Question about Taylor 2008 C713-27 Soft Serve Ice Cream Yogurt Machine, 2 Flavor
PH-84 TAYLOR FREEZER LOCKED - Taylor 2008 C713-27 Soft Serve Ice Cream Yogurt Machine, 2 Flavor
I have a C712 taylor soft serve and we have one side somehow mixing in to the other ??? how is this happening ???
The separate flavors only meet at the center draw valve of the freezer door. That valve should have an H-type seal that looks like 2 connected o rings. If you haven't replaced this seal 034698 Large Basket Seal, it could be the problem. You can buy the seal individually or as part of a kit.
You can also try to make sure that the viscosity of the product is even, you don't want one side to be noticeably softer than the other.
The other possibility is there is a problem with the mix pumps. First try replacing all of the seals and gaskets. Use this kit X49463 81Tune up kit for Taylor C712. The pump parts do wear out over time including the stainless steel cylinder sleeve. If one pump was working better than the other, that could explain the mix bleeding.
If none of that takes care of the problem let me know. tex@softserveparts.com
Jun 17, 2017 | Taylor Ice Cream Makers
Any maintenance issues on a taylor 430 frozen drink machine
The Taylor 430 is a solid machine. The only maintenance you need to worry about are:
1. Cleaning - Follow the instructions. Supplies are here.
2. Replace wear parts - Scraper Blades and Tune-up kit
The next most purchased part for that machine is the freezer door, but the good news is the new replacement is much stronger than the old ones.
Soft Serve Parts 430
May 12, 2017 | Taylor Ice Cream Makers
My C713 water cooled yogurt machine keeps locking and only works when cleaned but only for a few hours then it locks again. Does anyone know why?
The temperature of the product is too high. If the product either in the cylinders or the hopper goes above safe temperature for too long the freezer will lock until the product is removed and the unit is properly cleaned. I would guess it's the hopper temperature because I think you would notice if the product that's dispensed is above 40 degrees. Soft Serve Parts C713
Aug 01, 2016 | Taylor 2008 C713-27 Soft Serve Ice Cream...
Taylor 794 machine won't freeze yogurt
Try these sites:
http://www.taylorproducts.net/Inside/FAQ.aspx
The thermostat has gone bad or the refrigerant charge is low...check the thermostat to make sure that it is calling for the refrigeration system to run, make sure power is getting to the compressor and then make sure the compressor is cooling properly...
If compressor is running them the t-stat is okay and there is a problem there....is it is cycling on and off then the t-stat is bad.....
if it is running continuously then you probably have a refrigerant leak...it needs to be found, fixed, and the system recharged...
Jan 22, 2013 | Taylor Ice Cream Makers
Can someone tell me where the viscosity adustment switch is on a taylor slush freezer model 355?
you have to brixe the unit first but need a special tool and you can set the viscosity on the display but you have to have the unit running properly and not use sugar free or diet products
Jun 29, 2011 | Taylor 632-33 Ice Cream Maker
Taylor ice cream maker single serve
You can't. Taylor won't send you one unless you are a foactory trained technician. Sorry
Oct 19, 2008 | Taylor 632-33 Ice Cream Maker
Taylor 2008 C713-27 Soft Serve Ice Cream Yogurt Machine, 2 Flavor Logo
104 people viewed this question
Top Taylor Ice Cream Makers Experts
Dennis Boxerman
J.D. Browning
J.D. Browning
Andrew Taylor
Andrew Taylor
Are you a Taylor Ice Cream Maker Expert? Answer questions, earn points and help others
