SOURCE: bobbin thread bunching
Hello every one I have the Manual available for the Kenmore 12102 sewing machine in (Pdf downloadable) for those in need of this booklet. You may email me at [email protected] this email address is also used for outreach ministry.
By the way my name is Borther Paul.
SOURCE: Bobbin thread not catchinig Kenmore model 385 12912890
Christytn,
I am going to guess that you have the bobbin thread facing the wrong way. When you
put it in the case, open part facing you, make sure the thread is going clockwise.
That should fix the problem.
Debbe
SOURCE: Old Kenmore 158. bobbin issues, thread clumping and such
problem is always on the opposite side of the fabric, in your case the machine is not threaded properly.
SOURCE: kenmore sewing machine (new) - bobbin threading
If the bobbin winder is not turning after pushing it on it will either be that there is some oily rsidue on the winder rubber, the winder rubber is worn on one side although if the machine is new it is very unlikely, the winder rubber is not connecting with the balance wheel which means an adjustment and that will mean getting inside the machine which is not easy.
SOURCE: I need instructions threading the bobbin on Kenmore sewing machi
I believe it is a seperate bobbin case, hold the open part of the bobbin case towards you with the finger at the top, hold the bobbin case by the latch, drop the bobbin in so it turns anti clockwise and pull the thread through the slot about 6 inches, keep hold of the latch, and pop the bobbin case in
