Question about LG Washing Machines
Lg front washer replace struts - LG Washing Machines
I moved a front load washer without shipping bolts, can it be fixed?
There is nothing to fix if there is nothing broken. Is there something broken, or not working correctly?
Mar 08, 2015 | LG WM-2277HW Front Load Washer
Replace rear struts how to replace
Remove front panel, lay washer on side opposite the strut you are replacing, remove old strut, replace with new one.
Oct 03, 2014 | Maytag Neptune MAH5500B Front Load Washer
Tub problems
replace or it will jump all over the place
Jul 12, 2014 | LG WM-0532HW Front Load Washer
The drum in my front load washer is whobbling/shaking really bad during the washing process. Found some plastic pieces on the floor. Any suggestions what the problem might be and is it difficult for a...
sounds like one of the struts has been broken take the back of and make sure all the struts are connected correctly and none of the holding pins have snapped. its an easy diy simply remove the plastic strut pins and replace faulty strut they correct the barrel as it washes
best of luck
merry christmas
Dec 13, 2010 | Frigidaire GLTF530DS Front Load Washer
Our LG front load washer and dryer are so out of balance when they spin that the vibration shook the compressor of our new refrigerator (which is located nearby) until it failed. We have placed rubber pads...
there must be a broken spring in the washer or a strut bar has come loose this unit should not be doing this. as per its age alone if you are some what technical remove the lid and check all four springs are attached and all five struts in line if not have it looked at it does not cost as much as a new machine these can be the only faults so you know what your looking for it will be hard for a service maN to rip you off
best of luck
please take the time to rank this advice
and have a merry christmas
Dec 07, 2010 | LG WM2487H Front Load Washer
Are struts on the front or back of this car?
The struts model (MacPherson Strut),are both in front and back of this car.
2000 - 2006 Hyundai Elantra Shock Absorber and Strut Assembly - Rear, Driver Side, KYB GR-2/EXCEL-G, Twin tube, Strut Assembly. $72
2000 - 2006 Hyundai Elantra Shock Absorber and Strut Assembly - Rear, Passenger Side, KYB GR-2/EXCEL-G, Twin tube, Strut Assembly $68
1996 - 2006 Hyundai Elantra Shock Absorber and Strut Assembly - Front, Driver Side, KYB GR-2/EXCEL-G, Twin tube, Strut Assembly $67
1996 - 2006 Hyundai Elantra Shock Absorber and Strut Assembly - Front, Passenger Side, KYB GR-2/EXCEL-G, Twin tube, Strut Assembly $63
Of course this is only the cartridge, you have to transfer the spring, and the top mount of the existing strut. You need a pair of coil spring compressor to do the job. The basic procedure to replace a strut is:
Remove the top nuts that secure the strut assembly to the frame mount inside the engine compartment. Do not remove the center nut.
Mark the lower strut mounting location on the hub for installation reference. The alignment will be close if the new strut is installed in the same position.
Remove the bolts that hold the strut assembly to the hub.
Remove the strut assembly from the vehicle.
Mark the top mount for installation reference. Using a side mounted spring compressor, compress the spring and remove the top nut and retaining washer. Pull strut assembly out from the bottom of spring.
Slide the new strut assembly up into the spring and reposition the top mount onto the spring in the same position that it was removed. Install the retaining washer and top nut.
Tighten the top nut to the manufacturer's specifications and carefully remove the spring compressor.
Place the strut assembly back into the vehicle.
Oct 16, 2010 | 2000 Hyundai Elantra
Washer shakes when spining. More on heavier loads.
shaking is generally due to inadequate floor structure under machine; i.e. plywood floor. in addition, if the washer is on a "pedistal" it will make matters worse; as the center of gravity is away from the floor. in rare cases, one of the drum "struts" can fall apart; and, cause excessive shaking. if you broke the locknut on one of the legs, unscrew the leg, and bring it to the hardware store for a replacement nut.
Feb 15, 2010 | LG WM2487H Front Load Washer
Bad vibrations/shaking with LG washing machine WM2032HW
What's the exact model of your washing machine? I'll need this to get you exact part numbers.
If you're looking for a quick and cheap fix that works. Try installing a rubber anti-vibration pad under the washer. I've had the best luck with a pad called Silent Feet. They are pretty hard to find in stores but Amazon.com carries the full line of Silent Feet anti-vibration pads. They will provide you with the best results short of replacing the full shock isolation assembly in the washer. And they cost a lot less.
Mar 03, 2009 | LG WM-2032H Front Load Washer
LG wm -1832c front loader making noise
when you take the panels off you will see that the barrel is suspended by springs on top and fake struts on the bottom. be careful when removing the panels. if the barrel is leaning forward it's the front struts, if it's tilting upward it's the rear. and be careful how much you load in a front loader
Feb 17, 2009 | LG WM-1832C Front Load Washer
LG WM2277HB drum wobbles when doing larger loads.
You could have a broken strut. However, keep in mind that these units are designed for 16llbs of dry weight for optimal performance.
Nov 27, 2008 | LG WM-2277HW Front Load Washer
Washing Machines Logo
15 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
