Question about HP Compaq nc6220 Notebook
Will not power up even to bios
When you try to power on light comes on and fan runs will not even light up tryed changing ram did not work also when trying to power two green blink two times
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    If you have two sticks of RAM try one at a time in each slot at a time and also make sure your battery is disconnected and you only have the AC adaptor hooked up for power.
My T61 shuts off after 15 secs of installing any OS. It shuts off even while changing BIOS Settings. Please help.
Have you tried a different power adapter? Is the fan working? I assume it is getting through the ram check? Also try with the battery out. Is it saving bios settings?
Mar 04, 2011 | Lenovo ThinkPad T61 Notebook
Power light comes on but not working
First you need to determine how many blinks you are getting when you try to power on the laptop. Check the blinking codes below and reason behind that for HP Compaq laptops Blinking battery power LED Battery Insufficient charge on the battery Blink: 1 - Caps Lock/Num Lock - CPU CPU not functional Blink: 2 - Caps Lock/Num Lock - BIOS BIOS corruption failure Blink: 3 - Caps Lock/Num Lock - Memory Module error not functional Blink: 4 - Caps Lock/Num Lock - Graphics Graphics controller not functional Blink: 5 - Caps Lock/Num Lock - System board General system board failure Blink: 6 - Caps Lock/Num Lock - BIOS BIOS authentication failure You need to first Remove the memory module (RAM)- Try to power on the laptop ? then again reset it and try to power on. Check whether it is coming on or not. try the same procedure with Hard drive. If laptop is getting power on after removing one of the device then we can be sure that that particular device is faulty and we can change that then? Let me know if you find any difficulties doing this.. I hope this will help you to get it work. Plz vote for me..Dreamkam
May 27, 2010 | Computers & Internet
Failed to boot, i cant even get to the bios! only the fan running, led(green) and (red) indicator doesn't even light.
Dear Client, unpluged all the data cables, power cables or wires, bios cell and RAMs. Everything should be unpluged from the motherboard for two hours and then reassmbled. It will work properly but when you reassembled it just plug with the follwing devices.
* Power Cables
* Data Cables
* Bios cell
* Processor + Fan
* RAMs
Do not attach CD-Rom or Hard Disk, just turn on the computer without Hard Disk and CD-Rom and try to enter in bios setup. I assure your problem will be solve. Now you can attach the CD-Rom and then try to boot up from the CD-Rom and in the last you should try to attach Hard-Disk. I hope you will do it step by step and get success.
Good Luck
Feb 14, 2010 | Asrock 775i65G Motherboard
Cannot get new Motherboard to boot up in Normal Mode
what u may have done is wwhen u were installing the new board, gave a static shock to the system...that will cause only the fans to come on and nothing more...this is a bad problem bc u cannot fix it...if u figure out something else is wrong, and it gets fixed, let me know
Jun 20, 2009 | Gateway Computers & Internet
I have no POST or screen power when I turn on the laptop
Try this.
Remove the main battery and power the laptop up - if it works connect the battery - no need to shutdown.
Next thing to try.
Remove the main battery and the BIOS battery wait 1/2 + hour, insert BIOS battery but not main battery - power up, configure BIOS Date & Time setting if OK connect main battery.
If none of this work, you have a large paper weight.
You can salvage the hard disk and insert it into an USB hard drive adapter case and use it as an external USB hard drive.
Apr 14, 2009 | Gateway M285-E Notebook
Acer Aspire 5520 boot problem power on linght blinks
If you can't get past the bios boot then likely its a problem with the bios settings or a hardware issue on the motherboard. Make sure the processor fan is running when it turns on.
Feb 23, 2009 | Acer Aspire 3100-1405 Notebook
Upgraded computer and won't come on, no bios.
disconnect all and reconnct it.something jammed .may be *********** bord circuit is ground.
disconnect hdd ram then try.
to reattch one by one.
try with only smps ,mother bord and ram.
also check processor sitted correctly.
Nov 24, 2008 | MSI MS-6734-10 (-6734-010) Motherboard
New asus m3n72-d motherboard bios will not post
If you don't already have a case speaker hooked up to the board, you might want to connect one since there isn't an on board speaker and you will not hear error beeps otherwise.
Also, if you have another non-phenom AM2 processor handy you should really update the BIOS to latest release. Many late model Phenoms will not work on motherboards that have earlier BIOS releases and you will not be able to post. You should then choose "Set Optimized Defaults" and save the bios without any changes then shut down (not reset). When you power on again it should post and you should be able to get into the BIOS.
A third thing you can try (after you get a case speaker hooked up) is using a cheap pair of ddr2-6400 RAM to get the board to post so you can get into BIOS and change the voltage to the correct settings for your RAM if it requires a higher voltage than the bios expects.
Aug 23, 2008 | Intel Motherboard
GA-MA790FX-DQ6 Mobo not POSTing Should i reset the bios??
no beeps, indicates you have faulty CPU or mainboard.
  • remove all components even RAM and CPU.
  • insert only CPU and Speaker (without RAM or any other componet).
  • Boot and try to hear, there must be long beep for missing RAM, if not then try to re-insert the CPU or change the CPU/Mainboard.
Thanks and Good Luck
Iqbal
May 14, 2008 | Gigabyte GA-MA790FX-DQ6 AMD Phenom Socket...
Emachines 1900+ gets power to the monitor and computer but wont boot
There could be a number of causes. Do you hear any beeps when the computer starts up? Try seating all the chips in the motherboard. That means, apply pressure to each individual chip on the motherboard with your finger or thumb. The goal is to make sure each chip is securely attached to the board. Sometimes, heat or new h/w installs partially "pop" some of the chips out of the motherboard - causing the circuitry to be disconnected...
Aug 03, 2006 | E-Machines eMachines Refurbished EMA...
HP Compaq nc6220 Notebook Logo
253 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
