Question about First Act Learn and Play Keyboard ( Discovery)
New First Act keyboard keys won't work
I recently purchased a First Act keyboard. The keys make no sound at all
Hp probook 4510s key board problem
You can try cleaning keyboard with a toothbrush, but with repairing computers for 15 years I find -
a) buy a USB keyboard
b) buy and install a new laptop keyboard (easy-ish install)
c) install Sharpkeys - a program that changes a key of your choice to act like something else (example # becomes K)
Apr 19, 2013 | HP ProBook 4510s FM849UT Notebook
LAPTOP KEYBOARD UNEVEN
What type of HP is it?
Feb 14, 2012 | HP Computers & Internet
My keyboard only works when it wants to, i thought it was a virus but my laptop is now virus free and my keyboard still does not work properly, sometimes does not work at all sometime the number two holds...
If you have a sticky key that you know of you may have a couple that you haven't noticed. The number 2 key sticking usually means something was spilled on it at one time.If nothing is spilled you will only see the keys at the sides act up and usually the longer or larger ones. These act up from not hitting them straight but at an angle.
The next time it does this try thumping the keyboard to jar stuck keys loose. The key may look ok but is stuck just enough to do this. You just need to flick a finger at the keyboard to knock them loose. You may have to do this a few times before it dislodges the offender. On a normal keyboard you flip it over and knock on the back like knocking on a door to do this. On a laptop you can't hit it as hard.
If the keyboard keeps doing this your option is to replace it. Depending on the make and model a new laptop keyboard is about $45-$75 and is installed in a few minutes.
Sep 02, 2011 | MSI Computers & Internet
Acer keyboard can`t accsss keys such as question mark,. Alternat key won`t allow you to access uper keys.
Sounds like you need a new keyboard. If its a laptop they can be found by searching ebay or google the model and then "Replacement Parts" or "Replacement Keyboard".
If its a desktop, you need to purchase a new keyboard from a store or online.
Hope This Helps
Sep 02, 2010 | Computers & Internet
I recently dropped water on my acer aspire and now alot of the keys are not working can you tell me if i can buy a keyboard that has the fn key on it so i can brighten my screen as that feature no longer...
HURRY IMMIDIATLY DISCONNECT THE DEVICE FROM THE COMPUTER. you may short your motherboard if you dont act quickly.
What i would do is turn it upside down. Shake the liquid out while upside down. you must let it dry for quite some time i recommend 72 hours. it sounds harsh but if you wanna use it again that the best way to go.
Another thing to do is apply heat from FAR away to evaporate the heat.
let set for 24+ hours.
after that most of the time the keys might be sticky depending what you spilled in it. take apart keyboard with care and clean iwht alchol.
Feb 18, 2010 | Acer NSK8458AN Keyboard
F2 key does not work
Sounds like time for a new keyboard for your laptop - I'd suggest checking eBay! they have good prices on NEW keyboards most of the time - you can get one for about $10 depending on laptop model.
Feb 14, 2010 | Computers & Internet
Two keys periodically will not work - 1 and z - then if we keep hey depressed long enough, they work. Tried new batteries. What is lide expectatncy of thsi keyboard?
Should last a long time as long as the keyboard is being treated in a rough manner. I've had my keyboard for 3 years now and it still works fine.
Alot of times, dust or dirt gets in the keys and that can cause problems. You may want to use a can of air and blow underneath the keys to get extra dust or dirt away from it. That can cause keys act funky. Also any kind of liquid can cause problems as well.
Nov 26, 2009 | Microsoft Wireless Desktop 3000 Keyboard
Keyboard types wrong character
The problem is with your keyboard not with its s/w. if u have installed vista and still the problem remains then it is problem of keyboard. pls rush to nearest service center. don't do much experiment
Jun 15, 2009 | Medion MD-40954 Notebook
Keypad not functioning properly...
Check to see if your shift, control, alt, or other modifier keys are stuck on your keyboard. These can cause your keyboard to act erratically. Also, if this is a wireless keyboard, you may need to change the batteries, as this can also cause a keyboard to act erratically.
May 14, 2008 | Acer Computers & Internet
First Act Learn and Play Keyboard ( Discovery) Logo
13 people viewed this question
Top First Act Toys Experts
Andrew Taylor
Andrew Taylor
Are you a First Act Toy Expert? Answer questions, earn points and help others
