Question about Frigidaire NLPWD15W Front Load Stacked Washer / Dryer
Nlpwd15 dryer 3 beep and control lock
CONTROL LOCK GE GAS DRYER
  1. Press and hold for 3 seconds the "Control Lock/Unlock" button on the control panel to lock the control panel.
  2. Listen for a double beep and observe the "Control Lock" status light is lit when the control lock is in effect.
  3. Press and hold for 3 seconds the "Control Lock/Unlock" button on the control panel to unlock the control panel. The "Control Lock" status light is goes out when the control panel is unlocked.
Jan 31, 2015 | GE Dryers
Maytag dryer epicz says "controls
controls locked
This feature allows you to lock your settings to prevent
unintended use of the dryer. You can also use the Control Locked
feature to prevent unintended cycle or option changes during
dryer operation.
To enable the Control Locked feature:
Press and hold AUTO DRY LEVEL for 3 seconds. Control Locked
glows and a single beep tone is heard. To unlock, press and hold
AUTO DRY LEVEL for 3 seconds. The indicator light turns off.
Jul 15, 2011 | Kenmore Elite HE4 Electric Dryer
The controls locked is displayed. what causes this and how do i get the controls unlocked.
Jan 11, 2011 | Whirlpool GEW9250 Electric Dryer
Control locked
If you want to enable the Controls Lock/Unlock Feature:-
To enable the Controls Lock feature when dryer is running: Press and hold the CONTROLS LOCK/UNLOCK button for 3 seconds. The control is locked when a single beep is heard and the Controls Lock status light is on. This feature allows you to lock your settings to avoid unintended use of the dryer. You can also use the Controls Lock feature to avoid unintended cycle or option changes during dryer operation.
■When the dryer is off, it is not necessary to press the Control On button before activating the Controls Lock feature.
For unlocking: Press and hold the CONTROLS LOCK/UNLOCK button for 3 seconds to turn this feature off.
NOTE:- When the dryer is running and Controls Lock is on, the dryer can be stopped by pressing the Pause/Cancel button, but cannot be restarted until the control is unlocked.
Good Luck and have a nice day
Rating the solution is highly appreciated.
Jun 29, 2010 | Whirlpool GEW9250 Electric Dryer
Control lock on
To enable the Control Locked feature when dryer is
running:
Press and hold the CYCLE END SIGNAL button for 3 seconds.
Locked status light is on.
On button before activating the Control Locked feature.
To unlock:
Press and hold the CYCLE END SIGNAL button for 3 seconds to
NOTE: When the dryer is running and Control Locked is on, the
dryer can be stopped by pressing the Off button, but can’t be
Jun 01, 2010 | KitchenAid KGHS01P Gas Dryer
How do you turn off the control locked key?
running:
Press and hold the END OF CYCLE SIGNAL button for
the Control Locked status light is on.
To unlock:
Press and hold the END OF CYCLE SIGNAL button for 3 seconds
can’t be restarted until the control is unlocked.
May 29, 2010 | Whirlpool GEW9250 Electric Dryer
Control locked light is on
dryer operation.
running:
To unlock:
Here is a manual.
Apr 10, 2010 | Whirlpool GEW9200L Electric Dryer
Machine is stuck in control lock
This feature allows you to lock your settings to prevent unintended use of the dryer.You can also use the Control Locked feature to prevent unintended cycle or option changes during dryer operation.
To enable the Control Locked feature when dryer is running:
Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Locked status light is on.When the dryer is off,it is not necessary
to press the Control On button before activating the Control Locked
feature.
To unlock:
Press and hold the END OF CYCLE SIGNAL button for 3 seconds to turn this feature off.
NOTE:
When the dryer is running and Control Locked is on, the dryer can be
stopped by pressing the Pause/Cancel button,but can't be restarted
Apr 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Controls locked status light stays on and dryer cannot be used
To enable the control lock feature:
Press and hold the CYCLE SIGNAL button for 3 seconds. The
CONTROLS LOCKED icon lights up, and a single beep tone is
heard. To unlock, press and hold the CYCLE SIGNAL button for
Jul 11, 2009 | Dryers
Whirlpool dryer is locked control locked.
the controls on our unit can be locked by holding a button for 3-5 seconds.
look on the control panel for a "paddle lock" symbol next to one of the buttons. cant tell you which one as they do change from year to year.
just find the right button and hold it in for a few seconds. then it will beep and should unlock after that.
Jan 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire NLPWD15W Front Load Stacked Washer / Dryer Logo
16 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
