Tylo combi 8 sauna heater keeps tripping - Heating & Cooling
5 Suggested Answers
  • 9 Answers
SOURCE: heater only gets mild warm Tylo sport 4 heater
more than likley installation problem not enough voltage top operate heating element
Posted on Feb 01, 2010
SOURCE: I just bought a house with an amerec sauna. The
the 'easy' answer would be a tripped high-limit switch. Inside the generator box, there is a resettable circuit breaker to the heating element, on the top of the water tank.
kill the power to the unit, take off the shell and look for the pushbutton.
If that is the problem, there is a likely chance that the temp sensor in the shower is not working so it overheats and trips the high temp limit.
Posted on Apr 29, 2010
SOURCE: My tylo supersport 8 sauna
Remove the unit bottom panel (2 small screws) and look at the quick disconnect terminals on the heater rods ( 6 heating rods - 3 on each side of the unit). If you have any corrosion on these terminals, the wires will overheat and fail, preventing the heating rods from working. If the wires did overheat, you should see melted wire insulation. Replace bad wire and quick disconnect terminals with new. Should cost less than $20.
Posted on May 29, 2011
8880u81
  • 3103 Answers
SOURCE: I have a brand new Blue Wave sauna that has been
these have a ground fault interupt built in for safety and to prevent electrical overloads.. it may need replaced due to not being heavy enogh to run it..there should be a minimum amp rating somewhere..like a base rate of 50 amps or so..look at the rating and see what the power outlet has on it.. may not be strong enough..or the ground is bad..
Posted on Jan 02, 2014
Heat is not working on hvac package unit
The unit you state is a Sauna heater/humidifier. I do not understand how or why it is connected to a heating ventalting air conditioning (HVAC) system, please explain.
Mar 17, 2014 | Tylo COMBI-U7 Heater
My Tylo sauna high limit keeps tripping
overheating check voltage if ok bad heater element
Jan 28, 2014 | Tylo Sauna Heater HETYSPRTU2 22 kw
Where is the safety shutoff on a Tylo super sport 7
On top of the unit/sauna, you will need to remove the roof or wood covering. It is held down with screws, usually. If your unit in fact does have a reset it will be located on the side of the control box which is located on top of the sauna.
Jan 15, 2013 | Tylo Super Sport 7 Sauna Heater
My tylo sauna will not switch on
check fue inside if bad check heater
Sep 07, 2012 | Tylo COMBI-U7 Sauna Heater
Tylo sauna heater won't heat
if not calling for heat check temp sensor
Jan 19, 2012 | Tylo COMBI-U7 Sauna Heater
My tylo supersport 8 sauna no longer produces heat. The timer works but there is no heat. I have checked the circuit breaker but that doesn't appear to be the problem. Any thoughts??
Nov 23, 2010 | Tylo SUPER SPORT-U8 Sauna Heater 8 kW
The steamer does not work in my tylo combi 8 Do you have any solution to have it fixed
When was the last time you removed the rocks and cleaned out the deposits? Replace stones if they are in bad condition. This should be done once a year. also, a limit switch could have tripped and you need a service tech to reset the switch. Hope this helps and if it doesn't, call a dealer in your area. Tylo is a swedish company but there is a N. American handler http://www.airmist.com/.
Mar 21, 2009 | Tylo COMBI-U8 Heater
Heating & Cooling Logo
41 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
