Question about Heavy Duty 648967 Arrow Electric Staple Gun/brad Nailer
Arrow ETF50BN electromatic staple gun/ how to load it?
How do you load it?
3 Suggested Answers
SOURCE: how to repair jammed arrow electo matic staple gun
You'll have to disassemble it. There is probably a staple lodged in the "hammer" mechanism on the business end of the stapler.
Often, these staple are very difficult to remove -- a very small flat-tip screwdriver and needle-nose pliers usually work best.
After you get all the jammed staples out, lubricate all moving parts with something akin to 3-IN-1 machine oil. This should prevent future jams.
Charlie
Posted on Aug 20, 2009
SRF518
  • 232 Answers
SOURCE: how to open arrow p22 staple gun
there is a spring follower in the base with a hook that latches into the body of the stapler. press in then down to unlatch the follower.
Posted on Oct 21, 2009
Testimonial: "yes thanks very much!"
How do I clear a jam?
You have to remove a clip & pin on the side of the staple machine to remove the lower portion where the staples are stored.
Mar 03, 2015 | Arrow Tools & Hardware - Others
Loading staples into a Stanley sharpshooter staplegun
There are 4 staplers in the Stanley SharpShooter family. You drop the staples on top of the "slide out loader," then slide it into the gun. See models and staple sizes below:
TR150HL Stanley Sharpshooter
  • Stanley SharpShooter TRA700 series or Arrow T-50 heavy duty staples
TR150 SharpShooter
PHT150C SharpShooter Heavy Duty Hammer Tracker
  • TRA700 series or Arrow T-50 heavy duty staples (1/4"-3/8")
TR250 SharpShooter Plus Heavy Duty Staple/Brad Nail Gun
  • Stanley SharpShooter TRA700 series or Arrow T-50 heavy duty staples and 1/2", 9/16" and 5/8" Brads
More information on the Stanley SharpShooter and a quick loading demo can be found here: http://www.expotv.com/videos/reviews/12/134/StanleyTR150HLSharpShooterHeavyDuty/185661
Sep 11, 2012 | Stanley Proto Stanley TR150HL SharpShooter...
Just got an ET50red electric staple gun. Loaded Arrow T50 14 mm staples with the points facing up and out of the tool. When I pull the trigger, the led worklight comes on, I hear and feel the stapler...
remove the staples and check inside for a jammed one up there. squirt some oil in there. load it again and try. please follow the instructions to a tee. having the wrong staples or what ever can damage the unit, if it isn't already. good luck
Jul 31, 2011 | Arrow T50P ARROW STAPLE GUN
How to load staples?
    • 1 Push in the push rod plate on the back of the Arrow T50P and press down to unclip the push rod from the gun. Pull the push rod out of the staple channel and away from the staple gun.
    • 2 Insert a strip of staples into the channel with the tips of the staples pointing toward the bottom of the staple gun.
    • 3 Place the end of the push rod into the staple channel of the gun. The end of the push rod has a small, solid piece of metal that fits into the staple channel.
    • 4 Press the rod all the way into the staple gun until the rod plate engages in the notch at the rear of the gun.
Jun 26, 2011 | Arrow T50P ARROW STAPLE GUN
How do you load new staples?
Find the button on the bottom of the stapler's back edge. Push the button in and down. Pull out the bar that pushes the staples into place. Slide in a row of staples with the points facing down. Push the bar back and lock it into place
Feb 20, 2011 | Arrow CHROME STAPLE GUN ARROW IND....
How do you load staples
A piece comes out of the rear of the staple channel and the staples go in there.It is spring loaded to push staples to the front of the gun.
Oct 09, 2010 | Arrow CHROME STAPLE GUN ARROW IND....
Can u tell me how to load the staples into my arrow t25 staple gun not used it for a long time
Hello. Here is a link to a free manual for your stapler. http://www.arrowfastener.com/upload/manuals/79055000259_manual.pdf
Look on page 3 for the three steps to load it.
1. Press latch in lower rear of gun to remove pusher rod from machine.
2. Insert strip of staples.
3. Replace pusher rod.
Happy stapling! J.
Jun 22, 2010 | Arrow T25 Staple Gun
How to load Staples ?
at the rear of gun there is a small door, press in and down at the same time , it should come out ,there is a spring attached to it as well.
Apr 15, 2010 | Arrow CHROME STAPLE GUN ARROW IND....
How do I load the staples in this staple gun?
Push in and down the silver color piece at the end of the gun. Pull piece and spring out. Load staples, end down. Reassemble.
Jul 07, 2009 | Arrow Fastener T27 Light Duty Household...
Arrow Fastener Co./Electric Staple Gun - ETF50BN
First make sure no staple is jammed between the hammer and the anvil or plunger and you might also try to spay with pb blaster or wd 40 and pull yhe trigger several times very rapidly and see if this will free plunger , does work to free sometimes
Jan 22, 2009 | Arrow T50P ARROW STAPLE GUN
Heavy Duty 648967 Arrow  Electric Staple Gun/brad Nailer Logo
722 people viewed this question
Top Heavy Duty Tools & Hardware - Others Experts
yoopertech
Tom Chichester
Are you a Heavy Duty Tool and Hardware - Other Expert? Answer questions, earn points and help others
