Question about Hayward 3/4hp Super Pump Inground Pool Pump 115/230 Volt # Sp2605x7
Need to replace pump motor i have a new motor but i cant seperate the pump on the motor armitur
  • 131 Answers
I was having the same problem with my pool
motor, and couldn't saparate so i replace it
as unit both pump and motor,
Posted on May 08, 2009
My makita cordless drill barely turns and is smoking
If it's pulling hard then gets hot enough to smoke your problem could be in either the motor or transmission. If you can, seperate the motor from the trans and try running the motor by itself. If it spins free and strong, you have a jammed transmission causing the motor to over heat. If it still labors your problem could be with the armature bearing(s), brushes, or armature windings.
Aug 19, 2012 | Dewalt Makita Bhp452 18v Cordless 1/2"...
Cant loosen center nut on fan to seperate fan from water pump
Most fans have 4 bolts around edge where water pump and fan meet,,never knew of a center bolt...but hey find something new everyday....not saying your wrong but please check......
Aug 16, 2012 | 1998 Isuzu Hombre
I have just gone to replace motor controller on GW712 top loader washing machine but have found that the motor pump connections to be different. Old controller has 5 pin plug that does both, new...
The new motor controller board has a plastic breakout bit on the pump socket witch will give you 5 wire motor/pump.
No mod needed to wires or plugs.
Feb 17, 2012 | Fisher and Paykel Washing Machines
I neet o replace drain pump on a LG wm1832cw model
its not easy, but you'll have to lay the washer on its back and take off the crate like bottom panel. Discontect all the hoses. Disconnect the electrical line going to the pump. If you can, try and seperate the pump motor from the housing by unscrewing two screws on the housing, which will seperate the motor from the housing, If you cant get to it, I actually broke the screws on the drain filter housing to get it loose. I secured it back with the other front loading screw and some gorilla glue, shouldnt be a problem. I should at least get another 6 years out of this pump. Good luck.
May 31, 2010 | LG WM-1832C Front Load Washer
Trying to replace motor cant figure out how to remove impeller,
Might be a screw in middle of impeller with reverse thread. If so, remove. Remove back cover of motor, hold center shaft with wrench and unscrew impeller from shaft.
May 05, 2010 | Hayward 1.5hp Pool Pump Motor Motor A O...
My jigsaw stopped running. Judging from the sparks coming from around the armiture, my guess is the trouble has to do with brushes or worn armiture. The saw is not an expensive one so perhaps it's not...
Many times I clean the commutator with light sand paper and she come back to life. Take a brush out and sand the end off to clean it. Then fold a small piece of sand paper and push it down in the hole where the brush goes and rotate the motor by hand and clean the comm off. Good as new!
Sep 15, 2009 | Saws
Wiper Fluid Not Spraying
First of all-Check ALL of your Fuses. Inside the Reservoir there is a Small Pump. This is the Pump that you need to replace if no Fuses are Blown.
Jan 12, 2009 | 1999 Chevrolet Suburban
Hayward 3/4hp Super Pump Inground Pool Pump 115/230 Volt # Sp2605x7 Logo
176 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
