Question about Yamaha Audio Players & Recorders
Yamha reciever Rx-v757 displays PS PRT : 035
Using the diag page It list this code PS PRT ::035 four time
5 Suggested Answers
  • 151 Answers
SOURCE: Yamaha RX-V757
make sure you have not wired from box to speaker then to another speaker ,you should wire from switch box to one speaker then from box to another speaker, this presents the right load to the amp, if you have done this you may have a faulty switch box.
hope this helps.
cable guy.
Posted on Jun 20, 2008
TOLhamRadio
  • 509 Answers
SOURCE: Yamaha RX-V757: Tuner not working
Is it set for XM / Sirius? If so, you need their special antennae unit; or are you talking AM & FM?
Posted on Jan 12, 2010
SOURCE: can a yamaha ipod dock connect to an rx-v757
You can connect him true the auxiliary inputs with an adaptor cable 3.5mm to rca
Posted on Jun 02, 2010
SuperTech-11
  • 1591 Answers
SOURCE: My Yamaha RX-V757 Receiver wont
There are internal fuses in this unit.
Check these fuses first.
If you find a fuse that measures open, and the glass isn't black or black/silver then simply replacing the fuse may do the trick.
Make sure you get an EXACT match for the fuses, some are slo-blow because of the power on surge it has to allow.
Posted on Feb 27, 2011
Yamaha rx v757 av receiver
tape out to line in on eq, line out from eq to tape in on receiver, use tape monitor switch to make eq work
Mar 14, 2014 | Audio Players & Recorders
My Yamaha RX-V757 Receiver wont turn on at all, everthing has gone blank??? Help
Feb 27, 2011 | Yamaha RX-V757 Receiver
Can a yamaha ipod dock connect to an rx-v757 receiver?
Jun 02, 2010 | Yamaha RX-V757 Receiver
Jan 12, 2010 | Yamaha RX-V757 Receiver
Multiple lights are lite when running a cycle....can't run certain cycles (bulky items, whites etc) spin light continuously blinks. have tried unplugging and restarting with no results
I feel you may have a Control Board issue. I would see if the Control Board will let you into Service Mode. If it does I would read the Diag code blocks 1 thru 40. The block only show up when an error event has been logged.
Bottom line I see no easy way out without least swapping out the Control Board for a start point.
You will need the FAV6800A/FAV9800A Service Manual to get started. See page 17 of the SM TO READ THE Diag codes
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
Here is a quick start if the Control Board will let you into Service Mode;
To enter Service Mode press and hold simultaneously the Enviro Plus and Spin Only keys until the machine beeps and the LED display reads 00.
From the Service Manual;
Display Diagnostic Codes
The diagnostic code display can be toggled on and off from Service Mode by pressing the Wrinkle Control key. The display will show a “d”. The diagnostic codes can be viewed by using the Set Delay Time arrow keys. The Set Delay Time down arrow key will cycle down the list one code at time each time it is pushed. The Set Delay Time up arrow key will cycle up the list one code each time it is pushed. The first time the Set Delay Time down arrow key is pushed, the newest code will be displayed. A code generated during or after the current cycle will be displayed with the rightmost dot “.” turned ON. Access Other Features While a diagnostic code is displayed, if the Normal
If you decide to give it a try jot down the code blocks and toss them back to us for review.
The Control Board p/n 25001217
Another vendor Clothes Washer Control Board - 25001217
Good Luck Rich
Dec 29, 2009 | Maytag Neptune FAV6800AW Top Load Washer
I've lost all digital sound to my reciever.
Get into the cable box menu and look for audio settings, chances are your digital output from the cable box is off. If you still can't get audio, reply with your Cable Box Make & Model and I can help you further. Hope this helps
May 25, 2009 | Yamaha RX-V757 Receiver
My Yamaha HTR-6050 shuts off at random times and says "Check SP Cable"
i think it means speaker cable?
http://www.fixya.com/search/p514076-yamaha_rx_v2700_7_1_channels_receiver/check_sp_cable
Apr 23, 2009 | Yamaha RX-V757 Receiver
Yamaha RX-V757 No Left Channel Output - Video Sources Only
First - make sure it is not a defective cable by reversing the leads/colors on the inputs if problem then goes to the right channel then you know it is a bad cable/RCA, etc., connector. I would try that first.
Thanks,
dthomas
Feb 07, 2009 | Yamaha RX-V757 Receiver
Yamaha RX-V995 receiver turns on & then powers off 2 seconds late
I suggest you run self diag.  press [FM/AM] key + [Input mode] key and press the [power/standby] switch.
ps prt = power supply problem
dc prt = shorted output or leakly cap in channel
tmp prt means to hot on heatsink
you'll likely have to measure the resistances of the output FETs to find a short,
Jan 02, 2009 | Yamaha RX-V995 Receiver
Reciever turns itself off
try cleaning it out, get all the dust out of it if not , you may have some screwed up capacitors or transformer
Jan 02, 2009 | Yamaha RX-V757 Receiver
26 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
