Question about Logitech USB Desktop Consumer Microphone
My mic is not working.
It is plugged in, i went thru the steps recommended in the user manuel. rebooted it, turned it off and on. and it still wont work.
  • 2 more comments
  • jusjos Nov 04, 2007
    mic is connected, went to control panel sound enabled is not muted but still not working mic is good tested on another pc
  • Anonymous Nov 19, 2007
    my mic is not working, i can hear from other but others cannot hear me
  • crazycarl198 Jan 19, 2008
    i have a voice sever for a game a play and the mic is not working for it. plus when i tried to test mic on my computers voice recorder it did not work either
  • xrpm71 Apr 28, 2008
    I am also having this problem, my headset works fine but the mic is not working, has anyone found a solution to this problem?
Same with me its not working crappy mic i say i have a head set mic but i can hear others but they cant here me.
Posted on Apr 11, 2008
Moto g 3rd gen wont charge or turn on after my battery died. why?
Hi Crystal,
This is our recommendation as well.
  1. Plug it into the charger
  2. Hold the VOL DOWN key
  3. While still holding the VOL DOWN key, press and hold the POWER key
  4. Hold both keys down for over 120 seconds. This is more than two minutes and will seem like a long time. You might want to time yourself to make sure you hold it longer than two minutes.
  5. After holding the keys down for more than two minutes, release them.
  6. The Flash Boot screen will display, and the Normal Reboot option will be highlighted
  7. Press the VOL UP key and the device will start a normal reboot.
  8. We're working to eliminate this issue in a future update.
    If you have tried the above and it didn't work, try this:
    • Plug in the phone for 15 minutes.
    • Proceed to Step 2 above.
Motorola Support
May 07, 2016 | Motorola Cell Phones
Rca tablet model rct6272w23 screen pixalted white then went black now wont turn on
I would recommend calling RCA support at (800) 252- 6123 so they can suggest some troubleshooting steps you can take. If it is still under warranty and you're unable to get it working then you can send it back and get a replacement
Dec 28, 2014 | Tablets & eReaders
My nexus 7 tablet wont leave the startup screen. I tried a hard reboot but it stays on that screen and wont turn off
Important:Plug your device into power outlet
Step 1: Power off Nexus 7
Step 2: Power on while holding Volume Down/Up
(enter BootLoader)
Step 3: Press Volume Up to toggle to "Recovery Mode"then press power to select
Step 4: Hold The Power Button and tap Volume Up when you see "No Command"
Step 5: Press & hold Power Button & Volume Up Button Again
Step 6: Toggle with vol down CLEAR CACHE & reboot
Nov 03, 2013 | Google Nexus 7
My turtle Beaches work work with my turbo fire 2
they are not compatable... read your booklet that came with your head set and you will see if small print that it is not compatable with datel controllers. you can get a typical head set with mic. that comes with your cell phone as i have and with the plastic clip that comes with the cell phone set clip the mic part just above the foam cover over the turtle beach mic. (also turn off the mic. part of the turtle beach unit) then put the cell phone single ear piece into your left ear and then put on the turtle beack head set. due to the small size of the cell phone ear piece you will not feel it. then plug into your datel controller the plug from the cell phone head and mic piece. you will hear thru the turtle beach all of the game sounds, etc.. and thru your cell phone set you will hear you chat. it works and will do until datel or turtle beach comes out with a fix, if ever.
Jun 30, 2011 | Datel Xbox 360 Turbo Fire 2 Wireless...
It wont power up if plug in
Depends on the kind of microphone. Some mics use PHANTOM power, a small 24 -48volt signal that makes the microphone operate. Mics that don't need it will ignore it, but mics that do will require it to function, otherwise they will not work at all. If you have a mixer with a PHANTOM power switch, turn it on and try it, otherwise you may need to get an outside phantom power supply from a music store or pro audio shop.
Another possibility is the microphone is not the same impedance as the input you are plugging it into. You may need get a line transformer to step up the volume of the mic to work with your system. Again, check with the store. Always read your manuals too if you have one. Good Luck.
Feb 21, 2011 | Audio Players & Recorders
HELP! My new compaq presario cq60 built in microphone wont work. I need help fast, major school project due in two days. My mic worked before, I disabled it because i was trying to so some streaming...
Do you have two mics or not,well if you have one you may have to delete one of them or both.Reboot the computer windows will install the drivers and this should fix this If not un-install the sound card drivers.Windows should reinstall once you reboot.However before you do make sure you have a copy of the sound drivers to reinstall.
Good luck
Sep 12, 2009 | Compaq Computers & Internet
Just bought a tent trailer with a Dometic Fridge.
You need to make sure that you follow the manufacturer's recommendations for using the unit with each specific power source. It's important that you have the all switches in the proper position, based on what power source you're using.
Here's the manual for your model, save a copy and print it out and take some time to review the section #3 Operating Instructions on page 6.
Hope you find this helpful and will resolve your issue.
Jul 26, 2009 | Dometic RM2193 Compact Refrigerator With...
Internal mic not working
IThe issue could be due to incorrect audio settings, corrupted drivers.
I recommend you to follow the steps in the below link:
Similar steps have to be followed even for Vista.
Jun 30, 2009 | Acer Computer AOA150 Notebook
My Iphone wont turn on
Step 1. Turn off your iPhone.
Step 2. Hold down the power and home button.
Step 3. When you see the Apple logo, release the power button but continue holding the home button down.
Step 4. Open iTunes and wait for it to tell you that its in restore mode.
Mar 24, 2009 | Apple iPhone 3G
My sansa e260 wont turn on or charge
I had the same problem. Place the device into hold and press the menu and mic buttons at the same time. The first time I tried it, I had no response and then I pressed the same buttons again and my e260 came back to life.
After getting my e260 to come on, I updated the firmware and everything has been working.
Jan 27, 2008 | SanDisk Sansa e200 MP3 Player
Logitech USB Desktop Consumer Microphone Logo
572 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
