Question about Sealy Electric Mattress Pad
Broken control-need replacement - Sealy Electric Mattress Pad
Wiredcontroller is broken..options how to connect manually
Depending on what you mean by broken, you could do one of two things: open it and clean it (sometimes dust can in theory get stuck and make it appear as if the controller is broken), or find another broken controller on ebay (for cheap) and replace any piece that could be physically broken. Ideally, there would be a working piece in that broken controller that you could use for your current controller.
Feb 03, 2018 | Computers & Internet
How to replace the knob and stem on a frigidaire range?
Stem is part of control switch need to replace control .....
Knob is probably fine, just pull out shaft from knob use old knob on new switch as long as plastic knob is not broken
Aug 12, 2014 | Frigidaire Kitchen Ranges
On/off swith knob broken
Is it the actual knob that is broken or the little tab the knob holds onto that is broken. You either need a replacement knob or a replacement switch assuming the know is also the thermostat for the unit. Does that same knob control the fan speed? Temprature or timer?
Mar 31, 2014 | Pelonis Heating & Cooling
Left front lower control arm broken in 2004 Honda Civic Hybrid
i would replace it, not easily done you need special tools
Feb 13, 2014 | 1993 Chevrolet C1500
Broken metal wire in ibm selectric ii
You have either a broken tilt tape or rotate tape. One controls the tilting of the element (ball) and the other controls the rotation of it. If either one is broken, you will need a qualified technician to replace it and make any adjustment necessary so it doesn't break again.
Oct 17, 2013 | IBM Correcting Selectric II
Dtergent dispencer does not open
Dispenser Lever
If the dispenser is broken and doesn't open or close properly the dispenser lever might need to be replaced.
Detergent Dispenser Cover
If the detergent dispenser cover is broken and the detergent dispenser doesn't work, the dispenser assembly should be replaced.
Wax Motor Actuator
If the dispenser will not release the detergent the actuator connected between the wax motor and the dispenser might be broken. Check the wax motor actuator and replace it if necessary.
Detergent Container
If the dishwasher dispenser doesn't work the detergent container may need to be replaced.
Dispenser Lid
If the dispenser is broken and doesn't open or close properly the dispenser lid may have to be replaced.
Detergent Dispenser
If the dishwasher dispenser doesn't work the problem is often related to the release mechanism. If the problem is with the dispenser itself, it may be easier to replace the entire dispenser.
Dispenser Door Spring
If the dispenser is broken and doesn't open during the wash cycle the dispenser door spring may have to be replaced.
Dispenser Latch
If the dispenser is broken and doesn't open or close properly the dispenser door latch may have to be replaced.
Dispenser Door Pin
If the dispenser is broken and doesn't open or close properly the dispenser door pin may have to be replaced.
Enter your model number to see parts for your dishwasher.
Dispenser Actuator
If the dispenser is broken and doesn't open or close properly the dispenser actuator may have to be replaced.
Dispenser
If the dispenser is broken and doesn't open or close properly the entire dispenser assembly may have to be replaced.
Wax Motor
There is an electrically powered device called a wax motor which opens the detergent dispenser. If the dispenser is broken and will not open to release the detergent, the wax motor might need to be replaced.
Bi-Metal
If the dishwasher dispenser doesn't work the bi-metal actuator might be burned out or defective. The bi-metal is a simple metal loop which acts as a latch for the dispenser door. As electricity is applied to the metal loop, the loop deforms and bends away from the latch, releasing it. If the bi-metal is burned out it won't deform or release the detergent door.
Dispenser Slide
If the dispenser is broken and doesn't open or close properly the dispenser slide may need to be replaced.
Dispenser Repair Kit
If the dispenser is broken this dispenser kit may need to be replaced.
Main Control Board
The main control board provides power to nearly every component of the dishwasher including the detergent dispenser. If the dispenser will not actuate the main control board might be defective. You should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
God bless you . see the photo attached.401f2962-5d22-48f3-89be-c1db11d8eabe.jpg
May 23, 2013 | Hotpoint-Ariston FDD914 24 in. Built-in...
Troubleshooting
Dispenser Lever
Wax Motor Actuator
Dispenser Lid
Detergent Dispenser
Dispenser Latch
Dispenser Door Pin
Dispenser Actuator
Dispenser
Wax Motor
Bi-Metal
Dispenser Slide
Main Control Board
Gd bless you
I need to know about the part that clips off that holds the air vent, a/c controls, and radio. Mine was broken into and the radio was stolen and the a/c controls behind the clip are broken and I can only...
you should be able to get the replacement parts from a dealer, from your description you should only need the radio/ac bezel and the ac control knobs.
Mar 12, 2010 | 2001 Dodge Neon
Right joystick
I don't personally know of anywhere that will replace the stick. If it truly is broken as you say, you will need to purchase another one. After all, it is broken.
Nov 11, 2008 | Microsoft MS Xbox 360 Common Controller...
Xbox controller
The joystick breaks when a plastic piece inside breaks. This problem can be fixed using parts from a second broken controller. Open both controller cases, take a good joystick from one (can be left or right) and replace the broken piece in the other. You'll need a soldering iron, solder, and desoldering braid. You don't want to use a desoldering pump as the contacts come off the board VERY easily.
May 28, 2008 | Microsoft Xbox 360 Controller
Sealy Electric Mattress Pad Logo
53 people viewed this question
Top Sealy Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Sealy Furniture Expert? Answer questions, earn points and help others
