Question about Locks & Locksmithing
Handle on my Kwikset lock keeps falling off
The handle side with key insert the handle keeps falling off
brainyass
  • 242 Answers
SOURCE: The Door Handle Will Not Unlock!
Remove both sides of the handle and you should be able to slide the lock mechanism so the door opens.
Posted on Oct 23, 2008
  • 10 Answers
SOURCE: cannot remove disk that covers screws to tighten my lock
The screws are located on the non locking side of the handle. To get the cover off most pop off by placing a small screwdriver behind the edge and gently prying. Paint/varnish will make this harder so you my have to take a razor and cut around it.
Please rate.
Posted on Jun 05, 2009
rsmith972278
  • 160 Answers
SOURCE: the key for my kwikset door handle lock won't
The answers to your problem are very numerous.
Usually what has happened is that when the lock was installed the pins (the part of the lock that rides on the cut part of the key) were not facing down. This allows dirt and debris to collect in the pin holes and also if a spring breaks it won't push the pin up to the cut part of the key. Some locks you can't even rotate to a position that faces down.
What I suggest is removing the knob or lever lock from the door and blowing out the key hole with compressed air. Work the key back and forth through the lock and blow it out again. If this doesn't work ... try and get a refund or a replacement from wherever you got it. Remember your time is worth money and so is your frustration. Don't waste allot of time trying to fix something that can be replaced relatively cheaply.
Thanks,
RSMITH972278
Posted on Oct 13, 2009
rsmith972278
  • 160 Answers
SOURCE: how do i remove exterior handle kwikset titan?
You need to insert the key and turn it clockwise, then insert a stiff metal tool like a straightened out heavy paper clip into the hole on the shaft of the lock by the circular flange next to the door. Push it in until you feel it give and pull out on the handle at the same time. If you need more help please contact me.
Best of Luck,
RSMITH972278
Posted on Nov 14, 2009
  • 35 Answers
SOURCE: have a kwikset bathroom door
Wiggle the backset a few times while pulling on one side or the other. Certain brans have a catch and will opnly release when this is done.
Posted on Feb 02, 2011
Im trying to tighten up the screws in my kwikset lever knob in my bathroom but I keep pushing in that little hole on the side and it still wont come off. Is it broken?
There is a setscrew in the hole. Insert a 3/32" hex wrench (Allen wrench) and turn to the left to loosen. The handle will pull off easily.
Jul 01, 2014 | Locks & Locksmithing
Will all kwikset keys unlock all kwikset locks?
I've heard of this problem happening. Whenever the key is changed, check it several times before locking the door. If you have keys duplicated, the duplicates must be very accurate or they might not work reliably. Difficult to know what causes this, unless someone is tampering with the lock, or resetting it improperly. Or could be defective cylinders - which would be disappointing. Pin-tumbler cylinders do not have this problem, it's something unique to Kwikset
Smartkey.
May 21, 2014 | Kwikset Professional Door Lock...
Kwickset door handle fell apart on my front door help
Kwikset locks are inexpensive because they do not have replaceable parts. Buy a new one.
By the time the lock breaks, it's probably time to get different keys, but if you have so many keys in the hands of people you cannot contact, or you have more than three other locks keyed alike, and you must have the new lock work with the same keys as before, the place where you buy new locks probably has someone who can rekey the new lock to your old keys. Kwikset also sells locks that you can rekey to other Kwikset keys yourself. They are more expensive than other locks of the same type, but could save money long term, especially if you find a need to rekey your locks a lot (lots of visitors, part-time tenants or roommates, your kids lose their keys a lot, etc.)
Sep 07, 2013 | Kwikset Professional Door Lock...
Kwikset 730LL-RH handle fall out, How to fix it?
I'm including a link to the installation/assembly instructions for the Lido LL730 3:
http://s7d5.scene7.com/is/content/BDHHI/44594-01
I'd recommend that you contact Kwikset Customer Support if you are unable to repair it:
Kwikset Corporation
Consumer Service
19701 DaVinci
Lake Forest, CA 92610
Kwikset Customer Service
Call: 1-800-327-LOCK (5625)
Here's the link for their customer service page:
http://www.kwikset.com/Customer-Support/Contact-Us.aspx
Feb 11, 2011 | Kwikset 4 Lido Lh Passage Levers Satin...
Have a kwikset bathroom door handle. Want to put on a new one. I took screws off but handle won't come off. How do I release the handles?
Feb 02, 2011 | Kwikset Locks & Locksmithing
I have Kwickset door knobs on my outside doors. I
The instructions they send are almost always generic and cover more than one subject.
If you insert the key and turn it all the way clockwise, you should be able to insert the tool tip they sent you into the hole on the shank part of the handle. Pull straight out and it should come off. Some times it takes several attempts to do.
Next turn key counter clockwise back to starting position and remove key. Dump lock out of handle, paying attention to orientation. Turn lock 180 degrees and reinsert back into handle. Put lock and handle back on to door and reinsert the key. Turn key clockwise and push.... remove key.
Hope this Helps,
RSMITH972278
P.S. PLEASE RATE MY ASSISTANCE
Jan 20, 2010 | Kwikset Professional Door Lock...
How do i remove exterior handle kwikset titan?
Best of Luck,
RSMITH972278
Nov 13, 2009 | Kwikset Professional Door Lock...
Door knob will not stay set. Keeps slipping out.
i would say the only fix for it is a replacement.sounds like its wore out, sorry
Jul 11, 2009 | Kwikset Sheridan Handle Set
Cannot remove disk that covers screws to tighten my lock
Please rate.
Jun 03, 2009 | Kwikset Professional Door Lock...
Changing doors would like to know how to take off kwikset door
remove the two screws on each side of the door knob from the inside of the door use medium size phillips head screw driver
pull the door handle off
remove the handle from exterior door side
remove two phillips screws from the side door that hold the door bolt pull the door bolt assembly out
reinstall on new door
insert bolt assembly
insert knob for exterior side(a lign it up
insert knob from interior side and align screws and tighten ligtly
check door for easy turning of knob and actuating latch
good luck
remove that assembly
take screw driver and remove the two scres that remove the plate on the side of the door and
Dec 29, 2008 | Kwikset Professional Door Lock...
Locks & Locksmithing Logo
80 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Tom Chichester
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
