Question about Dual Electronics XD1222 Car USB Player
Pin point wiring diagram - Dual Electronics XD1222 Car USB Player
How to fix electrical parking light on 2004 chevy express 2500. Pleeeese help me!
Do you know how to test automotive electrical circuit's using a DM M- digital multi-meter ? How to read an use a wiring diagram to pin point test point's in an automotive electrical circuit ? If not ,your best bet would be to take it to a qualified repair shop. Takes year's to get good at testing electrical circuits . Free wiring diagrams here http://www.bbbind.com/free_tsb.html Enter vehicle info. year , make ,model and engine size. Under system click on lighting then under subsystem click on exterior lighting . Click the search button then the blue link's till you find the one for the parking lamps. Second diagram shows park lamp relay . Could be that is the problem.
Oct 25, 2017 | Cars & Trucks
Fuses
you are getting a short somewhere within the circuit. If you are capable, try putting an volt/ohm meter in 12v position and find a chasis ground, put the negative lead on it. Second, remove connector from fan and sequentially take your positive lead and go from pin to pin until you find voltage. When that happens, that wire in the circuit is possibly your culprit. Having a wiring diagram will help in determining where that wire is connected and will be able to pin point a possible fault. Try this site to find your make and model wiring diagram: http://www.eautorepair.net/app/YearsMakes.asp?gclid=CLeMqp3O770CFSISMwodGV0A3g
Apr 20, 2014 | Volkswagen Jetta Cars & Trucks
Where is the radio speed sensor wire on Hyundai/Infinity model 96560-0A500 radio?
sounds like either a call to dealer service to try for an answer or a car audio store for some help..good luck..
Dec 08, 2013 | 2009 Hyundai Sonata
Connection diagram for diehl t85 typ 600
1) Copy following links.
http://waterheatertimer.org/images/Deihl-T85-600-wired-for-208-230-Volt.jpg
http://waterheatertimer.org/Countdown-timer-horsepower-ratings.html#T85
2) 3-pin 5 amp service has 2 hot legs (wires) located across from each other on outlet.
Interrupt one hot wire and circuit turns OFF.
However live power potential still exists on remaining hot leg.
3) To turn off both Hot legs, use DPDT spring-wound timer such as Intermatic 60 minute FF460M or FD460M
http://waterheatertimer.org/pdf/039_FF-series-sell-sheet-with-wiring.pdf
Jan 05, 2013 | Diehl Hardware & Accessories
Where would I find the wiring diagram for a Samsung Security Camera SOC-a101? It is a 6 prong plug and I need to connect a PS2 connector to it.
I have a Samsung soc-a101 digital color security camera, wires corroded off male plug to camera what is the wiring sequence to the plug? wires are: red 12 volt looking at pin's front side not back of plug, from plastic tab pointed up red is on right top terminal, audio is top left terminal which I assume is white wire, then I have a clear plastic covered wire and the bare stranded wire. what terminals go to these wires I assume the bare wire goes to the metal ring of the plug as it had a wire soldered to it just don't know which! this leaves the bottom pins on the left and right set of two and the two bottom pins! Can you help? remember I am looking at the front not back where the wires are soldered. Thanks.
Dec 07, 2012 | Samsung Soc-a101 Hi-res Outdoor Bullet...
Pcm is not grounding injectors. need a pin diagram and ground location diagram
Ground points are in different locations throughout wiring harness. If you had any work done to engine it is very possible to have missed one of the grounding eyelets during the process of putting things together. Check along wiring harness in any area you can see or reach to try to locate any loose or disconnected ground looks.
Nov 23, 2011 | 1998 Pontiac Bonneville
I have an SDI Spirolab II Spirometer. The connector for the mouthpiece has broken wires. I need wiring info regarding which color wire goes on which pin.
It is very difficult to get the wiring diagram. Recently it has become very difficult to get information about internals of electronic gadgets. Because everything is proprietary now. You should contact the manufacturer for the wiring diagram.
Feb 21, 2011 | Health & Beauty
2002 jetta tdi died while shifting into 4th gear
Sorry, not a solution to this car but your other vw 1989 jetta...only way I could get hold of you.
here is your diagram
The following information covers electrical connections and plugs to the rear of the fuse/relay panel. It completes and supplements the information in the appropriate Service or Repair Manual for the fuse/relay panel section and should be used in conjunction with the wiring diagram for the vehicle or system in question. Volkswagen part numbers shown here may or may not match those on your panel, however, if you panel visually matches the diagram, it is correct for your application.
Fuse/Relay Panel - Rear Connections (Volkswagen Part Number 171 941 821 D) clear.gif
Connections and plugs on rear of fuse/relay panel:
A Blue 28 pin Instrument cluster wiring harness B Red 28 pin Instrument cluster wiring harness (position 5 open) C Yellow 22 pin Engine compartment/engine management, left side (position 10 open) D White 29 pin Engine compartment/wiper motor wiring harness, right side (position 6. 10, 14, 18, 27, 28 open) E Black 18 pin Rear wiring harness (position 17 open) G n/a 1 pin 10 individual circuits H Brown 6 pin Air conditioning/coolant fan relay wiring harness K Neutral 5 pin Seat belt warning system/coolant level wiring harness L Grey 4 pin Horn wiring harness L Black 4 pin Headlight/dimmer switch wiring harness M Black 2 pin Steering column switch wiring harness M Black 2 pin Headlight/dimmer switch wiring harness N Red 1 pin Separately fused circuits (glow plug wiring harness) P Red 7 pin 7 single point connectors for terminal 30 circuit R Green 2 pin Open/ECM power supply relay
Note: Terminal and harness assignments for individual connectors will vary depending on vehicle equipment level, model, and market. Always consult appropriate wiring diagram for specific terminal assignments.
hope this has resolved your problem
Thankyou
Aug 15, 2009 | 2003 Volkswagen Jetta TDI
Factory 99 dodge trailer plug wiring
You'll need to disconnect the wires from either the truck connector or the trailer connector...
I highly suggest purchasing a voltage checker- it looks like a screwdriver with a pigtail of wire with an alligator clip on the end. The tip of the 'screwdriver' has a point for probing. The light in the probe will light up...makes it easy to trouble shoot without a helper behind the trailer.
Hook the aligator clip to a good positive grounding point on the bumper or frame(not painted).
then pin by pin on the truck connection, stick the probe on each terminal tab.. and write a simple diagram where you find brake, tail, backup, etc...
Then i'd suggest, taking the connector off of your trailer, exposing the wire ends.
Run again thru your diagram and turn on each light of the truck. As you do, touch the wires from the trailer to that specific terminal. (make sure your ground wire is attached on the trailer) you can mark each wire with a piece of tape and label it which is which.
then simply attach your trailer wires according to your diagram to the terminals in the connector... that should get you in business..
hope that makes sense...
That way if the factory wiring harness remains the same, you'll be able to use it with other trailers if the need arises..
May 28, 2009 | 1999 Dodge Ram
I need the wiring diagram of pump it has 5 pins coming out of pump
hello, i holding a wiring diagram central locking system,model 201,it have a 6 pin,
  • pin no.1 brown goes to ground
  • pin .no 2 black ignition on
  • pin no. 3 red permanent 12 volt
  • pin no. 1 yellow trunk lid switch
  • pin no. 2 blue driver door switch
  • pin no.3 green passenger door switch
hoping it"s help to solve your problem,ty
Apr 28, 2009 | Mercedes-Benz 190-Class Cars & Trucks
Dual Electronics XD1222 Car USB Player Logo
Top Dual Electronics Car Audio & Video Experts
xxxxxx xxx
Matthew Spark
Matthew Spark
Are you a Dual Electronics Car Audio and Video Expert? Answer questions, earn points and help others
