Question about Olympus Camedia C-765 Digital Camera
Card cover open appears on screen despite it being closed. Tried removing card and battery replacting and powering on. No luck
My c-765 camera screen states card cover open, when it is securely closed. I have tried taking out the battery and card and replacing them and then powering off but that does not work. Thanks for your help.
    President:
  • 919 Answers
The problem you are describing is a problem with teh sensor in side the card cover door. It seems to have failed and needs to be replaced. Following are the instructions to send your camera to Olympus for service.
http://olympusamerica.com/cpg_section/cpg_servicerepair.asp
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $149 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
Posted on May 08, 2009
Canon ixy 50s
The manual o page 157 says : Lens will not retract. Do not open the memory card/battery cover while the power is on. After closing the memory card/battery cover, turn the power on then back off (pp. 17, 18).
If that does not work the first time, while he camera is off, remove the battery. wait a minute and reinsert the battery. Close the card / battery cover and switch on again.
unless there is a mechanical problem, this should solve the problem.
Mar 06, 2014 | Cameras
How to remove memory card from camera
Confirm the power-on lamp and the monitor are off and open the battery-chamber/ memory card slot cover. Be sure to turn off the camera before opening the battery-chamber/memory card slot cover.
Removing Memory Cards 1 Before removing memory cards, turn the camera off and confirm that the power-on lamp and monitor are off. 2 Open the battery-chamber/memory card slot cover and press the card in to partially eject the card. 3 The card can then be removed by hand. Do not attempt to remove the card at an angle.
Insert the memory card.
4 Slide the memory card in correctly until it clicks into place. 5 Close the battery-chamber/memory card slot cover.
Oct 08, 2011 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
I have to reset date time etc everytime i turn camera on
If the Date/Time menu appears when the camera power is turned on, the date battery charge is low and the date and time settings have been lost. Please purchase a lithium coin battery (CR1220) and replace it as follows.
1. Confirm that the camera power is turned off.
2. Slide the memory card slot / battery cover lock and open the cover.
3. Hook your nail onto the date battery holder and lightly pull up.
4. Remove the battery holder in the direction indicated by the arrow. a570isbackupbatremove.gif 5. Remove the battery by pulling it up in the direction indicated by the arrow.
a570isbackupbat.gif 6. Insert a new battery with the (-) side facing up.
7. Replace the battery holder and close the memory card slot / battery cover.
8. When the Date/Time menu appears set the date and time.
Feb 05, 2011 | Canon PowerShot A590 IS Digital Camera
Have an Olympus Stylus Tough -6000 digital camera and when I turn it on a message appears on the screen that says "card-cover Open" and it won't allow me to operate the camera. The problem is...
remove the batteries and the card from the camera and clean it with something smooth and dry ...after that reinsert the card in th ecamera several times until it is recognised..this happens when the card it is not proper inserted ..or something is meesing with the sensor that detects the cover position...so a gentle cleaning inside will help also..
Dec 21, 2010 | Cameras
I have put fresh batteries in my Canon Power Shot S1 camera and it still will not come on? Can you help me?
Contact failures may have occurred between the camera and the batteries.
Confirming that the [Memory Card / Battery Cover] is securely closed
If the [Memory Card / Battery Cover] is not securely closed, the power of the camera may not turn on.
Close the [Memory Card / Battery Cover] securely, and then turn the power on.
Clean the battery terminals with a dry cotton swab that has a fine and soft tip, and then re-insert the batteries.
If your camera uses four AA-size alkaline batteries supplied with the camera, follow the procedure below. In addition to Alkaline batteries you may use optional nickel metal hydride (NiMH) batteries.
1. Be sure that the camera power is off.
2. Slide the battery cover lock in the direction of the arrow, and push the battery cover slightly forward. Then open the cover.
batts_step1.gif 3. Insert the batteries as shown.
batts_step2.gif 4. Close the battery cover.
batts_step3.gif * For the PowerShot S2 IS, PowerShot S3 IS, and PowerShot S5 IS the batteries are inserted in a slightly different order, please refer to the decal inside the battery door for the correct order.
Installing batteries in cameras with 2 batteries. If your camera uses two AA-size alkaline batteries supplied with the camera, follow the procedure below. In addition to Alkaline batteries you may use optional nickel metal hydride (NiMH) batteries. Please see the various examples to find which type matches your camera.
Example 1:
  2. Slide the battery/memory card cover lock in the direction of the arrow (1.gif), and press down while opening the cover (2.gif).
  3. Insert the batteries as shown and close the battery / memory card cover.
Example 2:
  2. Slide the battery cover lock in the direction of the arrow, and open the cover.
* For the PowerShot A300 and PowerShot A310 the battery polarity is reversed.
Dec 05, 2010 | Canon Cameras
Card cover open
The problem you are describing is a problem with a sensor that is on the card cover door. It seems to have failed and needs to be replaced. Following are the instructions to send your camera to Olympus for service.http://olympusamerica.com/cpg_section/cpg_servicerepair.aspOlympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $124 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
Jun 11, 2009 | Olympus FE-190 Digital Camera
Nikon Coolpix P4 - no power after little piece between battery and SD card ...
the little white peice is what holds ur battery cover closed i think, so without a closed cover it cant really function. i think so anyway
Jun 12, 2008 | Nikon COOLPIX P4 Digital Camera
Camera not turning on
The Same thing just happened to mine said my card wasn't formatted, tried several card with no luck, the tell me too much money to have looked at $150 min they say buy a new camera. Always get extended warranty for 2-3 years the 49.95 is worth it in the long run.
Aug 16, 2007 | Pentax Optio 33L Digital Camera
Camera powers up but lens cover fails to open
It could be some grit or sand causing the lens cover to not open, so the camera won't initialize. Try cutting a slip of paper narrow enough to slide between the lens opening frame and the lens cover. Move it in and out to clear any grit that might cause the spring-loaded cover to bind. Good luck !
Dec 14, 2006 | Sony Cyber-Shot DSC-P41 Digital Camera
Olympus Camedia C-765 Digital Camera Logo
114 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
