Question about Pentair IntelliFlo VS-3050 & VS+SVRS Variable Speed Pump -
Inteliflow pump shuts itself off after running for 30 min but will try and turn itself back on
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Pentair Master
  • 1,448 Answers
Go to utube they have videos on programming you need to set time and a run time
Posted on Sep 07, 2014
Sand filter overheats
your pump shaft must be tight to turn , this could be caused by improper pump off season storage/or normal worn out or your sand charge is getting thru the filter , either one spells disaster for pump
Mar 21, 2014 | INTEX Sand Filter Pump
My magic chef model ctn1911gew is not working properly makes a clicking sound and is not cold at all and fan on bottom is not running. please help
Are we talking about the fan near the compressor? It is important to know if the compressor itself is running. If there is a loose connection to the compressor via the start/over load relay (normally attaches directly onto the compressor), or if the start/over load itself is bad the compressor will not run. It will click trying to turn on untill the over load gets hot Check to see if your compressor is really hot. Could be bad start/over load relay or bad compressor. Try unplugging your frig for say 30 min then, with your hand on top of a cool compressor, plug the frig back in and see if compressor smoothly vibrates for at least 5 min without becoming very hot or shutting off even though fan continues to run. The fact your fan is not running could itself be the problem. It is needed to keep the freon, and the compressor cooled.
Oct 12, 2013 | Refrigerators
Heat pump does not come on
check all the breaker by turning them off them back on, you may also have fuses in the box close to the outside unit, you will need a continuity tester for those. remember heat pumps will auto shut off for safety and make you wait up to 30 min before coming back on.
Apr 07, 2012 | Heating & Cooling
Unit builds to 25-30 psi then shuts off. You must
unhook the output line from the pump. run unit for 5 to 10 min. if no problem, check the tank valve at the end of you out put line, it screws into your tank. that valve must shut off at every down stroke of the piston, or air well flow back to the pump. will put an overload on the motor. good luck
Oct 16, 2009 | Campbell Hausfeld Air Tools & Compressors
Kerosene heaters run for 30 mins then shuts off.
Sounds like the pump or air filter is dirty. If cleaning them doesn't help, the pump will need to be rebuilt.
Oct 14, 2009 | Reddy Heater 60,000 BTU Kerosene...
Fuel pressure intermittently drops causing sputter and die.
check for 12v constant at your fuel pump if you are not getting that replace your relay.
if you are getting 12 volts at your fuel pump the fuel pump is possible to run tuel it gets warm then shut down to a lower rpm I would then replace the fuel pump
Oct 10, 2009 | 1994 Dodge Ram
Keeps turning off by itself after about 30 minutes
Is your air intake clean or clogged.. Maybe it's overheating causing it to shut off.. Had the same problem didn't replace the bulb but cleaned the intake and it works great again. Worth a try.. Intake is located on the left back pannel of the tv.. outside pannel pops off easly.
Apr 27, 2009 | Toshiba 42HM66 42" Projection HDTV
Pentair IntelliFlo VS-3050 & VS+SVRS Variable Speed Pump -  Logo
71 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
