Question about Whirlpool Calypso GVW9959K Top Load Washer
CA error code on Calypso Washer
CA error code comes up on Calypso Washer. Unplugged for a couple hours and replugged in. Ran a load without anything in it. Ran fine. Place a load of clothes in the washer and ran for 10 minutes then the CA error code appears again and shuts down the machine. Suggestions?
  • TyvekTape May 10, 2009
    Same problems over here, if I add clothes It will (at this point) no longer operate. I get CA, CI and more recently ob, there may have been some other codes also (SL) - after doing trobulshooting and some reading, I came up with the drive motor as the part to replace - though - I do have concerns more trouble may exist. I am on the fence, fixing this machine (first problem in 5 years), or a new one?
  • 351 Answers
CA Cl Average current limit Or Instantaneous current limit If a status signal comes back from the motor controller that a current limit has been breached, the unit will return to standby mode and display either CA for average current limit trip or Cl for instantaneous current limit trip. Average current trip occurs if there is a 2 second average of current draw greater than 5.55 amps at the motor windings. Instantaneous current trip occurs if there is a spike of 26 amps instantly at the motor windings. This may signify problems with the drive motor, thermal protector, or motor controller. Over-loading the unit may cause this problem.
Meaning you had stuffed it full one time and then it was hard on the motor, you will have to change the drive motor most likely...
Posted on May 08, 2009
I ran a self diagnostic test on my Whirlpool calypso washer and got CA error code. Do I need to replace the drive motor?
Before replace, I would first check the power supply, wiring and electronic.
Dado
Dec 24, 2014 | Whirlpool Calypso GVW9959K Top Load Washer
My calypso washing machine has an error code of "CA" What does this mean, it is squealing and will not drain water
CA means average current limit . this may signify problems with drive motor or motor controller over loading the washer may cause this problem. to clear this-press stop /cancel
Oct 04, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
I have a calypso washer it seems to be stuck on the heavy cycle no matter what i dothe display says 53 mins it wont do anyhting wont start if i hit the button wont let me choose another cycle like quick...
I just ran into a similar problem. Ours was stuck on Normal with 42 min. Started beeping every couple minutes last night after bad rain storm. Couldn't get it to stop. it would turn off if I hit stop and a couple minutes kater (like 2min) it would come on by itself. Left it unplugged overnight until about 6:00pm. Plugged it back in and it wnt right back to the normal mode after about 2min. HOWEVER, I keft it sit with the lid open and it beeped every couple minutes for a while then suddenly stopped. I checjked it and it is off, hasn't come back on. I haven't tried to run a load through it yet, so I don't know if it is fixed or not..
Oct 23, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Error code CA on calypso
http://www.applianceaid.com/calypso-codes.html#wash
Sep 27, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Machine stopped running during cyccle. No error
Unplugged the unit; replugged it. Buying a new machine.
Sep 14, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
My Calypso washing machine doesn't allow you to select start. It is an intermittent problem which seems to clear itself after a couple of hours. How do I fix it?
Hi , I,m online now trying to fix my calypso dryer problem , ijust got done fixing my washer 10 minutes ago (clogged pump) . In the past I have unplugged the units when they acted up (re-boot) and worked up til this sunday . Good luck !!
Rob
Aug 17, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Sears Calypso Washer purchased in 2004, displays the CA error code. Unplugged the washer for a couple hours and replugged in. Ran a cycle without anything in. Worked fine. Placed a load in and it ran for...
CA - Average Current peak - happens if there is a 2 second average of current draw greater than 5.55 amps at the motor windings. This may signify problems with the drive motor, thermal protector, or motor controller. Overloading the unit may cause this problem. Try washing smaller loads and see if the problem goes away. If it recurs when you wash bigger loads, decrease the size AND watch to see if you have to continue to decrease the size to keep the error from happening. If that were occurring, it could well be a sign of the electrical problems noted, requiring service.
May 07, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
CA Error Code - AEG OKO LAVAMAT 86700
c-a error message poped-up.washer stop working.............please help.
Sep 15, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
CA - communications error
most likely suspect is the relay bd under console this is the one on left there is some kind of communication problem between the 2 bds
May 17, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
1,496 people viewed this question
Dan Webster
Dan Webster
Sal De
