Question about Ovens
Robertshaw rtr4-1-202812 - Ovens
GE Profile Wall Oven Circuit Board
http://www.searspartsdirect.com/partsdirect
I HAVE QUESTIONS. THIS THERE 240 VOLTS AC TO OVEN. YOU MAY HAVE A BREAKER PROBLEM. FLIP THE BREAKER BACK AND FORTH 3-5 TIMES FAST TO GET IT TO RESET. IF THE LAST THING YOU DID WAS A SELF CLEAN THEN YOU MAY HAVE A SAFETY THERMOSTAT PROBLEM. IF YOU CANNOT FIND THE WHOLE MODEL NUMBER ON THIS SITE CALL 1-800-GECARES THEY WILL HELP YOU WITH PARTS
Apr 25, 2010 | GE Profile JTP18 Electric Single Oven
Jenn Air Wall Oven W181 Thermostat
I have found the following message on GE Repair Help:
Tim
  • Refrigeraton Guru
  • Technician
xx.gif Re: W181 Oven « Reply #3 on: January 10, 2010, 03:46:04 PM » You need to measure the length of that probe. If its near 3 inches you need this one.
http://midwayparts.net/midwayparts/zen-cart-v1.3.8a-full-fileset-12112007/index.php?main_page=product_info&cPath=6&products_id=232
If its near 6 inches you will need this one.
http://midwayparts.net/midwayparts/zen-cart-v1.3.8a-full-fileset-12112007/index.php?main_page=product_info&cPath=6&products_id=233
These are replacement kits the original is no longer available. « Last Edit: January 14, 2010, 09:26:32 AM by Tim » I have already ordered the part and hope it will work. Best regards, Miro Bogavcic
Jan 31, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
We have a Caloric Ultra-Ray wall oven from 1965 or earlier, Model number unknown. I need a safety valve with attached thermocouple, part number ''Z7800012'', made by ''ROBERTSHAW'' in Youngwood PA. Where...
try hollywood stoves . or try appl parts depot use part # 4060-901 this is a safty valve with 7/16/tubing with 2/8 adapter / 15 in cap tube .. it is very close to majic and caloric .. you can look at 6 different valves online www.apdepot.com .. hope ths wll help mm
Nov 24, 2009 | Ovens
The ignitor in our oven is no longer being made the replacement is a robertshaw 41-208 how do i put a square peg in a round hole
There should be a bracket with the new ignitor. There are also universal ignitors of the same type as the old one that can be made to work.
Eric
Sep 14, 2009 | Ovens
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
