Question about Canon PIXMA Office Equipment & Supplies
Canon mg5250 keeps blowing fuse and says wrong print head installed
It says wrong print head is installed and keeps blowing the fuse
  • 4088 Answers
SOURCE: Canon MP470: "Print Head is not installed. Install Print Head"
Some printer brands have a cute scheme that reads a "new" cartridge as good, but the refilled one has a small fuse link that is burned out by the printer. Try factory new cartridges. Unplug the printer power for a bit to reset the printer.
Posted on Jul 17, 2009
Geekman
  • 32281 Answers
SOURCE: Canon MG5250 - Can I print any documents that is
The only documents you can print using the flash drive are photos.
Connect a USB FLASH memory device and access your photos quickly and easily
Posted on Jun 15, 2011
  • 11800 Answers
SOURCE: my canon mp830 is telling
In this printer, like in most Canon ones, the printhead is separated from the ink cartridge and that makes the cartridge much cheaper to manufacture. The system is designed like that: the carrier is the one that moves everything along the page - fixed to a guide rail; in the carrier is inserted the printing head assembly - secured with a large lever situated on the left of the carrier; inside the print head the ink cartridges just slot in, thru pressure. You have a user sheet with that here
http://gdlp01.c-wss.com/gds/6/0900002856/01/mp830_esi_us_v1.pdf
The error message is generated when the communication between the printing head and the motherboard is failing. The fault can be located in 3 places:
1 - at the connection between the printing head and the carrier : the head is badly inserted (it has shifted out of position) or its contacts are dirty. Remove the cartridges, disconnect the power mains, lift the lever and slide the head out then clean both sets of contacts: on the head and carriage. If this doesn't fixes it then
2 - the connection between the carrier and the mainboard - done by a ribbon cable that plugs in it. Move the carrier by hand at the middle of the printer then check the status of the cable: if it's intact (no tears or kinks) and if it's firmly plugged in. If the cable is damaged then it will have to be replaced - a visit to a repair shop will be mandatory, they are the only ones that have spares. If the cable is good then
3 - the processor no longer communicates with the buffer circuit. The only way to fix that would be by replacing the mainboard, but it's not worth it: it will be cheaper just to buy a new printer.
Posted on Aug 30, 2011
pheireith244
  • 310 Answers
SOURCE: How do I print from
To print with black follow the instruction. 1. Open your photo/documents. 2. Press Ctlr+P. 3. Select Set up. 4. Select Grayscale 5. Press print. Good luck
Posted on Sep 05, 2011
caroldon
  • 17130 Answers
SOURCE: Put new cartridges in my canon mg5250 only printing black and yellow no other colours
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer ONLY WHEN PROMPTED, to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken. Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or poor ink cartridge contacts. Sometimes the power supply unit must be checked as a poor SMPS unit can deliver low voltage and cause issues to the printer function. Check all the leads and connections of the mother board , the tags to the ink cartridge. Also check the mechanical settings of the ink cartridge , if jammed or tight remove motor and manually free the drive before it is set back.
Posted on Oct 19, 2011
Canon printer MG5250 not printing error code UO52 saying the type of print head is incorrect install the correct print head
This is a common Canon error (been going on for years)
see
http://community.usa.canon.com/t5/Printer-Multifunction-Support/Call-to-Arms-for-the-dreaded-U052-Wrong-Printhead-Error/td-p/65759
You can try removing all inks. Switch off and unplug from the wall.
Wait
Reinstall inks and switch on
(you may need to switch on first to align the print head) Switching off at the wall while the printheads are in view will leave them accessible.
Nov 27, 2016 | Canon MG5250 Printer
White Lines over Black Colour?
MAKE PRINT ALIGNMENT
IF THE PROBLEM PRESENTS
FALLOW LINK
PIXMA MG5250
May 07, 2014 | Canon MG5250 Printer
Canon mg5250
1 st u check the power of the canon mg5250 and install driver to your pc with help of driver cd
Apr 19, 2014 | Computers & Internet
My Pixma MG5250 has run out of Cyan ink, how can i continue to print with just black ink?
With the canon single ink inkjet printers it is not possible to use only the black cartridges for printing. You will have to put a new cyan cartridge into the printer to continue printing.
Mar 06, 2014 | Canon Pixma Mg5250 Imageclass Inkjet Scan...
Canon mg5250
Hi, I have Canon mg5250 and today for the first time I tried to print a document that have an image in it and it keeps printing only the top part of it!
I have two computers and tried to print with both of them and still receiving the same problem!
I would appreciate if anyone could help. Thanks
Dec 02, 2012 | Canon Office Equipment & Supplies
Wrong colors printing
Perform a nozzle check and make sure all colors are printing properly.if not perform a head clean
Oct 24, 2012 | Canon MG5250 Printer
How do I print from a canon pixmar MG5250 in black and white. NO colour?
Sep 05, 2011 | Canon MG5250 Printer
Hi, I refilled cartridge CLI-526M fromCanon Prixma MG5250 and I have the error U130. How can I resolve the error to reprint? Thanks.
FAQ: An Error Message Is Displayed on the LCD
Issue
If an error message is displayed on the LCD, take the corresponding action described below.
Cause
The following ink may have run out. Replacing the ink tank is recommended. U041 Print head is not installed.Install the print head.U051 / The type of print head is incorrect.Install the correct print head.U052 Some ink tanks are not installed in place. U072 / More than one ink tank of the following color is installed. U071 The remaining level of the following ink cannot be correctly detected. Replace the ink tank. U130 The following ink tank cannot be recognized. U043 U140 U150 The following ink has run out. Replace the ink tank. U163 There are no photos in memory card Contact the support center or service center for ink absorber replacement. Press OK to continue printing Ink absorber full. Service required Timeout error has occurred The device may be incompatible. Remove the device and check the manual supplied with the connected device An unsupported USB hub is connected. Remove the hub. B200Printer error has occurred. See the manual **** Printer error has occurred. Turn off power then back on again. If problem persists, see the manual
Jul 06, 2011 | Canon MG5250 Printer
88 people viewed this question
old marine
old marine
