Question about Coffee Makers & Espresso Machines
How do i tighten a loose handle on a stella saucepan
silly girl
  • 513 Answers
SOURCE: loose door handle
DON'T remove the cover yourself unless you fully undertand the SAFETY issues involved in working inside a microwave oven. A microwave oven is possibly THE MOST DANGEROUS common consumer product to service. Usually with these doors, the latching parts tend to loosen up at times, thus requiring some re-adjustment and tightening. Sometimes they get a bit warn and require to be replaced. The handle by itself about $40, apparently GE doesn't know how to make a door handle that will hold up for more than a year or so. I just bought a new door off of eBay for $20 + $20 shipping ... a deal compared to the $135 + tax and shipping that most of the web sites want! All you need is a phillips screwdriver and a 5/16" socket. To get to 3 screws that anchor the TOP hinge, simply remove the vent grill (open the door and remove the 2 white screws that hold it in place). To get to the 2 screws that anchor the BOTTOM hinge, simply remove the 6 screws that hold the grey bottom pan of the microwave in place. The pan will swivel down, remaining attached in the back panel. Once you've removed the 5 hinge screws, the door should pull pretty much straight out. Reverse the procedure with the new door, which should come with hinges attached. Could be that the place the spring sits in is a little broken, so theres no stop for the spring. open it up and see if there's anything you can do with it, try some epoxy putty maybe. Good luck
Posted on Apr 30, 2006
SOURCE: Amana AFI2538AEW bottom freezer door handle is loose?
My dad's freezer handle is loose, model ABB2224DEW. Went to partselect.com and located drawing of freezer door parts. Found a link to a "do-it-yourselfer" that describes removal and replacement of the handle. Hopefully this helps.
Replacement of freezer door handle.
1. Removed freezer door handle. First I read the freezer door handle removal instructions in the Amana refrigerator user guide. Removing the handle requires inserting a plastic card at least 1.5 inches under the left end of the right side of the handle so it releases the butterfly clip latch on the freezer door. Next I pulled the right side of the handle to lift it away from the freezer door. Then still holding the handle away from the door, at the spot that is 1.5 inches from the inside of the right side of the handle, I held the plastic card vertically and slid one corner of it between the handle and the freezer door and worked the card down until it released the butterfly clip latch. Keeping the card at the same space under the handle so the latch was released, I then turned the card to the left until it was horizontal and was lifting the left end of the right door handle away from the freezer door. I then slid the handle across the card to the left until it cleared both door butterfly clip latches and it lifted off the door.
2. Installed freezer door handle. First I read the freezer door handle installation instructions in the Amana refrigerator user guide. The handle is curved on one edge and must be installed the curved side down. Correctly installed, the outside ends of the handle curve upward and the handle curve is down so it looks like a frowning mouth. Next holding the handle curved edge down, I turned it up so I could see the brackets and held it against the door. I lined up the handle brackets slightly to the left of the butterfly clips on the freezer door. Next I turned the handle with the brackets against the freezer door and slid it slightly to the right until the left side of the handle held onto the door butterfly clip by itself but was not latched. Then I lined up the right handle bracket with the right freezer door butterfly clip and carefully slid the whole handle to the right until I heard the left butterfly clip latch click. Next I slid the handle back slightly left once more and then slid it back to the right until I heard the right butterfly clip latch click.
Parts Used: HANDLE, DOOR (WHT) Level of difficulty: Difficult Time to do repair: 30 - 60 mins
Posted on May 29, 2009
  • 10 Answers
SOURCE: one handle is loose-how can I tighten it
shoulb be screws under cap on handle remove and tighten that should do the trick
Posted on Aug 18, 2009
SOURCE: Need handle for 40 year old Prestige saucepan
Replacements available for Prestige Lifetime pans
Contact ianelna@btinternet.com
Posted on Jan 12, 2010
blueextc3221
  • 15935 Answers
SOURCE: The door handles are loose. I want to tighten them
Remove the door gasket - and you will find the handle screws.
CLICK HERE to see the diagram.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Jan 13, 2010
I asked a question about getting new handles for my arcosteel saucepans and got referred to the Cars and trucks secrtion!!!
Arcosteel is pretty much lower end Stainless Steel cookware and unfortunately you will not be able to buy NEW parts for them as is also the case with most of the expensive brands. If any of your items are unusable because of the handle condition you will need to buy a new saucepan.
You might find people trying to sell off used sets cheaply in good condition and you could use the handles off those or the complete unit.
Dec 04, 2015 | Cars & Trucks
Loose single handle no brand name faucet
There is a little rubber icon Red for Hot and Blue for the cold on the front of the handle. Remove the rubber insert from the handle. There is a small allen screw that needs tighten to tighten your handle.
Mar 05, 2013 | American Standard Plumbing
What does the classic saucepan look like?
Saucepans are round pots with flat bottom used for cooking, heating and making sauces. It has varying size and depth with comfortable handle.
You can see the different Saucepans and pots at
GroomNStyle Top 5 Best Saucepan and Pot reviews 2015
Jan 14, 2013 | Home
My 40 year-old Prestige saucepan handles are disintegrating, and I would like replacements, Where can they be repaired, please?
Most of the saucepan handles are available at most of the Kitchen appliances stores/hardware stores . If the type does not match as per you model a slight correct can be done by a tool/machine shop near to your place.
Feb 05, 2011 | Vacuums
I have a saucepan that is Camelot Americana brand that I have had for 23 years. Today the handle broke and I am enquiring about purchasing a new handle. Could you please advise if there is a distributor...
Camelot Americana Temp-Tone cookware is still distrubuted and based on Bridge Street Rydalmere NSW Camelot Americana Distributors - Party Plan Selling.
Jan 04, 2011 | Microwave Ovens
Loose handle on door
The door handles mount on hex bolts sticking out of the door, the door handles have key hole inserts that match with the bolts. The door handles are then slid in one direction to lock the handles in place. Removal is the reverse. To tighten the door handle screw the bolt out enough that you can still put the handle over the bolt heads and slide the handle to lock the handle in place.
Apr 12, 2009 | GE Profile Stainless Bottom-Freezer...
Loose Oven door handle
Ok you need to use plastic or rubber washers against the glass so it doesn't break. To stop the handle comming loose again you need to put "Lock Tight" on the screw threads then tighten carefully only untill the handle isn't loose. You can get this from any good hardware store. cheers
Please give feedback
Mar 23, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Loose handles - GE monogram model # ZFSB25DMD SS
try removing the handle, that will expose the mounts for the handle. You should be able to tighten them after removing the handle.
Jan 08, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Coffee Makers & Espresso Machines Logo
27 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
