Question about Desa International Blower Glow Warm Wall Heater
I need Glo Warm Natural Gas heater wall mounting brackets
3 Suggested Answers
  • 188 Answers
SOURCE: gwp30t manuals
Here is a link for the manual you are requesting... http://12.153.20.74/manuals/107884-01P.PDF. If you are in need or parts or have any questions you can contact Master Parts at 800-446-1446 or you can find them on-line at www.masterparts.net. I hope this helps.
Posted on Jun 08, 2009
freetek
  • 5568 Answers
SOURCE: can I convert my natural gas glo-warm wall heater
Converting gas appliances normally entails the replacement of a jet that controls the flow of gas and in most cases, the manufacturer will (or will not) have replacement jets available. If they do, it should not be costly or difficult since they are often only screwed on.
Posted on May 14, 2010
I have a dyna glo RMC 40 NGT vent less wall heater that I would like to convert to propane, I need to know which conversion kit to buy, and where. Thank you.
dyna glo natural gas heater Questions & Answers - Fixya
www.fixya.com > Forum > Tags
dyna glo ventless rmc50 ngt can this heater be changed from natural gas to propaneuse, ... Dyna Glo Natural Gas conversion to LP Gas I have a Dyna-Glo natural gas space ... Question about D-E36 Infra-Red Wall Mounted Panel Heater ... dyna glo heater model #RMC-40GT I believe on your particular model , that you ...
Parts for Dyna Glo, Thermoheat and Dyna Glo Pro Heaters
spaceheaterparts.com/category.sc?categoryId=13
Shop Dyna Glo, Thermoheat, Dura Heat, Workhorse LP and oil fired htrs ... Circuit Board 2201181 Dyna Glo & Thermoheat 150k Nat Gas Htr RMC-FA150NGDGD ... This spark plug (ignitor) is used on Dyna Glo and Thermoheat 40K btu LP.
Propane Wall Heaters - Walmart.com
www.walmart.com > ... > Heaters
WalmartDyna-Glo IR18NMDG-1 18,000 BTU Natural Gas - Infrared Vent Free Wall Heater. $170. ... Dyna-Glo 40K Liquid Propane 360-Degree Tank Top Heater. $88.00 ... Dyna-Glo Deluxe RMC-FA125DGD Portable Gas Powered Forced Air Heater.
1352062 Dyna Glo Natural Gas conversion to LP Gas
162.220.53.34/F/.../t1352062-dyna_glo_natural_gas_conversion_lp_gas
Jan 12, 2016 | Heating & Cooling
I need a thermocouple for a dyna glo heater model #RMC-40GT
I believe on your particular model , that you have to replace the entire pilot assembly. As the thermocouple is an intricate part of it. In which case any LP or Natural Gas heater's pilot assembly will fit it. You will have to secify either Natural Gas or LP Gas when ordering.
I have provided 2 links to where you can purchase the pilot assembly you need.
http://www.mrheater.com/OrderParts2.aspx?catid=57
http://www.aandbsales.com/index.html
I hope this helps you & thanks for choosing FixYa.
Jul 29, 2011 | Dyna-Glo D-E36 Infra-Red Wall Mounted...
Can I convert my natural gas glo-warm wall heater to propane?
May 14, 2010 | Desa International Blower Glow Warm Wall...
I have a Dyna-Glo vent-less wall mounted natural gas heater model number RMI-60NG Pilot light ignites.However no gas will supply too the burners.Causing them to be inoperable.What might be the cause of...
If it is a few years old, it could be the thermocouple. These are usually available from Lowes. Take your model/serial # and if you can, take the old part too.
Dec 11, 2009 | Dyna-Glo Heating & Cooling
We have a dynna glo zero clearance for Natural Gas
Before you attempt to covert to lp. You need to check the flue. Black smoke is cause by incomplete combustion. So it may be now plug with black soot. Heat-exchanger may be damage Before you invest in a lp kit. Make sure it is worth it. To convert you need the main burner orifices and lp spring for gas value. Once you replace these parts you must adjust gas pressure, nat gas is measured at 3.2 - 3.5wc lp is measured 10.5 - 11.00 wc. In my honest opinion this is to dangerous for customer to attempt. Please a HVAC contractor inspect unit and install lp kit.
Nov 20, 2009 | Dyna-Glo D-E37 Wall Mounted Panel Heater
Dyna-glo parts
thermocouples you can buy from any heating spares oulet or national energy a hone well is most common for useing as a replacement
Feb 03, 2009 | Dyna-Glo D-E36 Infra-Red Wall Mounted...
Convert from lp to natural gas
you need to go to the manuel and check if you can retrofit the heater to natural gas. there is a difference in the ORIFICE size. or check to see if there is a phone number to the manufacture and talk to them. THE BEST THING FOR YOU TO DO IS TO GET A CERTIFIED A/C PERSON TO DO IT, IT IS VERY DANGEROUS IF YOU GET THE WRONG ORIFICE SIZE !
Jan 05, 2009 | Dyna-Glo D-E37 Wall Mounted Panel Heater
Natural Gas wall heater
It sounds like the thermocoupler is either not adjusted into the flame properly, or you may have gotten a bad one. The thermocouple is the main thing that makes the pilot work.
Dec 22, 2008 | Dyna-Glo D-E36 Infra-Red Wall Mounted...
Wall mount dyna glo model RMC-40NGT
I have the same one i am looking for the wall brackets, I lost mine. I also bought mine at a garage sale the people had it attached to the wall completely hooked up .they had no fire backer on it .They only took it off the wall when i purchased it
Nov 02, 2008 | Dyna-Glo D-E36 Infra-Red Wall Mounted...
Glo-Warm Wall Gas Wall-heater parts...
We had a problem keeping the pilot light to stay on, and this site recommended that it could possibly be the thermocoupler that was causing our problems also. We ordered the thermocouple, put it on,hooked it back up and it worked great! Thank you so much.
ordered thermocouple from www.masterparts.net
Nov 19, 2007 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Desa International Blower Glow Warm Wall Heater Logo
261 people viewed this question
Top Desa International Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Desa International Heating and Cooling Expert? Answer questions, earn points and help others
