Question about Microsoft Xbox Live Three Month Premium Gold Pack for Xbox 360
Firewall settings blocking internet from Live. I know which ports need to be open, but i dont know how to open them (I have a U.S Robotics router)
Having trouble connecting to Xbox live. The MTU setting is above 1364 and the UPnP option is set. It directed me to firewall configuration but i don't know how to configure those settings so that it will connect.
    Genius:
  • 1,269 Answers
You must do port forwarding now to resolve the firewall problem. Call xbox on what port you must forward on the router's admin page for the xbox live. If I remember it correctly, xbox live uses port 3074 TCP and UDP, 88 TCP and UDP, 53 TCP and UDP, 80 TCP and UDP
Posted on May 07, 2009
Firewall block
you don't if you are sensible. Set the firewall with the correct ports instead, ask vonage for the port settings you need.
Oct 31, 2009 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
Connecting xp to xbox 360 for internet. now it tells me nhat i have a strict nat setting dont know how to change.
There should be an option for AUTO settings. Make sure that is selected and it should fix your problem. If not, post here again and I'll help further.
Sep 22, 2009 | Microsoft Xbox 360 Console
Motorola router nat not open for xbox live
Configuring the Firewall for Gaming
By default, the SBG900 firewall is disabled.
If, as recommended, you enable the firewall, refer to the game’s documentation to ensure that the necessary ports are open for use by that game.
The pre-defined SBG firewall policies affect X-Box LiveTM as follows:
LOW: XBox Live data can pass through the firewall. No user action is required.
MEDIUM or HIGH: To enable X-Box Live traffic to pass, you must configure:
• Choose Custom on the Firewall > POLICY — basic Page • UDP 88:88 and UDP/TCP 3074:3074 on the Firewall > POLICY — advanced Page
Configuring Port Triggers
Because the SBG has pre-defined port triggers for games using any of the following applications, no user action is required to enable them:
• DirectX 7 and DirectX 8 • MSN Games by Zone.com • Battle.net®
For a list of games supported by Battle.net, visit http://www.battle.net.
You may need to create custom port triggers to enable other games to operate properly. If you set custom port triggers and enable the firewall, you must customize the firewall to allow traffic through those ports.
To create custom port triggers, use the Gateway > PORT TRIGGERS — custom Page.
SB900 USER GUIDE
The motorola guide has more information relating to port triggers.
If you download the pdf file, go to page 27 for Firewall settings and Page 35 for Gaming Settings..
More indepth information is there.
Hope that helps
Mike
Sep 20, 2009 | Arris SURFboard SBG900 Wireless Router...
Cant connect to xbox live
First thing you want to do is make sure that the router isn't blocking the 360's MAC address, the best way to do this is to open up your internet browser and type 192.168.2.1 into the address bar which will bring up the Belkin router settings and then check any blocked access attempts in the wireless security section. If it isn't blocking it then you can change the port options in one of the other wireless options on the settings page.
May 27, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Port Forwarding with Kaspersky Internet Security 2009
Anti Hacker -> Settings -> Enable Firewall -> Low Security -> Settings ->
Rules For Applications -> Add -> Torrent
Edit Rules -> Add -> Rule Name -> utorrent
Properties -> Remote port (selected)
properties -> Local Port (selected)
Rule description -> Remote Port - >(enter the port) -> DEPENDS YOUR CONFIG
Rule description -> Local Port - >(enter the port) -> DEPENDS YOUR CONFIG
Allow Inbound and Outbound TCP connection, where :
Remote Port: DEPENDS YOUR CONFIG
Local Port : DEPENDS YOUR CONFIG
May 25, 2009 | U.S. Robotics MAXg(USR9108) Wireless...
I need to open my Nat for Xbox live. Please Help!
Configuring Your Dell™ TrueMobile™ 2300 Router for Gaming
Follow below steps to set up the router for gaming:
  1. Select the system or systems to be used as game systems.
  2. Locate the MAC address. For Windows 2000 and XP
    1. Click Start -> Run.
    2. Type cmd, and click OK.
    3. On the command prompt, type ipconfig /all
    4. Write down the MAC (Physical) address of your computer to configure for gaming.
  3. Open the web browser, and type http://my.router (or http://192.168.2.1)
  4. Click the Advanced Settings tab.
  5. Click the DHCP Server Settings tab on the left navigation bar.
  6. Click Add button in IP Address Reservation,
    1. Enter the MAC address of the system you wish to use for gaming in MAC Address field.
    2. Enter an IP address for the system (select a number between 101 and 254)
  7. Click Submit.
  8. Click the Port Forwarding Settings tab on the left navigation bar.
    1. To set a single computer for gaming, check the Enable DMZ Host box.
    2. Enter the IP address of the system at DMZ IP Address field.
    3. Click Submit.
      note.gif NOTE: Only a single computer can be set for DMZ service. To set multiple computers for gaming, please post your query again
  9. Reboot the client system. The client system will use the newly assigned IP and will not have any TCP/IP ports blocked by the firewall feature of the router.
May 18, 2009 | Dell TrueMobile 2300 Router (000001)
I have a USR 5461 router and would like to change my NAT to open for Xbox live. How do i do this?
PS3 and Xbox ( NON BELKIN)
You Will Have to Disable the Firewall In Your modem / Router
And IF it is a router then Open The Ports
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
And also make sure that UPnP is Enabled
Jan 18, 2009 | U.S. Robotics USRobotics USR5461 Wireless...
Key ports
I had the same problem and I tried everything I found in all kind of forums but nothing every seems to work.
What it worked for me was:
First:
Clear your proxy settings in Internet Explorer:
  1. Start Internet Explorer.
  2. On the Tools menu, click Internet Options.
  3. On the Connections tab, click LAN Settings.
  4. Clear the Automatically detect settings check box.
  5. Click OK, and then click OK again.
Then:
Check Internet Explorer security settings:
  3. On the Advanced tab, in the Security section, make sure that the Check for server certificate revocation check box is cleared. Also, make sure that the Use SSL 2.0 and the Use SSL 3.0 check boxes are selected.
  4. Click OK.
Apply Changes.
Close Internet Explorer
Run Windows Live Messenger and You Are Ready To Chat Again!!
Aug 08, 2008 | U.S. Robotics (USR8200USR8800KIT)
Ftp - port forwarding
Hello.. If you already have the port numbers needed and static IP on your computer, you can do the following steps to open them on your router:
1. connect a computer to the router wired.
2. Launch an internet browser and type in http://192.168.2.1. Use the user name and password that you have set for your router.
3. Click on the Firewall tab, then Port Forwarding
4. For the Protocol, specify if the port you will open is TCP or UDP.
5. Set the port numbers on both WAN and LAN port range then set the Static IP address on the textbox then click add. After doing that, check if you have an apply,save or ok button and click on that.
Here is the site for the user guide of your router.
If you do not know how to set a static IP on the computer, you can do the steps from this link. This depends on the operating system of the computer you are using. Make sure to set an IP address in the range of 192.168.2.x (x being a number from 2- 200).
Jul 30, 2008 | U.S. Robotics USRobotics USR5461 Wireless...
Microsoft Xbox Live Three Month Premium Gold Pack for Xbox 360 Logo
420 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
