Question about Canon imageCLASS MF8450c Color Laser All-In-One Printer
My printer show insert black toner correctly
New toners just won't the screen says instal black toner correctly
SOURCE: toner not set insert toner message
The problem is with the paper tray not the toner, believe it or not. Take all of the paper out of the tray and then reinsert the paper into the tray. It should then work fine.
Posted on Mar 19, 2008
  • 22 Answers
SOURCE: toner replacement
When this happens it is usually because the paper has misfeed remove paper from cassette tray replace it then reseat toner.
Posted on Apr 23, 2008
SOURCE: toner
I had the same problem with this printer. And I think I got the problem solved by removing the all paper from the paper tray, and re-inserting the toner cartridge. I think it is the problem with incorrect error message from Canon's printer. It is problem of paper being fed into the printer mechanism slightly.
Posted on Sep 12, 2008
SOURCE: no toner cartridge
same problem!
Posted on Oct 23, 2008
  • 385 Answers
SOURCE: "Toner not set" persists, even though new
Hey!This happens a lot!Take out all of the paper,Open the cover,take out toner,put it back and add paper!!If this does not work then the toner sensor might be faulty!Good Luck!!
Posted on Nov 03, 2010
Toshiba e-studio 211 copier .Toner sign not remove please halp me anwerali78@yahoo.com
Machine shows "Toner not Recognized" when correct toner is inserted into MFP.
It can be due to main PCB faulty.
May 28, 2011 | Toshiba Office Equipment & Supplies
Lexmark c534dn unsupported cartrige
This error message appears on the printer screen when the printer thinks the wrong toner cartridge is installed. To clear it or identify a service requirement, follow the steps below. NOTE: If you succeed in resolving the problem at any stage during the procedure, you not need to perform the remaining steps.
  1. Open the top front cover of the printer. If the display DOES NOT read Close cover or Insert cartridge, the 32 error is not caused by the toner cartridge and printer service will be required to fix the problem.
  2. Make sure the correct toner cartridge is installed for this printer model.
    1. Check Lexmark for a list of compatible cartridges for your printer.
    2. If the wrong toner cartridge is installed, remove it and install the correct one.
  3. If the correct toner cartridge is installed, it may not be seated correctly. To ensure that this is not the cause of the error, do the following:
    1. Turn off the printer.
    2. Reseat the toner cartridge.
    3. Close the lid.
    4. Power the printer back on and check the display.
  4. If reseating the toner cartridge does not clear the error message and the error started as soon as you installed this particular toner cartridge, the cartridge may be broken. You can check this as follows:
    1. Power off the printer and then reinstall the old cartridge. (You can also try a different new cartridge to see if that clears the error.)
    2. If the error does disappear, the problem may lie with this cartridge. Please contact the point of purchase, especially if the cartridge is brand new out of the box.
  5. If the error cannot be cleared by putting in a new toner cartridge or one that is known to be working, the printer may require service to fix the problem.
Feb 15, 2011 | Lexmark C534dn Laser Printer
Se puede resetear el contador de los tambores de la oki c3400n
Trata esto:
When installing the C3400n printer, or when replacing the toner cartridge, be sure to fully insert the toner cartridge into the image drum, and make sure the blue lever is pushed ALL THE WAY toward the back of the printer (fully locked position). If it is not fully closed (locked), a "toner sensor" or "toner empty" message may result. Note: (Picture at bottom shows incorrect position of locked toner cartridge that may result in either of these messages).
Installation Procedure of Image Drum and Toner Cartridge:
          0.408?openelement&fieldelemformat=gif
    >> Insure the toner is fully locked, see photo below showing the correct and incorrect positions of the locked toner cartridge.
CORRECT (Fully rotated to lock position)
    91.28a2?openelement&fieldelemformat=gif
INCORRECT (Not fully rotated to lock position)
179.32a2?openelement&fieldelemformat=gif
Dec 01, 2010 | OKI C3400n Laser Printer
I wish to replace the black toner cartridge in the Dell 3010cn. How do I gain access to it. There is easy access to the cyan cartridge at the moment
if you want to replace black one only you should follow these steps Install or replace the toner cartridge while the printer is on (if the power is not on, the cartridge carrier does not rotate).
1. After confirming the Insert Yellow Toner(Y) message, open the front door.
2. Hold the tape on the protective cover and pull it forward to remove the cover from each cartridge slot.
NOTE: You need to remove the protective cover only the first time that you install the toner.
NOTE: Dispose of the protective cover after you remove it.
NOTE: The protective cover is attached to each toner cartridge mount.
3. Make sure the color of the toner cartridge matches the slot on the toner cartridge carrier. The order is Y, M, C, K. Gently shake the cartridge to distribute the toner evenly.
4. Lift the tab up 90 degrees and pull the toner seal straight off, keeping it parallel with the toner cartridge.
5. To insert the toner cartridges, align the arrows on the cartridge with the corresponding arrows on the printer. Guide the cartridge in until it snaps into place and then push down the handhold to lock the cartridge in place.
6. Close the front door.
NOTE: Make sure the toner cartridge is installed correctly. Otherwise, the front door cannot close firmly.
7. The toner cartridge carrier rotates to the next empty slot. When the color of the newly inserted cartridge appears on the display, followed by the Insert message, insert the next toner cartridge.
8. Repeat steps 1 through 7 when inserting the remaining cartridges.
plz do rate the solution if got help
Nov 25, 2010 | Dell 3010cn Laser Printer
Unable to remove black cartridge, it is really stuck. Help
I just changed my black toner this past week, and finally figured out why the cartridges get stuck like this.
First, you must eject the toner cartridge on the front-panel menu:
Menu->Replace Toner->Eject Toner->Black(K)
It will say "Rotating to Black Toner(K)" and then say "Black Toner(K) Ready to Eject"
Now, open the front panel and you'll see the black toner cartridge in front. You can also open the top panel if you want more light on your work area.
Lift the lock handle on the old toner cartridge to the "unlock" position, and here's the part that the Dell instructions don't have:
There are two channels for the toner cartridges -- one on each side. Run your finger down the channel on the right, and you'll feel a small, spring-loaded catch. This catch often gets sticky and won't release the cartridge without some help. Don't force it, but gently move it towards the back of the printer and it should release.
Now the old cartrdige should slide right out, and you can finish per the instructions that came with the new cartridge.
Jan 27, 2010 | Dell 3100cn Laser Printer
Printer is a Samsung CLX 3175FN. It says the
To run a quick check on your black toner, insert your old black toner back to the printer.
press on the menu button -> system -> report-> supplier info-> print. and same for your new toner, if it show u both the old n new black toner are under the same serial number. the new toner might be faulty. Invalid toner detected.
get the new toner with the box packing back to the shop for replacement.
Oct 02, 2009 | Samsung CLX-3175FN Color Laser All-in-One...
Won't recognize toner cartridge
go to: www.fixyourownprinter.com
the solution is to reprogram the eproms on the cartridges, easily done.
Dec 17, 2008 | Samsung CLP-510 Laser Printer
543k toner sensor error
Your indication regarding the 100% does not necessarily indicate a damaged chip (sensor).
Many chips do not work by actually sensing the toner but by usage or other tricks.
We cannot be sure about what happened but replacing the drum and affected items
should solve the problem. Needed parts may be found at
http://www.inkfilling.com/toner-refill-OkiData--C5800Ldn.html
Jan 21, 2008 | OKI C5800dn Laser Printer
Black Toner replaced
Replace Toner with gen cartridge.
Or Take cartridge back as faulty after checking that it was opened and installed correctly.
Check display on printer for indications that maybe it needs one of the 3 colour toners indicators are Y,C or M
K is black
Oct 20, 2007 | Epson Aculaser C1100 Printer
Canon imageCLASS MF8450c Color Laser All-In-One Printer Logo
699 people viewed this question
old marine
old marine
