Question about Dell Dimension 3100 PC Desktop
Computer doesn't start normally. Hangs everytime.
Hi. My computer doesn't start up normally. when i try to boot it, the first thing that appears is the computer brand. There are multiple options in that screen. When you press the delete key, you can enter the settings, when you press the tab key. you display the bios post message.
when i try both. after 30 seconds. a message appears saying auto detecting pri -slave.
then after that, the computer hangs. Everytime I turn on my computer. It always happens.
Your help will be greatly appreciated!
tnx :)
  • 2 more comments
  • razon_zean_k May 08, 2009
    @sir jeff
    you said to change the battery.. as I'm not into these stuff ( not techie and all )
    Pls guide me on how to change the battery..
    Step by step tutorial will be greatly appreciated.
    thank you very much sir!!
  • Ryan Oaks May 11, 2010
    Do you have secondary hard drive? Also, have you tried pressing nothing? Have you installed any new hardware recently?
  • Chris Hingee
    Chris Hingee May 11, 2010
    It appears that your C drive (ie hard drive has failed) do it make a clicking noise?
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    Go into the BIOS by pressing F2 and tell me if your hard drive is being detected in there.
  • Dell Master
  • 2,404 Answers
Your going to need a new hard drive put into the system. The one you have now is bad.
Posted on May 08, 2009
  • 42 Answers
Your battery is dead change the battery the bios is not saving your setting due to battery and popping up to find hard drive again it is using the defaults settings
My dell inspiron 1454 keeps looping on the boot up screen, then just goes back to the windows has filed to start screen..
Hi Charlotte,
The video doesn't show what you describe. The video shows that Windows is loading. Try booting in safe mode. Here's how:
Power up the machine. When the Dell logo appears, start tapping the F8 key until the Advanced Boot Options menu appears amd choose "Windows Safe Mode." Once windows starts, backup your data just in case. Then try to determine what it was you did last that may have caused the problem. Then try to start normally.
Hope this helps
Randy
Nov 02, 2012 | Computers & Internet
After powering on monitor says no sync
I've almost the same problem. When the system turns on the monitor doesn't sync. After a variable trials with down/up the sync is enabled and the computer starts.A very clear event occurs : when the monitor can''t sync ( and system doesn't boot)you can hear very clear a high fan rotation. When I look/hear in the system the Isuspect the cpu fan. The system boots ( monitor syncs) when the fan rotationgoes from high to low. So the system hangs on an internal check on the rotation speed of the cpu fan.I've googled a lot , but until now doesn't find an answer . Possibilties which I think about : replace cpu fan , clean cpu fun ( but it looks clean).I cannot measure the fan rotation speed when the system is hanging. At normal rotation all info can retrieved witth the program cpu-z.Did you already have a solution ?
Dec 07, 2011 | Compaq Presario 5000 PC Desktop
Acer Aspire One D255 with Windows 7 starter installed does not start up. Everytime i start the netbook, it prompts me to repair it or start normally. Start normally doesn't work and prompts me back to...
Usually this error occurs because there are some files missing from your operating system's directories. I would suggest using a Windows 7 DVD that has the operating system on it. You can put that in the CD drive and then the repair option should work. If you don't have a Windows 7 DVD, you may have to buy one. If there is important data on your hard drive, avoid reformatting it. If you're ever asked to format, say no. The following link is the cheapest Windows 7 DVD I could find, but you may want to shop around. (http://www.softwaresupplygroup.com/microsoft-windows-7-home-premium-32-bit-oem-branded-gfc-00564-brd.html) I hope this helps!
May 07, 2011 | Computers & Internet
Hi; I was downloading a video from internet, then a warning message appeared on screen denoting infection & necessity of downloading the suggested program which I refrained.then I disconnected from...
Start the computer in safe mode and then reinstall from the disk, also you could use press either f2 to change the order of boot from the hardrive to the disk,or F8 or F12 depending on the computer to boot from a selective drive, goodluck, viruses are nasty things.
Mar 14, 2011 | Computers & Internet
The laptop when booting up stops after the BIOS screen and then only shows a non-blinking cursor in the upper left of the screen. This happens everytime I try to start the machine at either warm or cold...
Hi, there is a possibility its trying to boot from a disc in the cd drive, if theres a disc in the drive remove it and try booting again as this can sometimes affect boot up, if this desn't work try repeatidly pressing F8 as the the laptop boots, a menu should appear with a few options on, using the arrow keys select boot using last know good configuration press enter and see if that fixes things, if not do the same again but his time select safe mode only, you might get lots of large icons etc but thats normal, then from your start menu/all programs select your virus program and do a virus scan on your hardrive.
If this doesn't work and all other avenues have been tried you could try a system restore using the F8 method
Hope this helps
Feb 12, 2011 | Toshiba Satellite A305-S6845 Notebook
I do have a dell laptop, but last night it hangs up den i cannot turn it off already so i'd just let the battery empty, i recharge it wen i woke up in the morning den it says the computer was not shut down...
I second what computus suggested, but I believe you'll have to press F8 repeatedly during boot instead of ESC or Del button. Boot up in safe mode and it should be able to restore things :-)
Aug 13, 2010 | Dell Inspiron 1525 Notebook
Program won't load
Boot your computer in Safe Mode by holding down the F8 key during boot-up, and selecting Safe Mode from the list when it appears. Once you're in Safe Mode, click Start, then Run, and type "msconfig" (without the quote marks) in the box. You'll get a screen with various options. Choose the Startup Programs tab and clear all the checkboxes on the list, then restart your computer normally. If the problem disappears, it means some program is trying to start automatically and causing your system to hang. To determine which program that is, re-enable your startup programs one by one, by going back into msconfig and checking its box, then rebooting. When your system hangs again on boot-up, you'll have figured out which software is the culprit. Uninstall it using its own uninstall routine or by going into Control Panel, Add & Remove Programs.
Please rate this solution!
~~Cheryl
Jan 03, 2009 | Screenplay Systems Writer's Dreamkit 4.0...
Start up problem
try to disable start up items that are not required...for that u have to boot in safe mode and type msconfig in Run
Dec 10, 2008 | Compaq Presario Notebook
PC Booting problem
format the pc and reinstall os be sure to load all the drivers
Apr 09, 2008 | Computers & Internet
Dell Dimension 3100 PC Desktop Logo
174 people viewed this question
Alun Cox
