Question about Music Bullet Mublt12 Kickin Mini Speaker For Ipod Iphone Mp3 Laptop Seen On Tv
Music Bullet earphone wire is not retracting correctly, how do i fix this problem
How do i fix the sound on my music bullet?
There may be a problem with the rechargeable power supply.
Jul 18, 2014 | Music Bullet Rechargeable Universal Mini...
Have my earphones on but can not hear music
You could try using your earphones with another device to see if they are working properly. For example, I think my earphones have a broken wire in them because when the earphone plug revolves up or down in the jack the sound cuts out. When I turn the plug around a little, the sound comes back. (I am sure you had the volume turned up :)
Jul 09, 2014 | SanDisk Sansa Clip MP3 Player
I got a psp 3000 and I just downloaded music on it and when I plugged in my headphones and play it all I can hear is the music and hardly the singer. How do I fix this?
Try a different set of headphones. It's possible that the headphones have a short and you're only getting sound out of one ear. If it's still doing it with another set of headphones, then it's either a bad headphone connector or the music files are corrupted or not recorded properly.
Mar 02, 2011 | Video Game Consoles & Games
Whenever i plug my earphones into my mp3 player I cannot hear my music through the earphones. any idea what the issue could be?
The wire inside the earphones Tore. If these earphones came with the Player then they are probably not very strong earphones. Usually the name brand ones are more durable. I believe it is time for you to buy some new earphones.
Dec 29, 2010 | Philips GOGEAR SA6045 MP3 Player
Why did my left earbud become silent?
you can make both of the earbuds work. You can open the earbud where the speaker is that you use to hear the musik. Use a soldering iron and a lead. check if the wire inside has removed, fix it back and you will hear sound on both earbuds.
Take care.
Jun 01, 2010 | Sony EX33LPS Headphones
Wire disconnect from left earphones
Time for some ingenuity.Disassemble the housing to get to the wire connections.The solder pads where the wires go are usually marked + or minus(-). The white/colored wire(signal) goes on the + side.This could be a red dot. The other wire (black) goes on the other pad(-). These wires are so fine they sometimes use nylon thread to give it a lil strength.Good Luck! dnbbgy
May 30, 2010 | Bose TriPort Consumer Headphones
Earphones wont work on dell computer/vistas have to restart computer to go from sound to earphones . how do i fix this
first check you connected the earphone properly. earphone has two wire. connect earphone green wire where you connect the speaker.
Jan 22, 2010 | Dell Inspiron 531s Desktop Computer
Instructions needed
you can buy regular head phones (not earbuds, those are the annoying things you stivk in your ear) some clip on, some have retractable wires, some are just normal. you can buy these at any electronics store.
Apr 06, 2009 | Creative Labs Zen V MP3 Player
When I put my earbuds into my ipod touch only one side works
i have the same problem. its not the headphones. its the itouch. its something to do with the jack-i think. because whenever i jiggle the plug eventually i can hear some of my music eventually. its a pain. and so how do i fix that ish?
Feb 14, 2009 | Apple iPod touch
Mp4 ear phones
hi the problem will be with the earphones after a bit of use the wires inside the plastic casing covering the wires where they plug into the mp4 these wires fray and eventually short out it is best to replace the earphones as soon as possible as shorting out will eventually cause the mp4 to overheat and short out.
If you have replaced the earphones and are still getting the same problem then it will be the solder points on the jack plug that you plug the earphones into the solder eventually will work lose causing bad connection but first repalce earphones then if you still have the problem but you probanly wont as the solder failing isnt a known problem with this product then you will need to take the cases off and get to the board where the earphone socket is soldered onto the board then you need to resolder the solder joint that connect it to the board.
But first repalce earphone with new ones as using someone elses or old ones might have same problem let me know if you need further assistance
Jan 16, 2008 | Konaki MP4-NS MP3 Player
Music Bullet Mublt12 Kickin Mini Speaker For Ipod Iphone Mp3 Laptop Seen On Tv Logo
16 people viewed this question
Top Music Bullet Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Music Bullet Audio Player and Recorder Expert? Answer questions, earn points and help others
