Question about New Home 2014LE Mechanical Sewing Machine
What bobbin does a new home sd2014 use - New Home 2014LE Mechanical Sewing Machine
All of an sudden my New Home machine has begun to knot up badly on the bobbin (underside) of stitches.....tried everything.....changed bobbin, etc Manual very little help!
Install a brand new needle.
Remove the top thread from the machine.
ALWAYS RAISE the presser foot and rethread from the beginning.
May 10, 2017 | New Home Sewing Machines
Why has it stopped working?
Most of the time if the bobbin won't engage is you are not making a connection as its has a certain way it goes on. Most New Homes are proprietary on how the different parts engage. If you look and not think too hard take your time, you will discover the proper way to get the bobbin to engage.
Jul 04, 2015 | Janome New Home Portable Mechanical Sewing...
Bobbin housing new home deluxe 445
here is a link for a manual, it should have the information about the bobbin housing in it.
New Home 445 Instruction Manual
Dec 10, 2014 | New Home Sewing Machines
How to thread bobbin model L373 new hope
Google make and model + word "manual"
http://homeappliance.manualsonline.com/manuals/mfg/europro/europro_sewing_machine_product_list.html
Jul 19, 2014 | New Home L-372 Mechanical Sewing Machine
What bobbin do I use for my New Home hf5024 sewing machine?
check with sewingpartsonline.com & ask them, cause it may be the bobbin spindle is not working right or the bobbin you were trying is stripped out
I also have several plastic & I have to make sure I get them just right when I put them on the bobbin spindle that they lock in correctly
Mar 30, 2012 | New Home 5024 Mechanical Sewing Machine
Hi. I need a new bobbin case for a New Home Model
Standard type bobbin case that can be bought on ebay or any sewing machine shop
Jun 16, 2010 | New Home HF-2022
My daughter in law's machine won't pick up the bobbin thread. I've never even seen a bobbin that loads like that so I don't know what to tell her. In fact, I've never even heard of a new home sewing...
New Home is Janome.
The bobbin thread may not be picking up because the needle is in backwards.
Refer to the manual for the machine - some require the flat side of the needle face to the back of the machine and some to the left side of the machine.
May 07, 2010 | New Home L-373 Mechanical Sewing Machine
My machine will not thread any bobbins.
Your bobbin winder has seized. Remove the top cover and oil the area where the bobbin winder shaft goes through the bobbin winder assembly. You might need to force the winder to turn with your fingers for a while, but it will begin to turn smoothly once the oil gets in there.
If the black bobbin winder tire has a flat spot worn into it, you will need a new bobbin winder tire. Costs around a dollar.
Apr 07, 2010 | New Home L-372 Mechanical Sewing Machine
Threading a bobbin on the new home 2014le
place spool of thread in , route it towards your bobbin holder, take thread and put through one hole about 4 inches hanging ontop. press it in and slide it to the right where you hear a click, hit the peddle, should be winding, it will automatically stop on its own when full. click it to the left when done, snip it and then drop that into your bobbin holder , cover your plate, thread your upper thread and presto you are now sewing with your threaded bobbin, always remember these steps. #1 material choice #2 thread weight #3 needle size. you got to match those 3 for beautiful perfect stitches.
Dec 16, 2009 | New Home 2014LE Mechanical Sewing Machine
New Home 2014LE Mechanical Sewing Machine Logo
22 people viewed this question
Top New Home Sewing Machines Experts
Tally Girl
Tally Girl
Nava Hirshenson
Nava Hirshenson
Level 1 Expert
Are you a New Home Sewing Machine Expert? Answer questions, earn points and help others
