Question about Olympus Vr-340 16mp Camera Digital Optical Zoom With 10x
Camera will not turn on..
Camera powers on and lens retract for a second then powers off.
  • 11967 Answers
SOURCE: When I turn the camera on, the lens extends, makes
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous interiors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particles that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Apr 21, 2011
SOURCE: When I turn the camera on it makes a few noises then shut off
i called the company (1-888-553-4448) olympusamerica.com and they told me to send it in and they will repair it for 70.95 plus a 6months warranty because i cant find my reciept. they also said what eva is wrong with it they will be able to repair it, but if u have ur warranty u can send it to them it wont cost u anything because u have ur reciept.
Posted on Mar 23, 2009
  • 495 Answers
SOURCE: Zoom lens is stuck out position...won't retract.
Lens errors are quite common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended or the camera has been powered on, but the lens had been blocked preventing its extension.
You can try the following:
1. Try compressed air. With a fine tip blow off gun and dry compressed air (20 lbs) set the tip between the lens turret and the camera body and turn on the air while moving the tip around the lens. It should remove all dust and sand. Turn the camera on and it should function fine.
2. Place the camera on it's back and look at the lens from its side. It may look slightly crooked. If this is the case, power up your camera and apply pressure gently to the side of the lens to center it. It should then extend fully.
3. [Try at your own risk] Try forcing the camera lens. Turn off the camera. Place it on the back with the lens facing up and take a look at the spacing between the lens and the lens housing. If you notice that the gap is not even all the way around the lens, the problem should be easy to fix. This type of a problem usually occurs if the camera was dropped while the lens was extended. Simply - VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a click as it pops back into place. If the lens is stuck at an angle, put the edge of the lens not the flat front, on the edge of a table and press the lens back towards the center. It will either click back in place and work or it will break off one of the three pins that ride in the grooves of the lens barrel. Try powering the camera back on.
Alternatively, take a look here for some more tips! http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Feb 06, 2011
t00nz
  • 4738 Answers
SOURCE: Olympus X-920 camera lens fails
Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
Posted on Jul 02, 2011
  • 11967 Answers
SOURCE: How can i fix my
Posted on Sep 11, 2011
The camera will not turn off and the lens is not fully retracted
from your question I understand there may be problems in the lens unit, in some cases totally open the lens unit fully re assemble it again,clean the sensors at side of the barrels, can override this snags.
the below picture is not the same, but similarly you take the cam sect out and reassemble it.
Mar 20, 2016 | Sony Cyber-shot DSC-H300 Digita Camera -...
Kodak easyshare Z650 lens extends and retracts
I only can think of two reasons. The first, the battery does not have enough power. As a safety precaution it shuts itself down, to avoid damage to the saved pictures. Because if the voltage is to low, it can't write with 100% accuracy.
Second: something is blocking free movement of the lens. This could have a cause inside the lens barrel, and you won't see a thing. It also could be a minute damage on the outside of the lens. Or what sometimes happens while putting the camera on, you touch the lens barrel. I assume you did remove any lens cap attached to the camera.
So if you can't see any damage to the lens barrel, charge the battery and try again.
Jan 30, 2014 | Kodak EasyShare Z650 Digital Camera
Lens error restart camera
  • 1. Begin by turning the power on and off 4 times. If this does not work, remove the battery with the power still on, wait about 15 seconds and replace the battery. Once you have installed the battery, turn the power on. You can plug the audio/visual cable into the camera preventing the LCD screen from powering up. This will allow for more power to be directed to extending or retracting the lens.
  • 2. Try using compressed air to clean around the lens barrel area, this may dislodge the debris that is preventing the lens from extending or retracting.
  • 3. Gently tap on the bottom of the camera while holding the camera with the lens facing the ground. Try using the palm of your hand or the rubber pad on the USB compartment. You want to dislodge any dirt or debris that is lodged within the camera.
  • 4. With the power OFF, place the camera flat on the table with the lens facing the ceiling. While holding the shutter button down turn on the power, this will cause the lens to auto focus hopefully seating the lens barrel guide pins.
NOTE: The next step is the most forceful procedure, therefore use extreme caution when performing. Remember, if a click is heard during this step then stop and check to see if the lens error has been resolved. Clicking sounds may indicate that the lens barrel guide pins have reset.
  • 5. While turning the power on GENTLY twist, pull or push the barrel while the lens is extending or retracting. You want the barrel to move in or out evenly. The idea behind this step is to overcome the friction that is caused by misalignments or dirt within the barrel.
Jun 20, 2012 | Canon PowerShot SD850 IS Digital Camera
Turn the power off and on again message
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settigs 1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa
Feb 15, 2010 | Sony Cyber-shot DSC-W170 Digital Camera
I turn camera on. Lens comes out. beep 3 times. turns off.
Everytime I try to turn it on, the lens comes out for about a second, the camera beeps 3 times, the lens retracts and the camera shuts off. The battery is completely charged and the camera is only 4 months old. HELPP :(
Jun 17, 2009 | Samsung Digimax S500 Digital Camera
Nov 11, 2008 | Olympus FE-220 Digital Camera
Lumix lens retracts and extends
Belikes, any external object is trapped in between your Lens Motor and Camera Body. You should consult Authorized Service Personnel to handle this trouble.
Jul 28, 2008 | Panasonic Lumix DMC-FX9 Digital Camera
Kodak Z700
Tentative solution:
I had the identical problem. I went as far as disassembling the camera ... not recommended.
Instead of fussing with the lens cover, I pressed on the lens assembly (gently), the lens retracted and the lens cover closed.
My camera works now. It will be my last Kodak.
Good Luck,
Mike
Jun 08, 2008 | Kodak EasyShare Z700 Digital Camera
Lens does not retract
I'm looking for a solution to this too. The repair is going to cost more than the camera did. SUCKS!!!
Dec 02, 2007 | Pentax Optio M30 Digital Camera
Camera lens
My camera did the same thing. Try doing a couple of things.
1) remove and digital media cards.
2) turn the camera on and delete any pictures that may be stored in the camera memory (not on a removeable card)
3) remove the batteries for 60 seconds
4) replace the batteries without the media card and lay the camera on a flat surface with the lens pointing up (not sure if this helps, but it worked for me)
5) The lens should retract.
6) Turn off the camera
7) replace the media card and turn on.
I think for some reason my camera was getting hung up on the pictures stored in the camera's memory.
Nov 16, 2007 | Cameras
Olympus Vr-340 16mp Camera Digital Optical Zoom With 10x Logo
130 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
