Question about Panasonic Televison & Video
My panasonic sa dm3 is saying it is locked so can not open the tray It plays the disc in there. How do I unlock?
mjap
  • 107 Answers
SOURCE: cannot open the disc tray
I see if thats the problem, the memory IC was been shocked by voltage caused by a capacitor, all I can say is to open your cd/dvd and unplug the memory IC and try to put it back, ussually its a 8 pin IC, I have a problem same as this before from a custumer but its a tv reciever.
Posted on Jan 13, 2008
  • 47 Answers
SOURCE: Locked DVD Tray
I'm pretty sure the force disk eject is the same across all Panasonic models - however I couldn't find anything specific for your model number. Still worth a shot, though.
With the unit in standby, press and hold the 'Stop' and 'Ch up' buttons together. It should power up and force the tray open. If this doesn't work, try changing up your timing by pressing and holding 'Stop' first, then a half-second later, press and hold 'Ch up' and keep them both held together. You can also try the opposite.
If none of these work, it will have to be taken apart to get the disc out. If you aren't comfortable trying, it will have to go to service.
Posted on Mar 09, 2008
  • 44 Answers
SOURCE: Just ot a universal remote
http://www.universal-remote.net/panasonic.html If they dont have it do a search on your comp for "panasonic dvd codes for universal remote" or something to that effect
Posted on Apr 16, 2008
  • 13 Answers
SOURCE: does not play dvd disc or music disc
I had this same problem with my Apex AD-500W DVD Player. I decided since everyone said the player basically needed to be replaced it wouldn't hurt to go through the buttons on the remote just to try and figure it out......I DID!!!! I turned on my DVD Player, inserted a disc, turned on my tv and then hit the SYSTEM Button right below the power button until the screen said MULTI and the machine started working perfectly. There are 3 settings in that button, PAL which made my screen go crazy, NTSC ( i have no clue) and MULTI(this one made it work)! Hope it also works for all of you!!!
Posted on May 16, 2008
ravichetty
  • 158 Answers
SOURCE: i have a panasonic
laser poss faulty.get it replaced
Posted on Jul 20, 2009
CD function not working on Panasonic SA-HE70 receiver
when you say its not working what do you mean by that?
its got no power.
the tray wont open.
tray trying to open but wont.
or just wont play cd.
if none of the above could you please give me more info please.
Nov 08, 2016 | Panasonic SA-HE70 Receiver
Panasonic dvd home theatre system SA-HT520. My 2 year old was playing with buttons on dvd player and now when i press open/close button it is saying locked and won't open, is there anything i can try...
The system has a locked / unlocked toggle sequence on the main unit by holding down stop (or Play) and then tapping the power button. Use this sequence lock or unlock the DVD / CD drawer.
Sep 29, 2011 | Panasonic Home Theater System System
Panasonic sa-dm3, says setting error, change setting and the turns off. what can i do?
It is always wise to tell us if this is new equipment or a spontaneous failure on previously functioning equipment. I'm guessing this the former.
For starters you could look at the manual.
http://www.retrevo.com/support/Panasonic-SA-DM3-Home-Theater-Systems-manual/id/312ci674/t/2/
See page 5. >>>>>>>>>>>>>>> STEP 1 <<<<<<<<<<<<<<< - Orienting the unit and attach the feet.
Its physical orientation is wrong, possibly upside down.
Sep 03, 2011 | Panasonic SC-DM3 System
Panasonic SA-PT460 disc tray keeps opening. When system switched on disc tray opens, then closes and then opens and stays open. can't play a disc.
SA-PT460
Original fault tray would not stay closed,opened up 460 case and then removed 2 screws on rear of drive. unplug 2 ribbon cables.
unscrew 1 screw in micro switch pcb rotate and spay cleaner into switch and rock switch several times until the reading across switch is 0 ohms before you start you will find the switch has about 2.5 k of resistance across it witch is too high.
as long as you have about 4ohms it will work.
Aug 14, 2011 | Audio Players & Recorders
I have a Panasonic SA-PT250 surround dvd player. It plays most formats, but often displays "Error" and "Can not play Disc" although the same disc plays on a friend's dvd player. My...
some branchs are locked for some regions, and dvd movies are open forr all regions.
try to unlock your dvd and the problem will be solved.
look in the internet how to unlock your panasonic dvd, its easy.
Feb 14, 2011 | Panasonic Televison & Video
Panasonic SA-HT520 error message
Sep 20, 2008 | Panasonic SC-HT520 System
Hi folks!!!
Might be cheaper to pick-up a sub-woofer and a set of speakers at the local store. I checked e-bay..no luck, and it doesn't look like Panasonic will sell separates. It will be easy to get a color match.
Mar 20, 2008 | Panasonic SC-DM3 System
Panasonic home theater
take it apart via the screws on the side and back and then there is a white lever you can pull to unlock it. make sure you are wearing shoes because you dont wanna short the system
Sep 09, 2007 | Panasonic sa-ht930 Home Theater Audio...
LOCKED displays when attempting to eject disk from SA-HT670
i have a panasonic SA-HT720 and it displayed locked anytime i wanted to eject discs so i found out that dad27's solution was the best and holding down the stop and power buttons also locks the system as well as unlocking it. God richly bless u dad27 u really helped me out
Jul 27, 2007 | Panasonic SC-HT670 System
Televison & Video Logo
136 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
