Question about RTO Mini Quads
Changing the oil
Hey mate, just bought my daughter a 49cc quad. not sure how to drain/change the oil. cheers
You don't half to change the oil it takes a oil fuel mixture like a chainsaw or a weed-eater
Posted on Jun 08, 2009
Tourke settings moto 200
Exhaust manifold nuts 10-14Nm
Exhaust mounting bolts 30-14Nm
Engine mounting nuts 45-50Nm
Oil drain bolt 11-15Nm
Oil filter screen cap 10-20 Nm
Spark plug 10 -14Nm
Crank case bolts 8-12Nm
Cylinder head bolts / nuts 18Nm-22Nm
Variator center nut 35-40 Nm 49cc gy6 149cc gy6 40-60NM
Clutch assembly nut for spring 50-60Nm 49cc gy6
Clutch center nut 35-40Nm 49cc gy6 1 49cc gy6 40-60NM
Gear box drain and fill bolt 9-15Nm 49cc -149cc gy6
Fan bolts 9Nm 49cc -149cc gy6
Valve lash adjusting nut 7 Ft Lbs
Standard Torque Setings
M5-Bolt or Nut--5Nm
M6-Bolt or Nut--10Nm
M8Bolt or Nut--21.5Nm
M10Bolt or Nut 35Nm
M12Bolt or Nut 55Mm
M6Bolt or Nut flanged head 12Mn
M8Bolt or Nut flanged head 27Nm
M10Bolt or Nut flanged head 40Nm
Jan 13, 2018 | Cell Phones
Scooter 49cc
well this scooter has a 2 stroke engine (meaning it mixes oil and gas) so it would need any kind of 2-stroke oil, it is always recommended to NOT buy the cheapest oil and rather to spend a little more on an oil brand that works better.
Aug 27, 2013 | Yamaha Motorcycles
Hi,i own a dinli t-rex dl-601 100cc atv quad bike and i recently changed the v-belt,cleaned the carb,wahed filters,drained and changed engine oil,drained and changed petrol,drained and changed 2 stroke,...
I think you might want to change catagories, I found this under Bicycles. Also, I was curious as to how you can list it as a Quad Bike . . . Bike is a short term for Bicycle, Bi meaning 2 as in 2 wheels.
Nov 21, 2010 | Quad 47 cc / 49 cc Pocket Mini Bike...
I'M TRYING TO CHANGE THE TRANSMISSION OIL AND CAN'T FIND THE DRAIN PLUG. CAN YOU HELP? Also a went to a bike shop who sold me gear oil GL-5 80/90W. It doesn't look or smell the same. Can you tell me if...
I don't know about the Hyosung, but most motorcycles, motor oil is the tranny oil, same thing. To drain the tranny, you drain the engine. My bike has a dry clutch, so it doesn't have any gear oil. But my Harley was different, it had 90 weight in the gear box and also had a dripper on the chain that would drop motor oil on the chain every couple minutes. Most people never change the gear oil. Most cars go for life without changing it. If you had a shaft drive rear end, it would be full of gear oil, Check it out. Hope this helps.
Aug 01, 2010 | Hyosung RX 125 Motorcycles
My 49cc quad bike is new wont start have changed the coil and plug but no spark tried diconnecting the kill switch
Maybe re-check the gap between the coil and the flywheel? x2 business cards is a good gap for those.
May 12, 2010 | RTO Mini Quads
Hey ppl ive bought this bike a ktm 125 sx 2002 from a guy .he sold it me prety cheap as it`s had pre mixed oil mx5 syth.put in the gear /transmition/part of the bike . the bike is spiting oil out of the...
In other words, you want to flush the theold out?
Drain the old, fill to proper level with20 weight oil and run it for five minutes then drain. Watch your oil pressure. Anything of the old still in there won't hurt a thing and will get dumped on next change. Oil cming out the exhsust is a two cycle thing and will exist if the mix is to much on the oil side.
Nov 11, 2009 | 2002 KTM SX 125
Gio mini quad 49cc no governer won't idle up
change the CDI unite it in the battery case.( price around 35 to 80 bucks )
Jul 18, 2009 | Quad Cycling
Clutch appears to be slipping
hey dude u gotta change ur clutch plate mannnn.....
Jul 03, 2009 | kawasaki Quad Bikes
49cc 2 stroke runs for 20 sec. then cuts out
20 seconds is all that is required to drain the float bowl. You have a float bowl/needle valve problem.
Apr 24, 2009 | Fender 2 Stroke Full 49cc ATV # ATG-47B...
RTO Mini Quads Logo
403 people viewed this question
Top RTO Toys Experts
The Scrivener
Pete Bruk
rostit
Are you a RTO Toy Expert? Answer questions, earn points and help others
