Question about Sony CHC-CL1 CD Shelf System
CD player has CDs in it but you press play it says no cd moves to all of them and says no cds
5 Suggested Answers
  • 12 Answers
SOURCE: CMT-BX1 won't play CD's - "No Disc"
If they're clean (i.e. not scratched up or dirty) store-bought CDs (burnt CDs can be iffy in some players), then yes you should return it.
Posted on Sep 19, 2007
SOURCE: cd player dosnt work
if you know how to open outer cover of the cd player then open it and clean the optical lens with a very soft cloth.put the cd and run it.it will play.
Posted on Oct 21, 2008
IrishDruid
  • 2712 Answers
SOURCE: WONT PLAY CD
Most likely a dirty lens or an optical assembly problem.
If its a dirty lens, the issue can be easily rectified by using a CD lens cleaner, available from nearly any electrical store.
If cleaning with the lens cleaner did not help, then it could be a major issue. Try unplugging the system from the power source for at least 15 minutes and replug and see first. If it works, great! If not...
If the lens has become opaque or scratched, or there is a problem with the assembly, then the only solution is to take it in for servicing. Mind you, this can be a pretty expensive repair, so you'll have to decide between getting it repaired or purchasing a brand new unit altogether...Shop around for repair costs and then decide which route to take..
Posted on Dec 03, 2008
SOURCE: sony chc cl 5 md - cd changer doesn't open
I had a similar problem with my sony cd changer. Took it apart it turned out to be the drive belt a 3 pound part. Got a new slightly smaller one and works well. Very easy to replace.
Posted on Feb 21, 2011
Sony CD Walkman D-EJO11
Laser pickup unit fault. Contact any service technician. Gopakumar Gopalan Google
Mar 07, 2014 | Sony Televison & Video
I have an Aiwa stereo cd player that only plays certain cd's but not the new ones, it is model cs-na222
Some Aiwa players will not play burned, non-closed or expanded limit cds (CD of 700MB or overburned to 750MB).
When you say new cds do you mean purchased pressed cds or ones you created?
Jun 03, 2010 | Aiwa Audio Players & Recorders
The cds won't play. Once you press play, the cd
Sounds like you have a powre supply issue. It could also be a display issue but if the display is working OK before you hit play I wouldn't think so. When you hit play does the display dim? If it does then the power supply is the problem. If not then the control board has a problem. Let me know how you make out.
hardrocko
Thanks for using FixYa
Feb 12, 2010 | Onkyo DX-C340 CD Player
It wont play CDs
the cds you put in there are not compatible to the player.if it had been playing the same cds then it is time to take your set to a tech for repair it can be your memory chip or your lens.good luck.
Apr 18, 2009 | Memorex MKS5009 Karaoke System w/CD/CD+G...
I cant play cds on my wharfedale pcd 6200 usb
I think you need to press and hold the Play button (marked PLAY/PAUSE) to switch between CD playback and the USB port (you can store mp3 files on a USB stick and play them directly) on the front of the device.
Try inserting a disc, switching the unit to CD mode, press and hold Play until the display changes and the CD spins up...
Might just work?!
Duncan
Mar 22, 2009 | Audio Players & Recorders
Envoy 2004 cd player
I had same problem with a 2005 Envoy in Jan '09. I took it to the ex-GM dealer. He said he'd try. The unit would only play using radio.
Mechanic took unit out of dash, and top off of unit. Ejected CD bu moving the eject mechanism. Replaced top and unit.
Works and plays cds. Cost $25.00 And i tipped the mechanic $10.00 for his knowledge.
Jan 30, 2009 | 2004 GMC Envoy
CD player won't play CDs burned on new computer
hi penguinxy.
try get a original cds if it works fine.the next time you burn cd try burn at 8x or low may be your cd lens is not detecting cds burnt at high speed.hope this helps..
May 10, 2008 | Jensen CD-2010X CD Player
Cd player not playing some cds: denon cd player ucd-77
try cleaning your not working cd with soap and water, and dry it with paper towel. tnx
Jan 30, 2008 | Audio Players & Recorders
Playing CD-RW audio CDs on Kenwood DP-J2070
try to play a song from original cds.
maybe you brunt it in mp3 file, or its a different format. try to burn your song to cd-r.
if still, try to use nero to burner..
if it wont play your original cds and burnt cds,then the optical lens or the board is broken.
hope I helped you.
Dec 06, 2007 | Kenwood DP-J2070 CD Player
Technics cd hi-fi
hi bobro, when burning the cds, make sure that you are burning it as an audio cd, as this player does not support mp3 formats, just normal audio cds... hope this helps!
Feb 11, 2007 | Technics SCEH790 CD Shelf System
Sony CHC-CL1 CD Shelf System Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
