Question about Ativa MD1200 12-Sheet Cross-Cut Desktop Shredder
Door open light staying on - Ativa MD1200 12-Sheet Cross-Cut Desktop Shredder
Fiat doblo door open light stays on and doors won't lock
this is the door open light indicator on your instrument panel correct? it thinks the door is open. do interior courtesy lights work? i.e. turn on off when opening doors? check for "normally open" circuit faults in the door switches
Aug 27, 2012 | Fiat Doblo Cars & Trucks
Expedition door open light stays on most of the time.
spray wd-40 in the latch on the doors then slam them a few times to loosen the switch on the latch that turns the light on with the key in the ignition and doors close if the chime rings like the key was left in the ignition then start with the drivers door
Aug 12, 2012 | 1999 Ford Expedition
The light on my craftsmans model 139.53990 garage door opener comes on when the door is opened but only stays on about 5 seconds. It lights when closed and stays on the normal length of time.
Very strange but you can try this. Unplug the opener and remove the light bulb. Use a small screwdriver and pry out on the center contact in the light socket. Replace the bulb and plug the opener in.
Aug 07, 2011 | Sears Craftsman LiftMaster Chamberlain...
Door won't open. door locked light stays on. I
Press and hold the End of Cycle Signal button for three seconds. This will turn off the Control Lock feature.
Thank you !!
Jul 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Door open indicator stays on and lights stay on and car won't lock
One of the doors "thinks" it is open.That will make light stay on, power door locks will not operate and alarm will not arm itself. If the indicator shows which door is open, then check on the door frame for the door ajar pin / switch. Move it by hand repeatedly to see if it is stuck or misaligned. If unable, then pull the pin out to check the connection, and if still no help, then bridge (short) the cables to see if dome light goes out. If this is the case, then replace the pin.
May 19, 2010 | 2006 Volkswagen Jetta
Overhead light stays on all the time on craftsman garage door opener
Hello. If the light stays on all the time check these:
A. The light time delay on the opener will keep the light on for approximately 4-1/2 minutes after the system has be activated, then will turn the light off automatically.
B. If the opener has a worklight switch (which is supplied only with a four-function wall console), slide the switch to "OFF" position.
C. If the opener has a pedestrian switch (which is supplied only with a four-function wall console), the light will stay on for 4-1/2 minutes after the pedestrian door has been opened.
Mar 31, 2010 | Sears Craftsman LiftMaster Chamberlain...
My door open light stays on as do interior lights
Sounds like one of the door triggers has continuity to earth,(Shorted) Test them all with a multi meter.
Cheers CeeBee
Oct 20, 2009 | 1999 Chrysler Concorde
Door open light stays on when door shut.
sounds like a faulty door switch not sensing that the door is shut. test the switches for continuity to determine the faulty switch
Jan 27, 2009 | KitchenAid KUDS24SE Built-in Dishwasher
2003 Explorer door ajar light stay on when all doors are closed
I had this problem on my 2003 explorer and took WD40 and gave the lock mechanism a good dose where it meets the clasp on the door jam. Then open and close the doors a couple of times to get them working. They get gummed up and sometimes have a tendency to stick.
Dec 29, 2008 | 2003 Ford Explorer
Ativa MD1200 12-Sheet Cross-Cut Desktop Shredder Logo
Top Ativa Office Equipment & Supplies Experts
jasbo
jasbo
Are you an Ativa Office Equipment and Supply Expert? Answer questions, earn points and help others
