Question about Clothing Accessories
Ducks unlimited belt buckle - Clothing Accessories
Seat belt alarm goes off intermittently when driving and buckled up. When I plug the passengers belt into driver,s buckle alarm is silenced. How can I fix this
There is a problem with the buckle sensor, it a really just a ground, circuit, try cleaning the buckle and belt end with spray brake clean, do not get it on the fabric of belt or seat covers.
May 11, 2016 | 2008 Ford Mondeo 2.0
How do you reverse the swiss gear reversible belt
While gently pulling the buckle away from the rest of the belt, rotate the buckle 180 degrees.
Sep 14, 2014 | Swiss Gear Mens Genuine Leather Reversible...
Broken seat belt buckle
If I had the problem I would look at a junkyard or on line at e-bay for a replacement. You will need to get the buckle and the belt that it is attached to that goes down to the floor down through the crack in the seat.
Remember the buckle receiver is made for the certain belt in the front and rear seats. I have often tried to put the wrong belt in a buckle and it would not fit. ( Example: the right belt goes in the right buckle.)
Be blessed.
Nov 08, 2013 | 2002 Nissan Xterra
Seat belt chimes intermittently even after buckling up
Maybe a bad switch or something in the belt latch,
I unplugged mine at the floor where the right belt anchors,
Now it's quiet,I still know if the belt is on or not by the way it feels !!
Apr 15, 2013 | 2003 Ford Mustang
I'm looking for a truck looking buckle for my dad's belt, he is a truck driver
Check out these 2 websites:
http://www.bucklesofestes.com/trucking.htm
http://www.buckleshop.com/trucking_belt_buckles.htm
Jan 10, 2013 | Clothing Accessories
Changing a seat belt buckle
The buckles are placed on the belts and then they are sewn so that you cannot remove the buckles.. You will have to replace belt and buckle as a unit. murf427
Aug 03, 2012 | 1998 Oldsmobile Intrigue
Seatbelt on passenger side want work
sounds like you have a buckle failure....this is the removal procedure...
  1. Remove the front seat.
110881806
  1. Disconnect the front safety belt buckle electrical connector.
110881807
  1. Remove the front safety belt buckle.
NOTE: The front safety belt buckle retaining bolt is part of the safety belt buckle and should not be separated.
Installation
110881808
  1. To install, reverse the removal procedure
Aug 11, 2011 | 1989 Jaguar XJ6
Srs light is on but everything is working..
Known problem for SRS light might be cause by bad seat belt buckle. Honda seat belt buckle and belts are lifetime warranty(not cover if broken because of abuse). Have your honda dealer scan it for code. They might charge you $55 to scan for the code(ex:09-3 driver seat buckle failure), but if it is a for buckle or belt code then everything is free including the scan(labor and part).
good luck
Dec 15, 2010 | 2002 Honda Accord
I have a 1994 mercedes SL320 Conv. the seat belt light on dash will not go out. any suggestions
faulty seat belt buckle or wiring, first check wiring for seat belt buckle if wiring and connectors are OK require new belt buckle, is this information helped you?
Oct 26, 2010 | Mercedes-Benz SL65 Cars & Trucks
Clothing Accessories Logo
273 people viewed this question
Top Clothing Accessories Experts
Da Doc
ray gallant
Are you a Clothing Accessory Expert? Answer questions, earn points and help others
