Majestic fireplace model 36BDVRRN burns and goes out will not stay lit
  • 6 Answers
SOURCE: Propane fireplace insert won't light
Gas apliances have safety features built into them so you don't blow yourself up. The pilot heats a thermocoupler which tells the gas valve there is a flame, open the main gas to the burner. If you can see the flame area of the pilot look for a round post about 3/16 inch in diamiter. This should be directly in the flame, if not bend the bracket so it is in one side of the pilot flame. The thermocouple is attached to a mounting bracket. This will be held in place by a 1/4 inch hex screw. remove the screw and the capilary tube leading to the gas control valve. Before you do anything, close the main gas supply to the fireplace and disconnect the power to the fan. You may need to semi dismantle the fireplace to get the thermocouple. The gas valve end is a brass 1/4 pipe thread plug. Turn the outer nut and remove without twisting the tube. Reverse this order to install a new one. Besure not to twist the capilary tube, tighten brass nut 1/4 turn past hand tight. Your better heating supply house will have these in stock. Restarting the pilot will take a few tries because the gas was off. Your gas suplier would charge about $75 to fix this. if you don't have the proper tools and it dosen't look pretty stright forward don't do it. You could get dead.
Posted on Dec 02, 2008
detox101
SOURCE: Gas fireplace pilot flame won't stay lit.
Hi , you can try and pull the panel on the bottom of fireplace out and check the adapter in fireplace. Sometimes they go bad. When you open in also check to see if there is an adapter plugged in and a option to use the battery operated function. If this goes bad the pilot will not stay lit.
Posted on Jan 14, 2009
SOURCE: gas fireplace will not stay lit
there is a probe that is in the one of the flame... This once heated builds up enough pressure do to the heat to keep the shut/off valve open... (reason, if the flame went out the gas would continue to flow) this "thermocouple is replaceable !! contact me at homeprohandyman@verizon.net
Posted on Feb 23, 2009
  • 10 Answers
SOURCE: GAS FIREPLACE
Yes, hopefully changing the thermocouple (skinny sensor) or thermopile(fat sensor) would do the trick.
Start with these fairly inexpensive repairs first.
Unfortunately if the honeywell valve is bad a new one can be expensive.
Also it is hard to order parts from Majestic, they just went bankrupt, not to long ago and Martin is taking them over. You might look for your valves model# and check online for other suppliers of that model# or ask for a compatible Direct Vent gas valve that's not as problematic. (eBay and HVAC dealers, etc.)
FYI:
You said it's been about 5 years, you might decide it's less of a hassle to have new gas fireplace installed. Martin and Empire are probably two of the best, with 5 year parts and labor warrantys.
Hope you find some success in your endeavor.
Posted on Apr 11, 2009
  • 3368 Answers
SOURCE: My propane fireplace pilot light goes out when the
I am just guessing but it may be set to low. The rush of air when it extinguishes could be blowing it out.
Good Luck,
Gilshultz
Posted on Nov 30, 2009
Lighting the pilot, starting the fireplace
Turn on the gas, hold the pilot flame button down and light the pilot flame, continue to hold the button for at least three min's, release the button pilot should stay lighted.
Jan 06, 2017 | Majestic Heating & Cooling
I bought an Insta Flame model FSDV 30 direct vent wall furnace, need a natural gas conversion kit. It currently is set up for propane and could use some help in finding the parts and installing them.
There is a ban on that particular furnace as they can explode!
You won't find parts or anyone that will work on it.
[PDF]TSSA Bans Series of Insta-Flame and Northern Flame Fireplaces www.dunnheating.com/.../TSSA%20Bans%20Series%20of%20Insta_Flame%20and%...
  1. Cached
  2. Similar
Oct 23, 2012 - (TSSA) has banned a series of natural gas and propane-fired direct vent ... 'FSDV22' or 'FSDV30' or 'FSDV32' in the model name or number.
TSSA Bans Series of Insta-Flame and Northern Flame ... - CNW Group
www.newswire.ca/.../tssa-bans-series-of-insta-flame-and-northern-flame-fireplaces-51...
  1. Cached
  2. Similar
Oct 23, 2012 - All Insta-Flame and Northern Flame natural gas or propane-fired direct vent freestanding fireplaces with 'FSDV22' or 'FSDV30' or 'FSDV32' in ...
[PDF]Fuels Safety Program DIRECTOR'S ORDER - TSSA
https://www.tssa.org/corplibrary/ArticleFile.asp?Instance=136&ID...
  1. Cached
  2. Similar
Mar 25, 2016 - Natural Gas Fired Direct Vent Free Standing Fireplace - Model ... Insta-flame or Northern Flame: Models FSDV22, FSDV30, FSDV32, D222.
Majestic Fireplace - - Recalls & alerts - Healthy Canadians Website
www.healthycanadians.gc.ca/recall-alert-rappel-avis/hc-sc/2012/15058a-eng.php
  1. Cached
  2. Similar
Nov 9, 2012 - Natural gas and propane-fired direct vent free-standing fireplaces ... Insta-flame or Northern Flame (Models FSDV22, FSDV30 and FSDV32, ...
TSSA Safety Order Ban of Majestic FSDV22, FSDV30 and FSDV32
www.fireplacegroup.ca/tssa-safety-order-ban-of-majestic-fsdv22-fsdv30-and-fsdv32/
  1. Cached
  2. Similar
Dec 21, 2012 - TSSA Safety Order Ban of Majestic FSDV22, FSDV30 and FSDV32 ... CFM Inc. (Majestic Fireplace) and bear the trade names Insta-Flame or Northern Flame ... (a) Natural Gas Fired Direct Vent Free Standing Fireplace - Model FSDV22, FSDV30 ... -Stove shipped as natural gas; LP Conversion Kit included
http://www.healthycanadians.gc.ca/recall-alert-rappel-avis/hc-sc/2012/15058a-eng.php
Dec 11, 2016 | Kitchen Ranges
My majestic fireplace lights and the burner lights and I turn on the switch and the burner stays lit for a minute or two then I hear a click and the burner and pilot light shut off
yes this would appear to me to be the classic symptoms of a bad thermistor , this little device proves that fire has lit (via heat) and keeps gas valve open , otherwise gas valve times out and shuts off (safety)
Oct 15, 2016 | Majestic Heating & Cooling
Manual for majestic gas fireplace model HDV36 RN
http://www.majesticproducts.com/Customer-Care/User-Guides-Manuals.aspx
Apr 27, 2016 | Majestic Heating & Cooling
Majestic Vermont casting dv36 lp
There could be several issues here. First is the pilot is weak. You may have something clogging the pilot oriface, or it could be turned down too low. Second is the thermocouple could be bad. And last, the main control valve could be bad. There are some tests that can tell you which of the last two may be your issue but they generally require a qualified tech.
Mar 30, 2014 | Majestic by Vermont Castings Home
Majestic gas fireplace mmodel majestic fireplace 36CDVXTRN will not stay lite after 20 minutes.
If you are able to , open the burner box , the igniter has a thermocouple ( might look like a thick wire that would be in the flame if it were on). If it gets corroded or junked up it will not register the flames presence and will shut off the gas). Take an emory cloth and polish it. Hope it helps.
Feb 05, 2014 | Heating & Cooling
My Majestic gas fireplace pilot stays lit. But the burner does not light when heat is called for.
Check a safety device called thermopile which the two wires connected to the unit needs to be around 500mV to open gas. This part is between 35-50$ If that is not the problem, you may need to replace unit gas valve.
Oct 10, 2013 | Majestic Fireplaces Majestic Topaz 20ILDV...
When we built our home 6 years ago, Airtron installed a Majestic NVBR36RN vented fireplace system. We had to turn our gas off a while back and never thought about the fireplace until now when we wanted to...
It has a panel hidden under the white fiber hearth bricks at the front bottom of the unit. you need to clean the lava rock off of them, pull both of them up, and then you will see the hidden linear cover that allows you to access the valve and light.
Dec 02, 2010 | Heating & Cooling
Dec 27, 2008 | Leisure HOMEPRIDE Electric Fireplace...
Heating & Cooling Logo
181 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
