My maytag centennial commercial technology model: MVWC300VWO has started draining while filling when I start cycle ? Plz. S.o.s.
2 Suggested Answers
richroth
  • 9472 Answers
SOURCE: I have a Commercial Series
Replace the "water inlet valve" on your machine. If you could post your model number I can point you to the part you need.
Posted on Dec 26, 2010
How do I fix my Maytag Centennial commercial technology washer.
No agitation? first use a meter and check ur water pressure switch? that is what sends the machine the message to start wash cycle? You can test it with a meter and with a manual test? ( first locate it in the panel, it has a plastic clear tube hose going into it, remove that tube from its connection, now put another small tube or hose into the slot where it was and have the machine set to wash cycle with water in it. Blow into the other end of the tube. If the machine starts to wash. the pressure switch is more than likely good. now take the original hose tube and plug one end and blow into it the other end, it should be hard and have pressure, if it is easy to blow and u dont feel any pressure and it feels like the air is going out ? sometimes they get busted open or a pin hole and release air causing the water switch diaphram to not open. if both check ok then next the motor coupler or belt if belt driven. check with a multi meter for continuity the door switch, and if there is a little movement on wash cycle in 1 direction only then check the cam dogs in agitator.
Mar 28, 2015 | Maytag Washing Machines
Our maytag centennial commercial technology washing mechine fills up with water goes to the rinse cycle and doesn't go any figher I think it would be the pump as it doesn't drain so it can't go to the next...
you didn't say if it washes or not I am guessing it does then when it finishes it is not pumping the water out. before u buy a new pump u should clean all drain lines and filter. be sure u check the discharge hose to make sure it is not plug. if all lines are clear then I would look to the pump as possible problem
Apr 19, 2014 | Washing Machines
Maytag Centennial Top Load Washer drains as it fills.
The water is probably siphoning out of the tub. Your drain pipe is either too low or the drain hose is down too far into the pipe. Take the drain hose out of the pipe and lift it high. I'll bet your problem goes away
Feb 06, 2014 | Maytag Centennial Top Load Washer
My washing machine hums and does not start it's cycle.
Possible that the INLET VALVE is humming and the valve is blocked or jammed . You can remove the outlet from the inlet valve and check if there is water flow If not tap on the valve with a soft hammer. It might release the valve and allow the flow, check also the water at the inlet and if the filter at the inlet is clogged.
Click this Link: Inlet valve
Jan 25, 2013 | Washing Machines
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
