Question about Canon imageCLASS MF8450C Multifunction Printer Color - 17 ppm Mono - 1
Canon mf8450 toner problems
Toner problems
2 Suggested Answers
  • 34089 Answers
SOURCE: How do I clean the transfer belt on Canon Imagerunner MF8450?
Refer your request for cleaning instructions directly to Canon.
Posted on Jul 10, 2014
Triumph -Adler Dc 2020 with Error code c 710 please help?
Toner sensor problem or Developer problem Description Toner sensor problem
• The sensor output voltage is outside the range of 0.5 to 4.5 V during toner control.
• The toner sensor control voltage cannot be set within the setting range when maintenance item U130 is run. Causes Defective toner sensor. Poor contact of the toner sensor connector terminals. Developer problem.
Feb 25, 2015 | Office Equipment & Supplies
BROTHER DCP7055 PRINTER SHOWS REPLACE TONER EROR
When replacing the toner cartridge, you MUST install a brand new, unused genuine Brother toner cartridge in order to reset the toner status. Swapping toner cartridges from one machine to another or installing a partially used toner cartridge may cause this problem. Brother machines control their image quality for the most suitable print quality by monitoring toner consumption. If you install a partially used toner cartridge, your Brother machine is unable to recognize toner consumption correctly which will cause this problem. Therefore, when you replace the toner cartridge, please use a brand new toner cartridge, not a partially used toner cartridge from another machine.
Jul 26, 2012 | Brother Office Equipment & Supplies
Bit of print at top then dirty streaks and no printing on rest of sheet
I know this is a silly question, but is toner cartridge full? Is the toner cartridge remanufactured? this sounds like a toner application problem. More info about the toner cartridge would help.
Keep it simple, but it could be a charge corona problem and it's arcing. If the inside of the machine is dirty with toner, get some canned air and blow out the interior of the machine. BE SURE THAT THE EQUIPMENT IS UNPLUGGED, and do the cleaning where it won't blow toner on your good clothes. doit outside or in the garage.
1. make sure cartridge has toner. If remanufactured, be suspicious. Especially, if toner is inside the machine. This indicates wrong/bad toner.
2. If tonered inside, carefully air blow the toner out. get another toner cartridge to try.
3. If problem persists, then a professional needs to do more cleaning and check voltages and clean electrical contacts.
Jan 05, 2011 | Brother IntelliFax-2820 Laser Fax
I have a TallyGenicom 8008 color laser printer which while still printing well, is making a terrible noise - a grinding worn out part noise! Any ideas how fix it or lubricate it?!
I would suspect if the printer is still printing and feeding paper OK the problem may be related to one of the toner cartridges being stiff or partially seized.
From memory I believe the most likely toner to cause the problem is the black toner (or the yellow), but you can identify which toner is causing the problem by doing the following;;
  1. Open the front cover (the one you access the toner through) after a few seconds close the cover. The printer should go through a self test.
    If the printer makes a griding noise during this self test and warm up phase this helps with identifying the cause.
  2. Open the front cover again, this time remove the top toner cartridge
  3. Close the front cover with the top toner missing
  4. Listen for the noise heard in step 1, if no noise is heard it is likely the top toner needs to be replaced.
  5. If the noise is heard with the top toner removed, replace this in the printer and remove the second toner.
  6. Again close the front cover and listen or the noise, if it is heard the problem is with the second toner.
  7. Repeat this process for the third and fourth toners to see if one of these may be causing the problem.
After you have identified which toner may be causing the problem, you may wish to try gently tapping the cartridge.
An unorthodox method of solving the problem if you are feeling brave and don't mind sweeping up toner!!!!!!!! You may wish to drop the toner cartridge (GENTLY) from waist height to the ground.
This may dislodge any toner jamming the cartridge and will resolve the problem - It will also spill a bit of toner on the ground so you have been warned!
Aug 16, 2010 | TallyGenicom 8008 Laser Printer
Samsung scx4200 toner problem
I refill the toner for samsung scx4200 .Now its show toner empty replace the toner on the printer lcd. How i can slove this problem.
Jul 09, 2009 | Samsung SCX 4200 All-In-One Laser Printer
Have a problem with a Sharp AR152. The toner
Once the toner lite comes on it blows the chip in the toner cartridge, a new toner will fix your problem.
May 04, 2009 | Office Equipment & Supplies
Recently changed the black toner cartridge in the Dell 3110cn printer. This past week when I print the entire page is being printed with a shade of gray. I think the toner cartridge has leaked toner and...
This could be a drum problem, the drum is part of the toner cartridge in this printer.
If the toner has leaked it will be all over the inside of the printer - you'll see it. I don't think that's the problem.
If the toner cartridge is an original Dell item, then it's likely to be replacable under warranty.
If the cartridge is a remanufactured item, it may be that the wrong toner has been used. Toner is NOT all the same, and this cartridge is one whe the wrong toner really will not work properly for long.
The chances are the changing the toner cartidge will cure the problem, provided you use an original Dell item, or a remanufactured item from a reputable manufacturer.
Apr 19, 2009 | Dell 3110cn Laser Printer
Samsung scx-4300 toner exhausted
samsung scx-4300 error message "toner exhausted" how to reset printer
Apr 11, 2009 | Office Equipment & Supplies
Problem with aficio 1035
The developer should probably be changed in it. the cartridge should be inspected as well. Was there any toner spills?
Jun 21, 2008 | Ricoh Aficio 1035 Copier
E020 Error message on NP6050
A E020 code is a toner amount problem in the developing ass'y. Is the copier asking for toner or was it and no toner was installed? If not the amount of toner is to low for the hopper to add enough toner in to over ride the toner sensor. Look in the developing ass'y for toner, if you only see about a 1/8' of toner you need to clean or replace the toner sensor. Then you are going to have to run in service mode " toner-s". Then rechk the amount of toner in the developer ass'y. It should be about a 1/2' or so. If not you have a problem with the toner hopper. And if that is the problem you may want to manually add toner in the developing ass'y to get the copier working again. You also have to clear the error code in service mode.
Jan 28, 2008 | Canon CLC 1120 Color Copier
Canon imageCLASS MF8450C Multifunction Printer Color - 17 ppm Mono - 1 Logo
old marine
old marine
