Question about Wildgame Innovations WGI N4E DIG CAMERA IR 4C 4MP
Cant get flextime pict. out of sd card - Wildgame Innovations WGI N4E DIG CAMERA IR 4C 4MP
My internal memory says it is full.It is a kodakeasysharem538,I really need to get these picts.off there.
If you don't want to delete them you need to either connect the camera to your computer and download them to a folder, then delete them from the camera, or remove the memory card and plug it into your computer and do the same, then put the card back in the camera.
Mar 21, 2015 | Cameras
How do I get pics of off camera when it has no sim card in it
The camera came with a CD. On it is the software you need to retrieve the pictures. But I don't think there are any on the camera, if you did not insert a memory card.
Perhaps one or two, but certainly not tons.
Before you use the USB cable (came with the camera too) to connect the camera to the computer, you have to install the software from the disk on your computer. After installing the software you can connect the camera and the computer will recognise the camera. First time give it a minute or so, because the computer needs to install and start a program.
Nov 21, 2014 | Wildgame Innovations Red 6 N6E 6-Megapixel...
What apps do i need to transfer data too my SD card as phone memory is fill?
if its androis use apps to sd apk available on android markets
Mar 02, 2014 | Cell Phones
Day pictures are now white and will take1good night pict then 5-8 are black. Camra is almost a year old. Was taking great Picts.
Do you have the camera set east or west? If you do you need to move to North or South if still not working do a hard reset turn off camera take out battery's and sd card push the button on/off button for about 5 seconds. Then put battery's back in leave the sd card out turn the camera on it should say no card. Once it says that turn camera off then put sandisk sdhc nothing higher than a class 4 speed of the card not the size. Then test camera again if still having the issue call Moultire 8006533334 option 1 and 1 for a live person.
Oct 30, 2013 | Moultrie Feeders Lx30ir Game Spy Camera
I have some pictures that are saved on the internal memory of the camera and not on my memory card, I cant seem to get them uploaded onto the computer.. how do I do that?
Remove YOUR memory card from the camera. then connect the USB cable to the camera - then to your computer.... it will see the internal memory-stored picts.
Oct 12, 2009 | Fuji Finepix Z20fd Digital Camera
How to get pictures off camera onto computer
if you have a sd card reader, put your card in the reader and then go to my computer, then go to removable disc drive, your reader should come up with all the picts on it
Jul 12, 2009 | Disney Pix Micro Digital Camera
Problem import picts via sd cardreader (taken with eos 450d)
Some card readers struggle with high capacity (SD-HC) cards and indeed some older devices.
If you (or a friend) has a lower capacity card (less than 2GB) try that in you camera and then pc.
You can purchase a VERY cheap USB card reader (c.£10 max) and it should sort your problem - I hope!
Jan 05, 2009 | Canon EOS 450D Digital Camera
Pentax Optio S not functioning
I don't know if it would help but try to update the firmware for the camera.
Jan 01, 2008 | Pentax Optio S Digital Camera
Memory card error
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Aug 14, 2006 | Pentax Optio S50 Digital Camera
    Wildgame Innovations WGI N4E DIG CAMERA IR 4C 4MP Logo
    21 people viewed this question
    Top Wildgame Innovations Video Cameras Experts
    Are you a Wildgame Innovations Video Camera Expert? Answer questions, earn points and help others
