Question about Qca Spas Majestic Series Aruba Xl Hot Tub
Aquatherm at600 pool &spa heat pump only heat spa to 85 degrees
My apollo spa galaxy II D20Nj will not heat past 85 can you tell me what I should do or part to get to fix this serial #BSJLJEG
make sure spa setting is at 104 degrees if at 104 degrees see control system if ok change temp sensor either in heater or control unit
Dec 07, 2013 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Aquatherm pool heater
make sure it is connected to the solar to get it to work
Jan 06, 2013 | Jandy Digital PoolSpa Control w Actuators...
I've had my Raypak SpaPak (smaller model) for about 2 years. It seems like it doesn't seem to heat the water as hot as it used to - I need to turn the dial to a higher setting to bring the pool up to...
If you do not keep close watch on your water chemistry, depending on your location , you could have a large calcium build-up or salt build up on your electric heating element. Also, these models are meant for spas, and depending on the weather in your location, the heater might have trouble keeping up.
Mar 23, 2011 | Raypak SpaPak Spa & Hot Tub Electric ...
Why is it in economy mode when I want it at 104 degree and get into it?
In economy mode the spa is only going to heat up during a "Filter cycle" Check your manual and set the spa into "Standard Mode" so when you bump up the temp. on the topside control, the pump should kick on & the spa should heat up.
depending on your spa you may have a "Mode" button that will fix this or you might have to press two control buttons at the same time. Your owners manual should explain this.
Good Luck!
Feb 11, 2011 | Qca Spas Dream Series Dream Master Hot Tub...
SPA WILL NOT HEAT PAST 94 DEGREES. i HAVE IT SET TO 103 AND IT HAS NOT MOVED PAST 94 DEGREES FOR OVER 1 HOUR EXACTLY WHAT BUTTONS SHOULD BE LIT ? IN OTHER WORDS IS THE AIR BLOWER LIGHT SUPPOSED TO BE...
if hook up to the firemans switch turn heater all the way to 104 degrees if using 4 pin connector for aqua link to heater set spa temp to 104 and make sure on aqualink spa heat is enabled and 104 degrees
Nov 30, 2010 | Jandy Aqualink Rs4 One Touch Control...
Aquatherm pool heater runs but not heat up
Did you replace the dryer on the unit?
Oct 27, 2009 | Heating & Cooling
Hi, I have a minimax 400 heater it will only bring the spa up to 85 degrees, the power light and temp light are on.
generally if you can only reach a temp of 85 or so you may have an oversized pump and the water is flowing too quickly through the heater. it may be necessary to install a manual bypass on the heater plumbing to divert the water enough to slow the flow through the heater down
Jun 11, 2009 | Pentair MINIMAX NT TSI IGNITER
Spa will not heat more than 85 degrees or so
on the back of the board is the bottom for seting the max temp follow the intruction from the manual or get one at jandy.com
May 26, 2009 | Jandy Laars Lt 400,000 Btu Heater
Minimax pool heater cuts out at 91 degrees when remotely set for
Turn the temp set knobs on the front of the heater all the way up do both pool & spa temp.
If that doesn't help flip the selector switch on the front of the heater the pool temp. This switch doesn't control what heats up Pool or spa it just selects the heater on and which thermistat to use
May 23, 2009 | Pentair Minimax Ch 400,000 Btu Propane...
Qca Spas Majestic Series Aruba Xl Hot Tub Logo
22 people viewed this question
Top Qca Spas Pool & Spa Experts
Ian Kime
Ian Kime
byrdhaus188
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Qca Spas Pool and Spa Expert? Answer questions, earn points and help others
