Question about Dishwashers
Renlig dw45 My dishwasher leaks at the door ,I am trying to find a door seal to fit but cannot get appropriate model number ?
  • 90 Answers
SOURCE: Whirlpool DU1100XTPS dishwasher leaking from front door panel
are there soap suds coming out of the door?
Posted on Jan 06, 2008
skrbin
  • 121 Answers
SOURCE: leaking lower door seal on kitchenaid dishwasher model KUDM25SHWH
check door hinge.
Posted on Feb 15, 2009
SOURCE: dishwasher leaking around the bottom of the door
I had the same problem in 2004, lots of Bosch trained repair techs, calls to Bosch, and the appliance dealer we purchased it from with no answers. Our kitchen cabinet bases were ruined by the flooding that occured. After months of trying to get help I insisted on speaking to a supervisor that told me it was my fault for putting a flexible cutting board on the right side a blocking the vent. I told her that no where in the manual did it mention this issue and none of their trained techs were aware of this flaw in their design. When I asked about getting my cabinets repaired she said that was not an option. When I mentioned possible legal action her response was "good luck with that". Here it is 2009 and they recently called about a possible fire hazard recall for the control panel. The Bosch trained tech that came out to complete the repair knew nothing about the vent/flooding issue.
Posted on Aug 06, 2009
SOURCE: Replacing LG Dishwasher door gasket/seal with Part # 3920DD3005A
Problem solved - it was not the gasket - it was the vent tube as defined in one of your on-line reported solutions. Thank you!!!
Posted on Oct 14, 2009
Testimonial: "Contacted numerous resources to try identify LG dishwasher leak problem, including LG. Found solution,vent tube right here on FixYa. Many thanks!!!!"
SOURCE: Replace bottom door seal on Dishlex Global 300 Dishwasher - Model DX300SA
HI - i just replaced the bottom seal yesterday. The guy at the spares shop advised me to replace both (bottom of door and bigger seal ) at the same time to ensure no leaks - i did that. The bottom door seal come out when you unscrew the screws - (No need to remove door) and because of all the gunk (from years of washing and age of the rubber) i had to wedge a blunt knife in between (starting at one of the ends) and lever it out - MAKE SURE YOU TAKE NOTE OF THE WAY IT IS BEFORE YOU REMOVE IT! An easy way to remember is there is a nick in the rubber of the old (and new) seal and as it is not centred, just note if the nick is closer to the left or right of the machine, I have replaced mine and there is a little leak and now i wonder if i put the seal in upside down! it has to go in the same way - before you gimmy your's out can you tell me if the nick in the rubber is to the left or right? (LIZ at yodelayeeoo@gmail.com) If I have put in back right there is a chance the screw didn't go through the plastic part of the seal and therefore not holding it in place properly. GOOD LUCK! Don't worry about having to really work at getting the old seal out - you don't need it anymore and i didn't damage mine, regards, Liz
Posted on May 27, 2010
Renlig dw45 the washing machine keeps trying to drain even though it is empty please help
Yup. I have an IKEA Renlig DW45 and this cured the problem (the dishwasher would not stop draining).
Thank you so much for taking the time to detail it here for us.
Jan 20, 2014 | Dishwashers
Leaking from motor
Water Inlet Valve
If the dishwasher is leaking water the water inlet valve might be defective. If the water inlet valve sticks open, it will allow water to fill the dishwasher continuously. Some customers report that they see clean water filling the bottom of the dishwasher after it's been sitting all night or for a couple of days. If this happens, turn off the water that is supplying the dishwasher. This is normally a valve under the kitchen sink. Then, replace the water inlet valve, it cannot be repaired. The water valve needs at least 20 lbs pressure to shut off properly. If your water pressure is to low replacing the valve may not solve the problem.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Center Wash Arm Assembly
If the dishwasher is leaking water, the center wash arm assembly might be cracked or split. This can allow a jet of water to spray toward the door seal, causing a leak. If a crack or split in the center wash arm assembly is found, replace it. There isn't any glue that will hold the part together inside the dishwasher.
Lower Wash Arm Assembly
If the dishwasher is leaking water the lower wash arm assembly might be defective. If the lower wash arm has a crack or split on the end, it can force water to spray directly toward the lower part of the dishwasher door. Then, the water can be forced under the door and onto the floor. Check the lower wash arm for any cracks or splits and replace it if necessary. Also make sure the screws are tight in the wash arm support. If the screws are loose, water can spray out the side of the pump and cause a leak.
Upper Wash Arm Assembly
If the upper wash arm assembly is broken or cracked it can cause water to spray very forcefully toward the seams of the door, causing a leak.
Door Seal
Every dishwasher door has a door seal. If the dishwasher is leaking water, it might be that the door seal is defective or worn out. Try closing the dishwasher door on a dollar bill and see if the door seal is making good contact all the way around the door. If not, replace the door seal. If the door seal is good or has been replaced and there is still a leak check the door hinges. If the hinges are bent the door will not close properly and the hinges will need to be replaced.
Dishwasher Door Gasket
God bless youc9c8c0e9-8a93-431d-b16a-9b8d97f35d28.gif14b36f01-1d58-4f2a-8f54-fc14feec17e3.jpg
May 23, 2013 | KitchenAid Dishwashers
Leaking from top
follow the next step, for test. God bless you
Water Inlet Valve
Door Seal
Apr 05, 2013 | Whirlpool Dishwashers
My dishwasher from ikea renlig dw 60, is 6 month old and now the light to select the programs stay red all the time and pressing the selection button doesnt do anything. Thanks for your help
Similar just happened to us. Turned power off, waited a while, opened door. pressed and held power on button then pressed and held also the select button. Brought it back to life. End leds lit up and i could then select and worked when i shut the door. Ours is a smaller Renlig. Good luck.
May 27, 2011 | Dishwashers
Our Hotpoint Aquarius Dishwasher BF11, built into the kitchen units is leaking steam from the door ( and starting to cause the wooden floor to bend ). Can I get a door seal for this model ? It's probably...
you gotta send the full model number,open the door and look at the very front of dw where the door closes into the machine,usually the tag is on the left side at 9 oclock,first are you positive that's where it's leaking remove the bottom kick panel and see if the motor or anything isn't leaking there too.if it is the door gasket it's an easy fix
Oct 07, 2017 | Hotpoint Dishwashers
Dishwasher door leaking
You probably need to replace the door seal part number 902894.
Jan 31, 2010 | Dishwashers
Frigidaire dishwashers FDB2810LDC0 bottom of door leaking where do I find a new seal?
You can obtain a new seal through an appliance parts store. You will need the make and model number of your dishwasher to get the correct seal.
Oct 03, 2009 | Frigidaire 24 in. FDB126RB Built-in...
Dishwasher leaks, is there a recall on this model,mdb7100awb
if the dishwasher is leaking water there is no recall on that. the recall i believe you are talking about would be for the rinse aide leaking in the door. you should contact maytag to see about getting the new kit installed on your dishwasher and you may get your leak fixed for free since the kit comes with the door seal.
You can contact maytag at (800) 675-0535 do not wait and do not use the dishwasher. you will need the model number and serial number off your machine when you call. it is located near the door seal on the tub.
Jan 03, 2009 | Maytag MDB7100AWB Dishwasher
Dishwashers Logo
193 people viewed this question
Top Dishwashers Experts
