Fuse constantly blowing on 32" Panasonic HDTV Tau (ModelCT-32HL42)
Our TV set had the same fuse blowing on us twice in less than 10 months.  When it happens, the TV can no longer be turned on. You can hear a click when you press the power on button but not in subsequent  attempts (unless you temporarily unplug the TV for a few seconds).  We are being told by an independant repair shop that this may be due to a capacity issue: the electrical circuit that converts the signals to a digital format would not be strong enough to withstand the flow.  If it's the case, can this be repaired by other means that replacing the fuse on and on ?  Have you ever heard of such an issue affecting these Panasonic HDTV models ?  Should  this be considered a manufacturing defect ?  Thank you.
    Genius:
  • 1,694 Answers
Change fuse from F6.3 amp to T6.3 amp (Slo-Blo).
The problem is the surge of current at turn on.
Posted on Oct 10, 2007
SOURCE:
Tv does not come on-no lights at all
This set has a pair of common issues----one: the fuse (6.3 amp and special--do not replace with Radio Shack or generic fuse) blows for no reason---with back off follow power cord (unplugged please) direct to the fuse which snaps into a holder--if stand of wire inside is broken or black replace the fuse with (not generic cheap fuse) correct fuse.
A few of these sets had problems with the degaussing circuit but that is rare----9 out of 10 times replacing the blown or open fuse with the CORRECT one returns set to operation.
I stress that as saw one where a guy replaced the fuse 3 times in a row in a few days with a generic one that popped at turn on.
Oct 24, 2012 | Panasonic CT-32SC13 32" TV
Tv has no picture or sound. replaced bulb no help greenlight blinks 79 times. red lights start blinking
Lamp light flashing once every 5 seconds or twice every 5? Twice every 5 seconds,....lamp failure, once every 5 seconds,...ballast or thermal fuse failure. You have a lamp, ballast or thermal fuse problem. The ballasts are a discontinued part and can only be purchased used at approx. $225.00 or rebuilt for around $175.00 less any service charges to diagnois and repair.
Jan 17, 2010 | Panasonic PT-50LC13 50" Rear Projection...
What is the size of the input fuse on a 32" HDTV .63 amp or 6.3 amp
That would be a 6.3 AMP fuse. If the fuse in the set is blown most likely the thermistor for the degausser is bad and needs to be replaced too. If you get me the model number of the TV I can get the part number for the thermistor. If you don't replace the thermistor then the fuse will most likely go right away or within a few days of operation. Please rate my answer. Thanks...
Nov 23, 2009 | Panasonic Televison & Video
No Power on 32" Panasonic
A slow blow fuse is also known as an anti-surge fuse the idea being any sudden "spikes" in you mains electric when you switch on would blow a quick blow fuse. Anti surge fuses are designed to tolerate any sudden initial electric pulse.
Jun 22, 2009 | Panasonic CT-32SL14 32" TV
32'' Panasonic TV, 4 yrs old, keeps blowing the fuse
Hi Mendi.
I had a similar problem, in that I could not find the proper fuse for my set. I bought a bit higher amp fuse from Radio Shack and it ended up blowing a couple months later. I've since pulled the TV down and replaced it with an LCD set, so I've solved my problem.
But, to address yours, I don't think the amp difference would not be the problem. Likely, there is a power issue on your set causing it to draw more amps and become out of specification. Using a higher amp fuse would buy you more 'capacity', but if its blowing those too (repeatedly), its likely a real problem in the set. I'm not a TV technician, so I can't tell you why. I'd suggest taking the thing in for service (cheaper than the house call) or if that is too expensive, looking at putting your money into a set that won't give you those problems. Or, just keep replacing the fuse until it doesn't fix the problem.
Sorry I cant help much more.
May 13, 2008 | Panasonic CT-36SL13 32" TV
Main fuse blown on CT-32G11 32" Panasonic TV, Replacement fuses continue to blow.
If the main fuse keeps blowing, check the horizontal output transistor for a shorted condition and diodes in that section as well.
Jan 12, 2008 | Panasonic CT-32G11 32" TV
Tv just shut off, now now power will not turn on at tv or remote
I have the same problem with my Panasonic Tau 32" HDTV (tube). It's well out of warranty, so I might "explore" and see if I can find a burned fuse or other component.
Jan 05, 2008 | Samsung TXM3096WHF 30" TV
CT32SX12F 32" Won't power on
when mine it, i had to replace a fuse
Jan 05, 2008 | Panasonic CT-32G11 32" TV
CT-32HL42 Panasonic will not turn on
These sets have a number of problems like yours which are associated with bad solder connections or cold solder joints. On this set one pin on the the start-up relay is usually open or intermittent The solution is to resolder connections on main p.c board. and especially on the vertical output IC. Also change the caps in the vertical section to avoid future problems. Scrivitron.
Jul 06, 2007 | Panasonic CT-27G13 TV
Panasonic 36HX41E Tau 36" HDTV Won't turn on
i think line out put transformer is leaking high voltage.if u r nat an technetion then dont try to on tv agin because high voltages can damage several costly ic in the set.
May 25, 2007 | Panasonic CT-32HX40 32" TV
Televison & Video Logo
155 people viewed this question
Top Televison & Video Experts
Ekse
