Question about Allegro DVD/VCR ABV511
I need the proceedure for programing tv with the remote and list of tv codes the remote model number is 6711r1p072j
I have a allegro abv 411 dvd vcr combo and the remot is 6711r1p072j and i need the tv code list and procedure to program tv
3 Suggested Answers
SOURCE: code for remote control
Sorry to tell you, but I have been looking for ages as well (I dont think we will find anything) you can try using other similar codes as they sometimes work
Posted on Aug 25, 2008
  • 49 Answers
SOURCE: Comcast Digital Conversion box (cable TV)
You will have to split the signal before it goes into the digital box. The digital box is not allowing the analog signal to go to your vcr so you will only be able to record what you are watching on the cable box (on channel 4). If you split it, you will get all your analog channels back on your VCR (the way it was before the box was added).
Posted on Jun 29, 2009
What is the code for my sony tv remote control DVD VCR COMBO
Ray, Check the attached links,remote codes.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Sony eSupport Remote Control Codes Programming Select Model
New 3 digit codes for DVD VCR DVR SAT TV VCR TV DVD DVR CABLE and DVR DVD...
https://www.att.com/support_media/images/pdf/uverse/set-up-code-list.pdf
Mar 08, 2016 | Sony Televison & Video
I Need A Remote Code For An Emerson EWC19T5 and One For All URC 4021 remote
Hello
Setup codes for Emerson Tv with One For All URC-4021 remote control are:
0154, 0236, 0463, 0180, 0178,
0171, 0623
The One For All 4 Device Universal Remote Control is preprogrammed at
the factory to operate an RCA TV, a Toshiba DVD player, a Motorola cable
box, and an RCA VCR.To control devices other than the default brands,perform
the following steps; otherwise skip this section:
[1] Turn on a desired device (e.g.,VCR or DVD player) and, if
applicable, insert media (e.g., cassette or disc).
NOTE: Please read steps 2 through 4 completely before proceeding.
Highlight or write down the codes and device you wish to program
before starting step 2.
[2] On the remote control,press a device key once (i.e., VCR/PVR,
DVD, CBL/SAT,or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo,
or TV/VCR/DVD Player Combo press VCR/PVR once.After programming
a VCR Combo device, you will be able to control channel selection,
volume, and VCR functions.
NOTE: To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD once.After programming
a DVD Combo device, you will be able to control channel selection,
volume, and DVD functions.
NOTE: To program control of a Cable Box, Cable Box/PVR (or DVR)
Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR)
Combo, press CBL/SAT once.
[3] Press and hold SET until the LED (red light) blinks twice,
then release SET.
[4] Use the Manufacturer's Codes (starting on page 18) to
locate the type of device and brand name and then enter
the first four-digit code for your device. If performed correctly,
the LED will blink twice.
NOTE: If the LED did not blink twice, repeat steps 2 through 4 and enter
the same code again.
[5] Aim the remote control at the device and press POWER
once.The device should turn off. If it does not, repeat
steps 2 through 5, trying each code for your brand until
you find one that works. If it still doesn't work, try
Searching For Your Code on next
NOTE: If the device does not have a POWER key, press PLAY
OK.
Sep 26, 2011 | One For All URC-3021 Remote Control
I need to know how to program a RCA universal remote RCU404N
Hello
Programming method for your remote control follows:-
In order for the 4 component universal remote to control your DVD player or auxiliary component, you must program it with the code that matches your component. The DVD•AUX key can be programmed to operate a DVD player or a second TV, VCR, DBS or cable box. These instructions explain the preferred method of programming the remote-the Direct Entry method.
1. Manually turn on the component you wish to assign to the DVD•AUX key (TV, VCR, DVD, DBS System or cable box).
2. Locate the enclosed DVD code list, or the
corresponding code list for the auxiliary component (TV, VCR, DBS, or cable box).
Note: If your brand isn't listed, use one of the Code Search methods to program this remote control (See Code Search on page 9).
3. Press and hold the CODE SEARCH key until the INDICATOR LIGHT illuminates, then release the CODE SEARCH key.
4. Press and release the DVD•AUX key. The INDICATOR LIGHT will blink.
5. To program for DVD, press the VCR key. For an auxiliary component, press the corresponding component key (TV, VCR, DBS•CABLE). The INDICATOR LIGHT will blink again, then remain lit.
6. Use the number keys on the remote to enter the first code listed for your brand. After you enter a valid three-digit code, the indicator light turns off.
Note: If you enter an invalid code, the LED will flash rapidly for 2 seconds. Start over at step 3.
7. Aim the remote at your component and press the ON•OFF key. If your component turns off, you have found the correct code.
8. Enter the code in the box provided on this page for future reference.
9. If your component doesn't turn off, repeat steps 3-7 above, entering the next code for your brand. If none of the codes work or your brand is not listed, use one of the Code Search methods to program this remote (See Code Search on page 9).
Mar 18, 2011 | RCA Televison & Video
I have an Allegro DVD/VCR Moel ABV511. I have an RCE Universal Remote and the code it offers for Allegro DVD/VCR players doesn't work in setting up the remote to control the player. Their code is 5...
There is not really a true 'universal remote.' If the remote is of older design than the set you wish to control, it will not contain the code set you need.
Before you buy another, check the mfr's website for code sets for any given model remote to ensure you aren't buying another one which will end up in a drawer. Unfortunately, this is a very common problem.
Jan 09, 2011 | Allegro ABV511
I need a remote code for a emerson lcd lc195em82
1. Manually turn on the component you want the remote to
control (TV, VCR, DVD, satellite receiver or cable box).
Note: If you press an invalid key during the Auto Code
Search, the remote does not respond and the illuminated
ON•OFF key does not blink. If you do not press a valid
Auto Code Search key (TV, VCR•DVD, SAT•CBL, ON•OFF,
GO BACK, PLAY, REVERSE, STOP), the search times out
after two minutes. When the search times out, the illuminated
ON•OFF key blinks four times and turns off. The last
programmed code under that component key is retained.
2. If you are programming your TV or satellite receiver, go
directly to step 4.
3. To program the remote to control a VCR or DVD. The
VCR•DVD key can control only one component, either your
VCR or your DVD. To program your remote to control
either your DVD or your VCR, you must first put the
remote in the proper programming mode. Follow these
directions before proceeding to step 4.
a. Press and hold the VCR•DVD key.
The illuminated ON•OFF key
turns on.
b.While holding down the
VCR•DVD key, press and release
the number 2 key on the keypad to
control a VCR or the number 3 key
to control a DVD. The illuminated
ON•OFF key blinks, and then turns
back on.
c.Release the VCR•DVD key.
blinks four times and then turns
off. Your remote is now either in
VCR or DVD Programming Mode,
depending on which you chose.
Proceed to step 4.
4. Press and hold the component key
(TV, VCR•DVD, SAT•CBL) you wish
to program. The illuminated ON•OFF
key turns on and remains on.
5. While holding the component key
down, press and hold the ON•OFF
key. The illuminated ON•OFF key
turns off.
6. After holding down both keys for
three seconds, the illuminated
ON•OFF key turns back on.
7. Release both keys. The illuminated
ON•OFF key remains on.
VCR•DVD
VCR•DVD
VCR•DVD
ON•OFF
(BLINK)
ON•OFF
(BLINK)
ON•OFF
ON•OFF
(BLINK)
SAT•CBL
VCR•DVD
TV
TIP: Throughout the programming of each key, be sure to
keep the remote pointed at the IR sensor of the component you
are currently programming the remote to control.
8. Press and release the PLAY key,
then wait five seconds to see if
your component turns off. If your
component does not respond,
continue to press the PLAY key
every five seconds until your
component turns off. Each time you
press the PLAY key, the illuminated
ON•OFF key blinks and a block of
10 codes are sent to your component.
This process continues until all of
the codes in the Code Lists have
been searched. (If your component
has not turned off after all codes have
been searched, the illuminated
turns off. The Auto Code Search
Entry method is exited.)
PLAY
ON•OFF
(BLINK)
10
11. To confirm that the component key is programmed with the
correct code for maximum functionality, test the component.
Attempt to control a variety of the component’s functions
with the remote. If some of the features of your components
do not work, try programming the remote with a different
code in the list until you find the code that allows the remote
to control the majority of your component’s functions.
Different codes can provide different levels of functionality.
Mar 26, 2009 | Televison & Video
I have a allegro Model MBC 300 P TV VCR remote need codes
i have RC NEWSTAR 96-8828 universal and i need code for SuperMax 1000 sat resiver
Jan 07, 2009 | Televison & Video
Programming remote
Code Numbers for TV
Lg/golstar..................1 or 2
Zenith.........................1 or 2 or 3
Samsung..................6 or 7
Sony...........................8 or 9
Hitachi........................4
Hold down "TV POWER BUTTON"....while holding hold button press above number for your TV.
Aug 11, 2008 | Allegro DVD/VCR ABV511
Programming remote for Zenith DVB412 DVD Player
Here is the response from LG/Zenith customer support:
Unfortunately, this remote has very limited programmability. The manual is correct.
INSTRUCTIONS: Controlling other TVs with the remote You can control the sound level, input source, and power switch of non-LG TVs as well. If your TV is listed in the table below, set the appropriate manufacturer code.
  1. While holding down TV POWER button, press the number buttons to select the manufacturer code for your TV (see the table).
  2. Release TV POWER button. Code numbers of controllable TVs If more than one code number is listed, try entering them one at a time until you find the one that works with your TV.
Manufacturer Code Number
LG/GoldStar 1 (Default), 2
Zenith 1, 3, 4
Samsung 6, 7
Sony 8, 9
Hitachi 4
For further information or troubleshooting, you may contact us at 800-243-0000 for LG Customer Service assistance. An agent will be glad to assist you. Please feel free to contact us with any additional questions or concerns. Thank you again for contacting LG Electronics.
Jun 30, 2006 | Zenith DVB412 DVD Player
Televison & Video Logo
318 people viewed this question
Top Allegro Televison & Video Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Repairing
Computer Repairing
ray gallant
Are you an Allegro Televison and Video Expert? Answer questions, earn points and help others
