Question about Mitsubishi WS-65311 65" Rear Projection HDTV-Ready Television
Double and triple exposure on screen on left side
I have a 65" mitsubishi big screen and it has double and triple exposure on the left side of picture. Any banner that is displayed across the set is in a concave setting. Is there anything I can do to correct this problem or am I going tyo need a repairman?
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 453 Answers
Bad convergence ic , normal repair cost $300 - 450
Posted on May 08, 2009
Mitsubishi LCD #LT40148--left side of screen has vertical lines.
I would guess a sustain or similar board---one for each side of the set and typical shop repair will exceed 200 parts and labor
Mar 17, 2012 | Mitsubishi LT-40148 40 in. LCD TV
Double vision on Mitsubishi Model #4544
resolder the convergence Ics that will most likely solve the issue. If not you will need new Convergence Ics
Feb 02, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Double picture & color problem
see if the mirror in side is broke or cracked
Jan 22, 2009 | Sony KP-53XBR45 53" Rear Projection...
Left side of screen going yellow and pink with leters in double
The convergence modules have gone bad Along with the new parts kit are fuses, diodes, and resistors that usually fry when these modules go bad. Depending on the model, there will be two and sometimes 3 of these modules that have to be replaced. Each module has 50 pins each that have to be soldered, so unless you have experience with complicated TV repairs, the cost to do that repair may be as much as a flat screen TV of the same screen size as yours.
May 12, 2017 | Mitsubishi WS-65711 65" Rear Projection...
Double vision on my Mitsubishi 46 inch width screen--TV is 5 years old
any repair shop can re converge the tv for you.id do some calling arond and get a few quotes to see what it would cost to have them come to you
Oct 09, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Replaced Convergence but pictures still display with double images
i went to converge my mitsubishi ws 73903 and the blue line wont go down to match the other ones
Oct 09, 2008 | Mitsubishi WS-73903 65" Rear Projection...
Picture problem on mitsubishi medallion ws 55819 model....picture convergence messed up on left and right side of screen (center fine)...problem goes away and set "re-adjusts" after it's been turned on for...
Well I have a Mitsubishi WS-65413 65 in. Rear Projection Television and when I power it on in the morning it looks as if the picture on the bottom of the screen is bending and parts of the picture "double up" but like the person above me said after it gets warmed up it goes back to normal but every 3 or 4 hours it might get messed up for a min...Anyways: Is it the picture tube going out?? If so how does anyone know how much it would cost to repair/replace & What is a "Convergence Module"?? I don't know if my T.V has one of those or not but if it doesnt is that the problem perhaps?? Please help me or ill be forced to go outside... :-( ..... thanx 4 the help ppl!! -
- Zachariah-
May 10, 2008 | Mitsubishi WS-65413 65" Rear Projection...
Need to change ring on fax to 3 rings. it is an hp office-jet 6110 all in one
  1. Press Menu .
  2. Press the right arrow (>) or the left arrow (<) until Advanced Fax Setup displays.
  3. Press Enter .
  4. Press the right arrow (>) or the left arrow (<) until Answer Ring Pattern displays.
  5. Press Enter
  6. Press the right arrow (>) or the left arrow (<) until the desired ring pattern displays.
    • Single rings – The fax machine answers after a single ring.
    • Double rings – The fax machine answers after a double ring.
    • Triple rings – The fax machine answers after a triple ring.
    • Double and triple – The fax machine answers after a double and triple ring.
    • All rings – The fax machine answers any ring. This is the default when not using Distinctive Ring.
  7. Press Enter .
May 09, 2008 | Office Equipment & Supplies
Big screen showing double and red ghost color
Go into your service menu and try to adjust the convergence, if it does not adjust, the IC's ( chips) are bad in that circuit. Call a local factory authorized dealer to service your tv. The cost should run around $450.00. Good luck.
Mar 29, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Problem with picture - "double exposure"
Your set has what is know as convergence problem and is a popular problem in the rear projection sets,the only way to correct the problem is by replacing the amplifiers in charge of aligning all 3 colors,your set might only use two amps for all 3 colors,The IC's(amps) are both the same number and they are mounted in heatsinks because they get hot,they have a number in the front that looks like this STK--- ---,they run about 25.00 each and replacing them can be difficult because they need to be unsoldered and removed without damage to the main circuit board ,then the new ones need to be soldered in,sometimes the new ones need to be aligned from the service menu so all three colors line up.If you are familiar with tv service you have now a place to direct your attention but if you are not too familiar be safe and call for assistance from a servicer.Let us know if you need more information.
Nov 07, 2006 | Mitsubishi VS-45609 TV
Mitsubishi WS-65311 65" Rear Projection HDTV-Ready Television Logo
108 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
