questions & Answers ...
www.fixya.com > Forum > Tags > proline pfl510w u
Washing Machines proline pfl510w u questions and answers. ... need user manualfor proline logic on line need user manual for proline logic ... PROLINE LOGIC 6 KG AA WASHING MACHINE- It is stuck on "error2" what does this mean and ...
Washing machine PROLINE PFL510W - Manual.com
https://www.u-manual.com/...manual.../washing-machine-proline-pfl510...
On this page you can get: Washing machine PROLINE PFL510W manual - is available for free download. All information such as file size, preview picture, ...
Anyone know how to reset a Proline washing machine ...
forums.moneysavingexpert.com/showthread.p...
MoneySavingExpert.comApr 3, 2010 - I can't find the manual, either at home, or online. Our washing machine(PFL 1466W-U) is showing off today. We've managed to take ... Does anyone know how to stop it from running this programme, so that we can select the empty/spin cycle. We have .... Ok it's a cover not written but you know what I mean.
Dec 16, 2015 | Washing Machines
Dyn8163d8p
Has the programme finished but the door remains locked? Turn the machine to OFF to reset the machine and this will allow the door to open.
Then look at this > Has the programme finished? Is the END light illuminated? If not the programme is not complete. Has the door locked light gone out? If not wait a further couple of minutes and the light will go out and you will be able to open the door.
If nothing happens and door still locked, and you live in the UK you need to ring this number > Phone 08444 995 599 to book your repair
E05 is a fault on the temperature sensing circuit. You need to check the wiring to the temperature sensor at the bottom rear of the tub. (circular item near the element). Unplug it, check the terminals and the wiring, check the connector on the sensor. If all ok, take the sensor out, clean it and refit it. Try the machine again. If the fault persists and the wiring and connections are good, you'll need to try a new sensor. Check it out, see how it goes and get back to me if you need more help Hope this helps
May 12, 2014 | Hoover Washing Machines
Programming the remote sensor to the 44665 hunter thermostat
Just fixed mine;
Note the sensor channel on face of remote
(ref: http://www.manualslib.com/manual/257219/Hunter-44665.html)
Mine was set on Ch15, well the thermostat only monitors 14 channels had to flick down dip switch #1 to set Ch7.
Then on the base unit thermostat, see page 5 of a similar unit for 44668/44665 manual (below) then wait about 10 minutes for things to sync up, and press remote button to check sensor temp.
Note the button order for Remote Sensor Programming at base thermostat:
http://www.hunterfan.com/SupportDocuments/OwnersManuals/44008-01Thermostat44668-44660WebR02102010.pdf
Feb 05, 2012 | Hunter Fan Company 5/1/1 Programmable...
Is there an easy to understand user manual for the aube TH132 AF ? Even my father in law can't understadn how to operate the under floor heating on a timer...
http://www.uheat.co.uk/aube_th132_underfloor_heating_thermostat.htm
TH132 is a thermostat for under-floor heating
Go to the website above and download on-line copy of your manual
On-line manual let you read bigger print & lets you break down the steps easier
I am sure by the time this answer reaches you, the problem will be solved
This is true because manuals are frustrating, until you tell somebody it can't be figured out >> which gives you time to rest >> after which the manual makes sense.
BUT I am frequently wrong, and you may be at a standstill
A quick look at the manual.
You can also select which part of the manual is giving you a problem and then I will help you through that specific difficulty
Wiring: I guess the instructions at bottom of manual apply to your model
Your 240Volt hot wires from breaker box connect to terminals 1 & 5
Your two wires supplying power to heat connect to 2 & 4
Pilot wire to terminal 3
Floor sensor to 6 or 7 >> wire from sensor can connect to either pole
The TH132 has two sensors, 1 located inside the TH132, the other sensor located in floor
Set up:
The first part describes 10 buttons (right away you know this is complicated)
There is a brief description of both sensors
Step 1 shows how to configure the start and temp-display switches
Step 2 covers installation of module on base
I guess you hook up power at this point because the display is supposed to light up
This implies that the bottom part of manual should be located more towards the top, and the power-up directive seems to be missing. Bad manual.
Step 2 shows what the display looks like with first power-up
Step 3 tells how to set current time and day.
Step 4 adjust temp setpoints >> floor temp is pre-programmed to 82 degrees
Step 4 shows that you press-and-hold the sunshine or moon button to have it display
The sunshine button is the upper temp setting, the moon is the lower temp setting
Step 5 is operating mode > choose automatic for programming to operate
Step 6 is programming, which carries on with about 24 steps
If this is your problem area, let me know
Now the manual suggests you make a chart of your programs
Other programmable devices don't work when there is a conflict in programming
Wow I see the TH132 is 'equipped with a proportional adaptive controller..' that carries a two year warranty. I'm sure you'll rest easy knowing that.
Reply back with the specific trouble area, and we'll get it going for you.
Oct 21, 2010 | Aube Technologies Aube 7-Day Programmable...
Recode steering angle sensor
For recode the steering angle sensor you must connect a diagnosis scantool to the data link connector of the car in order to access the ESP ECU (Electronic Control Unit), in other words programm again the steering angle sensor in the ESP ECU. Select the steering angle sensor programming (learning) menu, and follow the steps: put steering wheel in straight direction, then turn steering wheel to the left direction less 15 degrees, then to the right direction less 15 degrees, put steering wheel in straight direction again until the programming was done. Then the ESP light will turns OFF.
Aug 20, 2010 | Audi A6 Cars & Trucks
I need instructions for programming a Blue
Page 7 Programming
visit this website Link: http://www.emersonclimate.com/Documents/White-Rodgers/0037-6753.pdf
If you need futher help call hometechline 18002842925.
Feb 19, 2010 | White Rodgers White-Rodgers 1F85RF-275...
Sensor bar not working
Yeah you can get new sensor bar you can get wireless ones quite cheap only about 8 pound from lots of places such as : http://www.amazon.com/Nyko-87005-Wii-Wireless-Sensor/dp/B000LFJNG6 or http://www.amazon.co.uk/TeckNet-TYW-1009-Nintendo-infrared-inductor/dp/B000P0YV9G/ref=pd_bbs_9/203-3453072-6118343?ie=UTF8&s=electronics&qid=1189218297&sr=8-9
Sep 06, 2007 | Nintendo Wii Console
Home Security Logo
19 people viewed this question
Top Pro Line Home Security Experts
Lawrence Oravetz
Are you a Pro Line Home Security Expert? Answer questions, earn points and help others
