Question about Hotpoint FFS70 Bottom Freezer Refrigerator
My ff187e hotpoint fridgefreezer has all lights flashing it seems to be working fine but lights are a little annoying! apart from meat seems nearly frozen? please help
  • 5 more comments
  • alanwilson3 May 10, 2009
    It is a hotpoint ffe187e the lights are flashing and the fridge is freezing my salad and meat even though thermostat on low. Thanks for your help
  • alanwilson3 May 13, 2009
    Thanks for your reply it is much appreciated. Basically my fridge has started freezing my food this happened not long after I first used the quickcool button before then I have had no need to use it. The refridgerator made a beeping noise and the 3 lights on the front 2 green 1 orange started to flash I checked it out the noise stopped but the lights still flash. It has now started freezing my food, I have defrosted it and cleaned everything but nothing has worked. I am reluctant to contact hotpoint although I have made a general enquiry as to the best course of action because they have a bad reputation. Sorry for nit being clear before I really appreciate your help. Many Thanks
  • alanwilson3 May 16, 2009
    Hi thanks for responding I am unable to find you are you in uk?
  • Mark Nichols May 11, 2010
    i wish i could send you a link to my website and get then number off of there to give me a call but they will ban me if i continue to do it but if you search for whirlpool parts i have the word surplus in the link find it and i can help you further.
    find where the cold control is, make sure all connections inside the box are fine, and take continuity on the switch to see if it is open when its on and off.
    not a good model number please find it and give it to me
    what u mean nearly frozen? i will look into it but you have have to change the main control board...
5 Suggested Answers
  • 8 Answers
SOURCE: hotpoint fridgefreezer FFS70
if you have no cooling at all it means that a no gas charge b locked  in defrost c thermostat d compressor not working
Posted on Oct 31, 2007
SOURCE: hotpoint ultima fridge freezer
It's just simple.Keep the refrigerator open for few days with power on.After when the electricity bill comes,eveerything will be cooled.
Posted on May 28, 2008
SOURCE: Hotpoint Fridge Freezer FF187e - 3 lights flashing
i have just fixed my fridge freezer by following the instruction from KarenBa and GWoman i have also managed to stop the lights (super cool and super freeze) from flashing by turning the temperature to zero on both fridge and freezer so they turn off then holding both super buttons down for about 15 seconds then turning the temperature back up. hope this helps
Posted on Feb 24, 2009
  • 454 Answers
SOURCE: Hotpoint. Water is leaking from behind light bulb
The drain hose in the back of your freezer is frozen shut. The water you see is coming from the defrost cycle. Turn off the refrigerator. Remove the floor from your freezer and remove/thaw all of the ice. Locate the drain in the back of the freezer. It may be behind the back panel. Thaw the drain until water flows freely through it. Reassemble the freezer, and you are back in business.
Posted on Oct 23, 2009
Testimonial: "When back and bottom of the freezer were off there was ice everywhere. The drain plug was frozen. Thanks for the advice."
Hotpoint quadrio fridgefreezer
Sounds like the switch that controls the light is disconnected.
Gently pry the switch out(power off) and see that both wires are connected to the switch.
Feb 11, 2014 | Kitchen Ranges
Light on top of fridge keep flashing
Hi I found the hotpoint site, from there i found the manual for my fridge freezer.
Dec 08, 2009 | Refrigerators
The fridgefreezer has power but no cooling or freezing
Most likely there is low voltage to the unit or the compressor is bad. Is the condenser coil very dirty and if this unit has a condenser fan does it run?
Nov 10, 2009 | Hotpoint FFA90 Bottom Freezer Refrigerator
Flashing lights on hotpoint fridge
I have a hotpoint future FF187E both lights are flashing how can i stop them flashing ?
Aug 04, 2009 | Refrigerators
Ice in my fridge
Without seeing this I can't tell you a price or exact fault but the first free thing to try that could likely fix it. unplug the unit from the power and leave both the doors open for 48hrs so the unit is 100% defrosted then try again. cheers.
May 31, 2009 | Hotpoint RFA60 Bottom Freezer Refrigerator
Type hotpoint ff187e fridge section not cooling lights flashing
It is ice build up in the ducts in the fridge/Freezer section. If you switch off and let it defrost with doors open for 24hrs all will be OK. I have just paid £100 for a call out just to be told this solution to the problem which is something that should be in the inst. manual or told when reporting this fault to try first. One big con from Hotpiont.
Apr 04, 2009 | Refrigerators
My hotpoint ff187e fridge/freezer keeps bleeping and flashing how can i fix this? it is only 18 months old.
Turn the second knob at the top to off (freezer knob) turn the fridge freezer off. Then turn it back on. That may sort it. Or you may need to totally defrost the machine as there could be some ice blocking some vents. May need to remove the back panel of the freezer for this (inside).
Jan 31, 2009 | Freezers
Ice in my fridge
you have a bad condensor or the regulator is malfunctioning
Oct 06, 2008 | Refrigerators
Hotpoint ultima fridge freezer
May 28, 2008 | Hotpoint FFA60 Bottom Freezer Refrigerator
Hotpoint FFS70 Bottom Freezer Refrigerator Logo
101 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
