Question about Lava HD-2805 Ultra Remote Controlled HDTV Antenna with G3 Control Box
Lava HD 2805; worked for 2 days, received lots of channels; it rained; red light on bottom of antenna isn't lit and unit won't receive any channels now. Can it be fixed or do we have to return it?
I have a palsonic TFTV826HD tv and when i came home from a 2 week holiday , i am not able to receive the ABC and ch 10 stations , others i have , i reset and did the auto tuning
Do you use an digital antenna receiver which gives you a couple basic air channels for free Or is it through a cable company? It could be the weather conditions or the antenna could be unplugged or cable wire could be loose or cable company could have certain channels being fixed.
. We have a big Element HD tv flat screen and use an digital antenna receiver and when receiver is unplugged or if our outside/entry way doors are open (receiver antenna is outside) none or some of channels won't work..
Hope this kinda helps :/ :) let me know.at least I tried lol
Feb 01, 2017 | Televison & Video
Tried to hook up a HD antenna but it won't work
HD is pretty critical and if a indoor antenna do not expect much or anything for that matter.
Jun 17, 2012 | Televison & Video
I have a RCA D52W20 rear projection HDTV. This TV was purchased in2005. I cancelled my cable and I just hooked up a digital antenna but the TV isn't finding any channels. What do I need to do? I was...
HDTV indicates the number of lines that are shown by the TV. (HD means that at least 720 lines can be displayed in a given picture.) To receive OTA signals, you need an ATSC tuner (digital) of sufficient power (with a clear path to the transmitter) these days. The RCA D52W20 was released in 2002 and only has an NTSC (analog tuner). You will need a digital-to-analog converter to receive OTA TV (unless any low power analog stations remain in your area).
Please note that the basic digital-to-analog converters that were available with the government coupon back in 2009 were SD (480i lines of pixels used) units. HD d-t-a converters exist but are more expensive.
I hope this helps.
(the phrase "digital antenna" is meaningless; check with tvfool.com or antennaweb.org for the direction of local transmitters. TVfool.com will give more information on the type of antenna (indoor, outdoor, amplifier) that you will need to receive channels in your area. Antennaweb assumes an external antenna but is very conservative in the stations that it will indicate that you can receive. Antennas are given a color rating based on how far away the transmitter can be to get a watchable signal. Since digital signals are either enough for the tuner to interpret or you get a "no signal" message, you often need a stronger signal than was needed to receive a watchable analog channel.)
Sep 27, 2011 | RCA Televison & Video
I need to know what cables to get to make it true HD. Also I wanted to know why I can't receive local channels.
go to menu then tuning,set from cable to air,for local channel.you can't get true HD for cable because cable is an analog signal
Sep 07, 2010 | Televison & Video
Got a new tv antenna installed the other day, rescanned the channels and can't get Channel 10 in Sydney, Ingleburn (yes, we do have television in Ingleburn)! Also, it rained on the weekend and ABC dropped...
With all antennas you MUST ensure that it is all OK, physically check, there are no whiskers of braid caught between Inner & Shield, Make sure the center pin IS contacting in the socket. Check The connections at the Antenna end. Check the earth braid. If you can check continuity with a meter, check for "Shorts" between braid & center conductor. make sure it is Pointed at the Transponder... even a little off will give signal loss. rain fade is a huge problem unfortunately.
Feb 08, 2010 | Televison & Video
My Denon AVR 2805,has a problem. In a few seconds after switching on, it automatically turns itself off. What is the cause of this problem? How can I fix it?
This unit is in what is termed :protect mode". This means that one or more of the amplifier channels has a rpoblem that was detected by the protection circuit inside and the unit has been shutdown to prevent further damage. This is often shorted output transistors or a defective amp pac for the surround channels. Expect a parts cost in the $50 range for this repair.
Dan
Oct 08, 2009 | Denon AVR-2805 Receiver
With converter box only receive 2-3 channel
They have powered antennas that give you more stations. I added a HD antenna I bought off ebay for 19 dollars and I get 10 stations. Please give me good rating It means a lot to me.
Jul 05, 2009 | Insignia Digital-to-Analog Converter for...
Cannot receive HD signal
TERK HDTVa is a good amplified indoor antenna.
Jan 04, 2009 | Samsung SIR-T160 DTV Receiver
NO HDTV
There are many variables here that could cause the problem. I can receive a few local HD channels ( within about 60 miles ) on my 57H94. I am not aware of any "HD specific" settings- it's all part of the receiving circuits in the TV. The first thing I would look at is to be sure you have a secure antenna connection. Then be sure you have selected the correct antenna input on the TV (there are two). HD channels, as an example will show up as 10-1, 10-2, etc. Most TVs have different sensitivity thresholds, regardless of size. Usually digital signals, including HD, are either there or not. In most cases if a TV picks up a decent analogue signal, a digital set should receive the digital signal, including available HD channels, as well. If you are going to use an antenna, rather than cable or satellite, try to get the best antenna you can afford, that will meet your physical requirements ( indoor / outdoor,etc.). Keep in mind that not all digital TV signal are HD. All of our local stations in this area transmit a digital signal, but true HD broadcasts remain variable. I hope this has helped in some way-Good Luck!
Nov 15, 2008 | Toshiba 57H94 57" Rear Projection HDTV
RCA HDTV, indoor antenna and Dish Receiver 311
I want to use two (2) 311 dish receivers with only 1 outside antenna.
Jan 08, 2008 | RCA L32W11 32 in. HD-Ready LCD Television
Lava HD-2805 Ultra Remote Controlled HDTV Antenna with G3 Control Box Logo
44 people viewed this question
Top Lava Electronics - Others Experts
Are you a Lava Electronics - Other Expert? Answer questions, earn points and help others
