Question about Maytag Centennial MVWC6ESWW 4.0 cu. ft. Top Load Washer
Mvwc6es agitator starts on filling - Maytag Centennial MVWC6ESWW 4.0 cu. ft. Top Load Washer
Washing machine starts agitating before fill
Pressure switch stuck you can pop the hose off the switch and blow thru hose it may reset and fill correctly before agitation will eventually stick again.
Jan 12, 2014 | Maytag Washing Machines
Will agitate instead of fill
The pressure switch it broken of the pressure switch is clogged. Please contact me so I can help you.
Jan 02, 2014 | GE GTWP1000MWW Washer
Washing machine filled but wont agitate after the fill,it humms
Maybe the agitator isnt agitated enough.....yell at it for a bit...see what happens....if it that dont make it spin poor a lil rum in the tub....
Mar 01, 2010 | Whirlpool Washing Machines
Agitator starts before water fills. When adjusting
There may actually be more than one setting on the diaphragm control, or you may two diaphragms each with their own setting control. I hope this helps you! Good luck!
Dec 29, 2009 | Washing Machines
Agitator starts at begining of cycle before washer is full
Please be carful as running the agitator without enough water will overheat and kick out the motor, however it should be ok when it resets itself.
Yes, the machine should stop agitating when you lift the lid so this too is part of the problem.
After looking at the print I can only suggest that the cam contacts in the timer ( contacts 12 and 14) that start the motor are burned and stuck together.
Quentin
Sep 17, 2009 | Frigidaire FEX831CS Top Load Stacked...
Fills with water but won't start washing.
This may be worn agitator dog cam assembly or drive spindle. Remove agitator and/or disassemble (if the agitator is dual action) and inspect for wear debris and worn spindles.
if no then it may be a motor coupling may be broken or it may be a bad lid switch.
Hope this helps.
Aug 14, 2009 | Whirlpool Dishwashers
Kenmore 80 series washer. Agitates immediately and does not fill
it sounds like the water valve is bad,the water valve level(sm. med. lg.)controls the water valce-mike
Jul 17, 2009 | Kenmore 24032\24036 Top Load Washer
KitchenAid washer Model#KAWS700jqsr fills but won't agitate
if it's making a loud buzzing noise while its suppose to be agitating or spinning its the motor coupling
Dec 20, 2008 | KitchenAid KAWS700L Top Load Washer
Agitator always moving
The inner tub on some machines does rotate very slowly while filling to assist with the even distibution of the load. If the agitator is turning back & forth while in fill mode, you could have a timer or transmission problem. You need a tech.
Nov 04, 2007 | Kenmore 98702 Stacked Washer/Dryer
Maytag Centennial MVWC6ESWW 4.0 cu. ft. Top Load Washer Logo
19 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
