Question about Watches
Tghk 91-733 watch instructions
How to set date
  • 4 Answers
SOURCE: Setting time & date on Philippe Starck Fossile watch ph1080
hold the left, bottom button (marked ....) for a few seconds....then press the top right button (marked with 1 dot) to change between the hour, minute, date etc. use the bottom right button to advance the flashing number, and when finished setting time and date, use the bottom left button to stop the numbers flashing and return the watch to normal. hope this helps, this is also how to change the date for the other question asker (works on 2 other starck/fossil watches i have and i assume the controls are the same).
Posted on Dec 02, 2008
disap1
  • 98 Answers
SOURCE: Need to set time on WalMart TGHK watch.
If its digital that makes it more difficult to give setting directions online. Need to know the exact model #. I would do a google search to try and find your watch and you might find a manual online. OR you could seek out a local watch repair business and they should be able to set it with no problems. Most Sears have a watch repair kiosk in their stores! I woudlnt take it back to Walmart because they are just sales people! They have limited watch knowledge!
Posted on Jan 09, 2010
SOURCE: Watch setting instructions SEIKO 7N43 8A39 "A1"
If you are still wondering about this, pull the knob out to the first click. turn one way to set day, turn the other way to set date. Pull out further to set time.
Posted on Mar 09, 2010
  • 6 Answers
SOURCE: My TGHK watch is stuck in ''Military Time''...
advance the hours. The first time you go through the 24 hour cycle, it will be in am pm mode, the second time in 24 hour mode, the next time in am pm. Just keep advancing the hours until it comes up the correct time
Posted on Jul 16, 2010
fairyandtrol
  • 50 Answers
SOURCE: Need instructions for setting a Sharp watch model # 2092
All the settings seem to go through the start/stop button. If you hold it down for 3 (not 2, not 4, but 3) seconds, it toggles in and out of "set the watch mode". You can tell you are in it because the seconds at the bottom go all blinky. Use (quick press) start/stop to move from seconds, to minutes, to hours, to year, to month, to day. Mode subtracts, reset adds. To set alarms, etc, first put the watch into Alarm Mode (Mode button, again).
Use the reset button to move to the selected alarm (1-5).
Hold the start/stop button for 3 seconds to toggle into "set the alarm mode".
Quick press of start/stop moves between things to set (kind of alarm, hours, minutes).
3 second hold of start/stop takes you out of setting mode.
Posted on Nov 06, 2010
Tip
TGHK watch instructions
This is not for Tag Heuer, it's for TGHK watches.Here's the procedure: Press the MODE switch to step through the modes until you see the seconds blinking (righter after the ALARM set mode). Press the RESET switch to advance to the function you want to change (e.g. hours). Press the START switch to increment the hour to the correct time. Press the RESET switch to advance to minutes and, again, increment the setting using the START switch. (Hold the switch down to advance the numbers rapidly.) When you have stepped through all the elements and have everything as you want it, press the MODE switch once to return to normal time display. To set the ALARM: Press the MODE switch to display the alarm function. Press RESET once to see the hours blinking. Press the START/STOP switch to advance to the desired hour. Press RESET to advance to the minutes and set the minutes using the START/STOP switch. Press the RE#SET switch. The time will stop blinking. Set the alarm sound for either ALARM or CHIME using the START/STOP switch. Press MODE to return to the time display. To turn the ALARM off: Press the MODE switch to advance to the alarm mode. Next to the AL indicator there will be either a small ALM or CHI displayed. Press the START/STOP switch until they both are off. Press MODE to return to the time display.
on Mar 18, 2010 | Watches
How do I get my TGHK watch off of military time?
Try Googling (TGHK)(model) (manual) without parens to get instructions.
Apr 23, 2017 | Watches
How to turn off chime on TGHK AW-77-004 watch?
Google (TGHK)(AW-77-004)(manual) without parens for instructions.
Nov 08, 2016 | Watches
How do I changed the date on my wrist watch, TGHK AW 91-731, without changing anything else.
You can experiment.most digital displays need you to hold the top button in for 3 to 5 seconds to get it to start flashing then use the other button to scroll through each part of the menu and adjust up or down each number and Date.finally when you are happy with the setting just press top button again for 3to5 seconds.
Feb 01, 2016 | Watches
I have a TGHK A 91-729 that is currently set to military time. No instructions came with the watch. How can I get this to civilian time please help!
hit mode three times until TUES flashes and the seconds. Hit reset until the hours flash and hit start to change them. The watch goes from AM hours to PM and then back through AM and when it cycles through the PMs for the second time, they will alternate 12/24 hour time.
Mar 21, 2015 | Watches
SETTING DATE JUST ROLEX
After you unscrew the crown it is already in winding position. If you pull the crown, it will go to the date setting position. Further pull of crown will set it in time setting position. Try to pull the crown till you get it in correct date setting position and change the desired date. Do not use the date setting between 10pm - 2am, as this can damage date mechanism. The best way is to pull out crown to the time setting position and set the time to 6.30(anytime) and then push the crown in to date setting position and change the date to the previous day's date. Then again pull the crown out to the time setting position and advance hands forwards (clock wise) till hands pass 12.00 (midnight) and the date changes automatically to the desired one, then adjust the time, push the crown fully in and screw the crown on.
Jun 01, 2011 | Rolex Lady Datejust 179173SRJ Watch for...
How do you set the time on an Armitron 165 wrist-watch?
Hi wtgillo,
Hi there I see that you are in need of assistance setting time on your Armitron Wrist watch.
I would be more than glad to give you details on how to, Please see steps below.
  • Your Armitron Watch will have Four Button on the side of the watches rim.
  • Button on the upper Left is MODE.
  • Button on the lower Left is LIGHT.
  • Button on the upper right is DATE.
  • Button on the lower right is Alarm.
See Steps below:
*Setting the time*
  • Press and Hold down the Mode Button til the Hours flash
  • Then push Alarm Button to set the Hours
  • Press and Hold down the Date Button till the Minutes flash, then push D/Alarm Button to set the minutes
  • After setting the minutes on your watch, Press date till you get the month flashing push Alarm to set the month
  • Press the Date again till the Date flashes, then push Alarm to set date
  • Press the Date again till the Date on your watch flashes, then push Alarm to set the date
  • After setting everything push the Mode Button again just once to set everything or finalize your settings on the watch.
I hope that this will be of help regarding your query on how to set the time on your Armitron watch, I also included the setting of the time and date just for further details.
Have a nice day,
mvincentc
Apr 21, 2011 | Armitron Watches
Watches Logo
49 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
