Question about GE Refrigerators
My ge refrigerator dial has no numbers just an arrow with a narrow end and a wide end which one is colder?
aborcass
  • 2651 Answers
SOURCE: To make the temp inside the refrigerator colder?
7 will be your cldest temp
Posted on Nov 02, 2008
  • 58 Answers
SOURCE: No temp gauge, 2 dials one w letters & descriptions; one with numbers?
can you provide me with a model # of your appliance? Depending on the model, the controls are different. email it to me at jordanaschmidt@aim.com and I'll follow up with you with fix. thks
Posted on Jun 25, 2009
  • 66 Answers
SOURCE: @15 yr old GE top freezer fridge. Top freezer
check to see if an internal fan is fitted. This may have stopped/ burnt out. if fan is running try 24 hr defrost.
Posted on May 17, 2010
heatman101
  • 43501 Answers
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on May 28, 2010
  • 1796 Answers
SOURCE: hello, are ge -gss25sgrss
Hi!!
The clicking noise you hear is the start relay, this is followed by a humming noise, that's the compressor trying to kick in unsuccessfully. The most common problem it is the start capacitor, located on the side of the compressor. Check on the back of the unit that the condenser coil is clean, if not, disconnect power to the unit and use the vacuum cleaner with the brush attachment, be careful with the coils, they bend easily, when you're done cleaning the coils, reconnect power to unit and notice if the condenser fan will kick in when you turn the temp. dial from 0 to 1 or 5, you already said the evaporator fan (inside the freezer is working).
If both fans are working, the evaporator coil is clean and the compressor won't start when unit is turned ON, let's begin by changing the start capacitor. $19.49 at Sears Parts Direct http://www.searspartsdirect.com/partsdirect/part-number/GE-Parts/Refrigerator-Parts/WR62X79/0046/363/Model-GSS25SGRFSS/0432/0165000?keySuffixId=NA&productTypeId=0165000&searchModelNumber=GSS25SGRFSS&subCompDesc=Sealed%20system%20&%20mother%20board&brandDesc=GE&modelDesc=REFRIGERATOR-R-SERIES&blt=11
Click on the following link http://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Refrigerator-Parts/Model-GSS25SGRFSS/0432/0165000/G0506716/00008?pop=true&blt=06&prst=&shdMod= for an exploded diagram of the location of the capacitor part 729 on diag. 1kbron_9.png
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Posted on Dec 15, 2010
Top of fridge freezing with temperature on lowest setting
You need a new thermostat but there are some things you can check in the link. 1 is the warmest setting.
Most refrigerator temperature settings are controlled with a dial or slider. They are sometimes labeled 1 through 5 or 1 through 9. If you are not sure what to set it to, then set it somewhere in the middle. If the dial is numbered 1 to 5 set it on 3, if the dial is numbered 1 to 9, then set at 4. USUALLY the higher the number on the temp control dial, the colder the temperature your refrigerator will get. If your drinks and food are not as cold as you like, set the temperature dial up one number higher. If it is at 3 and you want your food colder, set it to 4 and test 12-24 hours later to see if your food is at the temperature you want.
Why Is My Refrigerator Too Cold
Dec 18, 2016 | Refrigerators
Is the temperature "N" the coldest or "+ "the coldest?
N stands for normal. Usually normal is midrange while + is either colder (for more refrigeration) or warmer (for higher temperature). Check the end of the scale for the word , coldest. There will typically be arrows pointing toward colder/est as well. Best would be to move the dial just one (hopefully an) increment and come back 24 hours later and check for a decrease on the thermometer (yours or the reefers built-in one). If it moves the wrong way (assuming constant ambient temperature) try dialing the other direction. .
Nov 02, 2014 | Refrigerators
The dial on my water c ooler has a +and -which is colder?
My guess is that moving the setting in the + direction makes it colder. My refrigerator uses numbers; the higher the number, the colder it gets
Apr 22, 2013 | Refrigerators
Refrigerator freezes food in back
You can always turn down the intensity of the chiller. There should be a dial on the roof of the fridge part, the higher the number, the colder it will get. There's usually a small vent from the freezer to the fridge, and it's generally in the back of the fridge. Plus it stays colder there than in the door or front of the fridge.
Oct 22, 2012 | GE Profile Stainless Bottom-Freezer...
Is the dial to adjust temp coldest set at low numbers or high number?
The dial inside the fresh food compartment, the bottom compartment
set to middle or above (higher numbers mean colder). Usually 5 to 9 if it has numbers.
Freezer knob in the middle if it has one. (If you set a freezer knob to "colder" it cuts
off the cold air to the lower compartment). Hope this helps
Jun 29, 2011 | Kenmore Top Freezer Refrigerator
WONDERING WHY MY GE GSS22SGRB SS REFIGERATOR ISN'T GETTING COLD, ALTHOUGH THE FREEZER SEEMS TO BE WORKING PROPERLY.
you should have a dial or knob that says freezer colder or warmer if so turn it for freezer to get warmer thast should allow cold aiur from freezer to enter into ref. that should make ref. colder. if to cold then dail it back a little at a time till ref. is what u like. ok try that. later gator.
Feb 15, 2011 | GE Monogram ZISS420NRSS 42" Built-In...
My GE TFX30PP is constantly running and doesn't turn off. The freezer is very cold but the frig side isn't cold enough. A repair guy put in a new "cold contol" sensor but it didn't help.
This is a very common issue, If the freezer compartment is cold and making ice the
problem is simply airflow from the freezer into the refrigerated section.
Typically when one senses the refrigerator is warm they max out the settings
on both dials the thermostat with its 1-10 settings as well as off for the compressor.
This controls the compressor and temperature.
The additional setting or dial is for colder freezer or refrigerator as well , However
it simply opens or closes a flapper door between the freezer and refrigerator boxes.
When that dial or setting is maxed , it closes and makes the freezer colder, yet leaves the refrigerated section starved for sufficient airflow to maintain a cold box in the refrigerated section.
Just set the dial that does not turn the compressor off to the middle setting.
One can leave the thermostat that does control the compressor in the max setting , just not the colder freezer setting, If you notice colder isnt colder refrigerator, Its actually colder freezer, A common issue found on 25% of all refrigerator calls a simple setting adjustment.
Its easy to think that maxing out the settings makes for a colder refrigerator, it doesnt, it makes a colder freezer and warm rerigeration section.
If a freezer is making ice, theres nothing wrong with the unit other than airflow setting.
I would also clesan the condenser coils off.
Add a comment
Dec 24, 2010 | GE Profile Performance 29.8 cu. ft....
May 08, 2009 | GE GSS20IEP Side by Side Refrigerator
Refrigerators Logo
18 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
